DK799P
DK799P
    C-TON
    PROCESS METER 0-10VDC LCD PNL MT
DK799P 数据手册
Voltage Powered LCD Digital Panel Meters Adjustable Voltage 4½ Digit EPIC SERIES DK790V Series Features: ◊ Low-cost, high-performance replacement for many OEM DPMs ◊ 4½ digits with high-contrast LCD ◊ Optional RED, GREEN or AMBER backlighting ◊ 12V or 24V DC Voltage powered ◊ Snap-in bezel mount eliminates mounting hardware ◊ User selectable, displayed engineering units ◊ Resistant to RF and EMI Ordering Information: Specifications: Display: Digits: Type: Backlighting: Polarity: Annuciators: Decimal Points: Overrange: Inputs: Ranges: Configuration: Impedance: Performance: Accuracy: Conversion Rate: Normal Mode Rejection: Adjustments: Warmup: Temperature Coefficient: Offset Range: Gain Range: Environment: Operating Range: Storage Range: Power Supply: Optional Backlight: Mounting: Connection: 4 ½ digits (±19999 counts) 0.45" (11.4 mm) 7 segment LCD Optional Red Negative (red numbers/black background) Optional Green Negative (green numbers/black background) Optional Amber Negative (amber numbers/black background) Optional Green Postive (black numbers/green background) automatic, “-” displayed °F, °C, PSI, %, user selectable, V, A KW, PF 4 position, user selectable four lower order digits blank for inputs >19999 & 30 dB @ 60 Hz span (gain) (2) (10V and 5V) and zero (offset) 10 minutes typical ±100 ppm per °C typical -19999 to +19999 1-20000 counts above adjusted zero 0 to 50 °C -10 to 60 °C 12 VDC or 24 VDC regulated (selectable) 24 VDC at 35 mA typical snap-in bezel mount 4 screw terminal (6 with backlight) PART NUMBER BACKLIGHT COLOR BACKLIGHT POWER DK796*......................................... NEG AMBER.................................................24 VDC DK797*......................................... NEG GREEN.................................................24 VDC DK798*......................................... NEG RED......................................................24 VDC DK799*......................................... NO BACKLIGHT.............................................. NONE DK800*......................................... POS GREEN.................................................. 24VDC *Add (P) for Power Engineering Units V, A, KW, PF PW2-12.................................................... Regulated 120V AC to 12V DC Power Supply PW2-24.................................................... Regulated 120V AC to 24V DC Power Supply PW1.0............................................................................24V AC to adjustable DC output CPW1.5.........................................................................24V AC to adjustable DC output CVC...................................................................................................................Calibrator C-TON Industries • PO Box 172 • Sunapee, NH, 03782 • USA • Phone (603)456-2655 • email: info@ctonindustries.com Voltage Powered LCD Digital Panel Meters Adjustable Voltage 4½ Digit DK790V Series EPIC SERIES Dimensions Wiring Decimal Point Selection 1. Locate jumpers J4 through J6 in the middle of the circuit board unit. 2. Jumper the appropriate decimal location as follows: J4 - 000.0 J5 - 00.00 J6 - 0.000 None - 0000 C-TON Industries • PO Box 172 • Sunapee, NH, 03782 • USA • Phone (603)456-2655 • email: info@ctonindustries.com
DK799P 价格&库存
很抱歉,暂时无法提供与“DK799P”相匹配的价格&库存,您可以联系我们找货
