DK807 & 809 Series
Adjustable LCD Digital Panel Meters
Large 1" - 3½ Digit Loop Powered or Voltage Controlled LCD DPM
Features:
◊ Large 1”, 3½ digit display for easy viewing.
◊ Wide ZERO (Offset) & SPAN (Gain) adjustment
◊ Decimal point user selectable
◊ Standard ⅛ DIN package
◊ Engineering units user selectable
◊ Snap-in panel mounting
◊ Non-backlit LCD or choice of AMBER, GREEN, RED or BLUE backlit LCD
◊ Gasket and clamp provided for NEMA 4, NEMA 12, & IP66 applications
Specifications:
Display:
Digits:
Type:
Polarity:
Annuciators:
Decimal Points:
Overrange:
Inputs:
Voltage Ranges:
Current Range:
Configuration:
Impedance:
Performance: Accuracy:
Conversion Rate:
Normal Mode Rejection:
Warmup:
Temperature Coefficient:
Adjustments:
Offset Range:
Gain Range:
Environment: Operating Range:
Storage Range:
Power Supply: Loop Powered:
Voltage Controlled:
Backlighting:
Mounting:
Connection:
Ordering Information:
3 ½ digits (±1999 counts)
1" (24.9 mm) 7 segment high contrast LCD
automatic, “-” displayed
°F, °C, PSI, %, user selectable, V, A, KW, PF
3 position, user selectable
three lower order digits blank for inputs >1999 & < -1999
200 mV, 5 V, 10 V (809 Series)
4 to 20mA (807 Series)
single ended (809 Series)
390KΩ (809 Series)
±(0.05% of full scale + 1 count)
3 per second
>30 dB @ 60 Hz
10 minutes typical
± 100 ppm per °C typical
25 turn potentiometers
-1999 to +1999
1 to 1999 (custom ranges available)
-10 to 50 °C
-40 to 75 °C
300Ω nominal at 20 mA (807 series)
10 mA at 12 V (9 to 16 V) or 24 V (16 to 32 V) (809 series)
35 mA typical @ 24 VDC
snap-in panel mount or clamp and gasket (included)
screw terminals
PART NUMBER ...... BACKLIGHT COLOR ....... METER INPUT ............METER POWER ... BACKLIGHT POWER
DK807A*...........NO BACKLIGHT ........4-20mA . ............. mA loop ...................... NONE
DK757B*................... BLUE..................4-20mA . ............. mA loop ..................... 24VDC
DK857B*.................... RED...................4-20mA . ............. mA loop ..................... 24VDC
DK947B*..................AMBER.................4-20mA................ mA loop ..................... 24VDC
DK957B*..................GREEN.................4-20mA................ mA loop ..................... 24VDC
DK809*.............NO BACKLIGHT ........Voltage...............12/24VDC...................... NONE
DK759*..................... BLUE..................Voltage ..............12/24VDC..................... 24VDC
DK859*...................... RED...................Voltage ..............12/24VDC..................... 24VDC
DK949*....................AMBER ...............Voltage ..............12/24VDC..................... 24VDC
DK959*....................GREEN.................Voltage ..............12/24VDC..................... 24VDC
*Add (P) for Power Engineering Units V, A, KW, PF
PW2-12....................................................Regulated 120V AC to 12V DC Power Supply
PW2-24....................................................Regulated 120V AC to 24V DC Power Supply
PW1.0........................................................................... 24V AC to adjustable DC output
CPW1.5........................................................................ 24V AC to adjustable DC output
CVC.................................................................................................................. Calibrator
C-TON Industries • PO Box 172 • Sunapee, NH, 03782 • USA • Phone (603)456-2655 •
email: info@ctonindustries.com
DK807 & 809 Series
Dimensions
Wiring
807 Series
1. DECIMAL SELECTION:
1999
199.9
19.99
1.999
J7 J6 J5 J4
2. J1, J2, J3 SELECTION:
IF:
OFFSET (ZERO) IS ≤ 0 or
OFFSET (ZERO) > 0 and GAIN (SPAN) ÷ OFFSET (ZERO) ≥ 5
J3 J2 J1
809 Series
A
B
IF:
OFFSET (ZERO) > 0 and GAIN (SPAN) ÷ OFFSET (ZERO) < 5
NOTE: If backlight supply is not loop supply,
ground should be referenced together.
J3 J2 J1
A
B
LED Digital Panel Meters
DK800/900 Series
Large 3½ Digit LED Digital Panel Meter
Features:
◊ Large, 0.8”, 3½ digit, GREEN or RED display for easy viewing
◊ Snap-in panel mounting - no tools or hardware required
◊ Gasket and clamp provided for NEMA4, NEMA12, & IP66 applications
Specifications:
Display:
Inputs:
Performance:
Environment:
Power Supply:
Mounting:
Connection:
Digits:
Type:
Polarity:
Decimal Points:
Overrange:
Hold:
Ranges:
Configuration:
Protection:
Impedance:
Accuracy:
Conversion Rate:
Common Mode Range:
Common Mode Rej.:
Zero Adjustment:
Warmup:
Operating Range:
Storage Range:
0.8” (20.3 mm) LED
automatic, “-” displayed.
display hold function is standard
±200.0 mV, +/-2.000 V, +/-20.00 VDC
bipolar, differential
±350 VDC, (±100 VDC on 200 mV range)
>1 MΩ, (>10 MΩ on 200 mV range)
±(0.05% FS +1 counts)
3 per second
>30 dB @ 60 Hz
±1V DC
>86 dB
automatic
10 minutes typical
±100 ppm per °C typical
-10 to 50 °C
-40 to 75 °C
+5V DC (± 5%) 180 mA @ 5 V
13 pin male connection
PART NUMBER
METER COLOR
METER INPUT
DK851A........................................... RED ............................................................ 200mV
DK852A........................................... RED ................................................................... 2V
DK853A........................................... RED ................................................................. 20V
DK951A........................................ GREEN . ........................................................ 200mV
DK952A........................................ GREEN . ............................................................... 2V
DK953A........................................ GREEN . ............................................................. 20V
J4C13........................................................................13 Pin Connector / Wire Assembly
PW2-5........................................................Regulated 120V AC to 5V DC Power Supply
PW1.0............................................................ 24V AC to adjustable DC output
CPW1.5......................................................... 24V AC to adjustable DC output
CVC...................................................................................................Calibrator
很抱歉,暂时无法提供与“DK947BP”相匹配的价格&库存,您可以联系我们找货
