DK807AP
DK807AP
    C-TON
    PROCESS METER 4-20MA LCD PNL MT
DK807AP 数据手册
DK807 & 809 Series Adjustable LCD Digital Panel Meters Large 1" - 3½ Digit Loop Powered or Voltage Controlled LCD DPM Features: ◊ Large 1”, 3½ digit display for easy viewing. ◊ Wide ZERO (Offset) & SPAN (Gain) adjustment ◊ Decimal point user selectable ◊ Standard ⅛ DIN package ◊ Engineering units user selectable ◊ Snap-in panel mounting ◊ Non-backlit LCD or choice of AMBER, GREEN, RED or BLUE backlit LCD ◊ Gasket and clamp provided for NEMA 4, NEMA 12, & IP66 applications Specifications: Display: Digits: Type: Polarity: Annuciators: Decimal Points: Overrange: Inputs: Voltage Ranges: Current Range: Configuration: Impedance: Performance: Accuracy: Conversion Rate: Normal Mode Rejection: Warmup: Temperature Coefficient: Adjustments: Offset Range: Gain Range: Environment: Operating Range: Storage Range: Power Supply: Loop Powered: Voltage Controlled: Backlighting: Mounting: Connection: Ordering Information: 3 ½ digits (±1999 counts) 1" (24.9 mm) 7 segment high contrast LCD automatic, “-” displayed °F, °C, PSI, %, user selectable, V, A, KW, PF 3 position, user selectable three lower order digits blank for inputs >1999 & < -1999 200 mV, 5 V, 10 V (809 Series) 4 to 20mA (807 Series) single ended (809 Series) 390KΩ (809 Series) ±(0.05% of full scale + 1 count) 3 per second >30 dB @ 60 Hz 10 minutes typical ± 100 ppm per °C typical 25 turn potentiometers -1999 to +1999 1 to 1999 (custom ranges available) -10 to 50 °C -40 to 75 °C 300Ω nominal at 20 mA (807 series) 10 mA at 12 V (9 to 16 V) or 24 V (16 to 32 V) (809 series) 35 mA typical @ 24 VDC snap-in panel mount or clamp and gasket (included) screw terminals PART NUMBER ...... BACKLIGHT COLOR ....... METER INPUT ............METER POWER ... BACKLIGHT POWER DK807A*...........NO BACKLIGHT ........4-20mA . ............. mA loop ...................... NONE DK757B*................... BLUE..................4-20mA . ............. mA loop ..................... 24VDC DK857B*.................... RED...................4-20mA . ............. mA loop ..................... 24VDC DK947B*..................AMBER.................4-20mA................ mA loop ..................... 24VDC DK957B*..................GREEN.................4-20mA................ mA loop ..................... 24VDC DK809*.............NO BACKLIGHT ........Voltage...............12/24VDC...................... NONE DK759*..................... BLUE..................Voltage ..............12/24VDC..................... 24VDC DK859*...................... RED...................Voltage ..............12/24VDC..................... 24VDC DK949*....................AMBER ...............Voltage ..............12/24VDC..................... 24VDC DK959*....................GREEN.................Voltage ..............12/24VDC..................... 24VDC *Add (P) for Power Engineering Units V, A, KW, PF PW2-12....................................................Regulated 120V AC to 12V DC Power Supply PW2-24....................................................Regulated 120V AC to 24V DC Power Supply PW1.0........................................................................... 24V AC to adjustable DC output CPW1.5........................................................................ 24V AC to adjustable DC output CVC.................................................................................................................. Calibrator C-TON Industries • PO Box 172 • Sunapee, NH, 03782 • USA • Phone (603)456-2655 • email: info@ctonindustries.com Adjustable LCD Digital Panel Meters Large 1" - 3½ Digit Loop Powered or Voltage Controlled LCD DPM DK807 & 809 Series Dimensions Wiring 807 Series 1. DECIMAL SELECTION: 1999 199.9 19.99 1.999 J7 J6 J5 J4 2. J1, J2, J3 SELECTION: IF: OFFSET (ZERO) IS ≤ 0 or OFFSET (ZERO) > 0 and GAIN (SPAN) ÷ OFFSET (ZERO) ≥ 5 J3 J2 J1 809 Series A B IF: OFFSET (ZERO) > 0 and GAIN (SPAN) ÷ OFFSET (ZERO) < 5 NOTE: If backlight supply is not loop supply, ground should be referenced together. J3 J2 J1 A B C-TON Industries • PO Box 172 • Sunapee, NH, 03782 • USA • Phone (603)456-2655 • email: info@ctonindustries.com LED Digital Panel Meters DK800/900 Series Large 3½ Digit LED Digital Panel Meter Features: ◊ Large, 0.8”, 3½ digit, GREEN or RED display for easy viewing ◊ Snap-in panel mounting - no tools or hardware required ◊ Standard ⅛ DIN package ◊ Gasket and clamp provided for NEMA4, NEMA12, & IP66 applications ◊ Decimal point user selectable Ordering Information: Specifications: Display: Inputs: Performance: Environment: Power Supply: Mounting: Connection: Digits: Type: Polarity: Decimal Points: Overrange: Hold: Ranges: Configuration: Protection: Impedance: Accuracy: Conversion Rate: Normal Mode Rejection: Common Mode Range: Common Mode Rej.: Zero Adjustment: Warmup: Temperature Coefficient: Operating Range: Storage Range: 3 ½ digits (±1999 counts) 0.8” (20.3 mm) LED automatic, “-” displayed. 3 position, user selectable three lower order digits blank for inputs >1999 & < -1999 display hold function is standard ±200.0 mV, +/-2.000 V, +/-20.00 VDC bipolar, differential ±350 VDC, (±100 VDC on 200 mV range) >1 MΩ, (>10 MΩ on 200 mV range) ±(0.05% FS +1 counts) 3 per second >30 dB @ 60 Hz ±1V DC >86 dB automatic 10 minutes typical ±100 ppm per °C typical -10 to 50 °C -40 to 75 °C +5V DC (± 5%) 180 mA @ 5 V snap-in panel mount or clamp and gasket (included) 13 pin male connection PART NUMBER METER COLOR METER INPUT DK851A........................................... RED ............................................................ 200mV DK852A........................................... RED ................................................................... 2V DK853A........................................... RED ................................................................. 20V DK951A........................................ GREEN . ........................................................ 200mV DK952A........................................ GREEN . ............................................................... 2V DK953A........................................ GREEN . ............................................................. 20V J4C13........................................................................13 Pin Connector / Wire Assembly PW2-5........................................................Regulated 120V AC to 5V DC Power Supply PW1.0............................................................ 24V AC to adjustable DC output CPW1.5......................................................... 24V AC to adjustable DC output CVC...................................................................................................Calibrator C-TON Industries • PO Box 172 • Sunapee, NH, 03782 • USA • Phone (603)456-2655 • email: info@ctonindustries.com
DK807AP
物料型号:DK807 & 809 Series
器件简介:这是一系列可调节的LCD数字面板表,具有大尺寸1英寸至3½位的显示,支持环状供电或电压控制。
引脚分配:文档中提到了不同的引脚配置,例如807系列和809系列有不同的接线方式。
参数特性:包括显示类型、极性、量程、小数点位置、超量程显示、输入电压范围、电流范围、配置类型、阻抗、性能准确性、转换速率、正常模式抑制、预热时间、温度系数及调整等。
功能详解:文档详细描述了如何进行零点和增益的调整,以及如何选择合适的工程单位。
应用信息:适用于需要精确测量和显示的工业环境,支持多种工程单位的选择,并提供了NEMA 4、NEMA 12和IP66等级的防护。
封装信息:提供了详细的尺寸信息,包括面板切割尺寸、安装支架轮廓、后视图等,以及安装方式和连接方式的说明。
DK807AP 价格&库存
很抱歉,暂时无法提供与“DK807AP”相匹配的价格&库存,您可以联系我们找货
