CUB5TB00
CUB5TB00
    REDLIONCONTROLS(美国红狮)
    COUNTER LCD 8 CHAR 9-28V PNL MT
CUB5TB00 数据手册
Bulletin No. CUB5T-E Drawing No. LP0628 Released 04/16 Tel +1 (717) 767-6511 Fax +1 (717) 764-0839 www.redlion.net MODEL CUB®5T - MINIATURE ELECTRONIC PRESET TIMER AND CYCLE COUNTER  LCD, REFLECTIVE OR RED/GREEN LED BACKLIGHTING  0.46" (11.7 mm) HIGH DIGITS  7-DIGIT BI-DIRECTIONAL TIMING CAPABILITY  6-DIGIT CYCLE COUNTING CAPABILITY  OPTIONAL RELAY OUTPUT MODULE  OPTIONAL SERIAL COMMUNICATIONS MODULE (RS232 or RS485)  SELECTABLE TIMER RANGES AND OPERATING MODES C UL R  ELAPSED TIMER AND PRESET TIMER FUNCTIONALITY  DISPLAY COLOR CHANGE CAPABILITY AT PRESET OUTPUT US LISTED  OPERATES FROM 9 TO 28 VDC POWER SOURCE IND. CONT. EQ. 51EB  NEMA 4X/IP65 SEALED FRONT BEZEL GENERAL DESCRIPTION The CUB5T provides the ultimate in timer flexibility, from its complete user programming to the optional relay output and serial communications capability. The meter functions as an Elapsed Timer or Preset Timer. It also has a built-in Cycle Counter. The display can be toggled either manually or automatically between the Timer and Cycle Counter values. With eight different input operating modes and 18 selectable timer ranges, the meter can be programmed for a wide variety of timing applications. The CUB5T has an LCD display with 0.46" (11.7 mm) high digits. The LCD is available in two versions, reflective (CUB5TR00) and backlight (CUB5TB00). The backlight version is user selectable for red or green backlighting with variable display intensity. The Timer has two signal inputs and eight input operating modes. These modes provide level active or edge triggered start/stop operation. A Display Hold mode will display the elapsed time for one cycle, while the next cycle continues timing internally. The Timer Reset modes will automatically reset the timer value when a time start edge is applied to the input. This allows sequential timing cycles without having to manually reset the Timer. In addition to the Timer inputs, a programmable User Input is available to perform a variety of meter functions. All inputs are current sinking (active low) and accept a variety of logic and open-collector output signal sources. Relay and switch contacts can also be used as signal sources, when the software input debounce filter is enabled. The capability of the CUB5T can be easily expanded with the addition of a field installable option module. When the CUB5RLY0 relay output module is added, the meter becomes a Preset Timer. The Setpoint Output can be assigned to the Timer or Cycle Counter values, and configured to suit a variety of control and alarm requirements. Serial communications capability for RS232 or RS485 is added with a serial option module (CUB5COM). DIMENSIONS In inches (mm) The CUB5T can be powered from an optional Red Lion Micro-Line/Sensor Power Supply (MLPS), which attaches directly to the back of a CUB5T. The MLPS is powered from an 85 to 250 VAC source and provides up to 400 mA to drive the meter and sensors. SAFETY SUMMARY All safety related regulations, local codes and instructions that appear in this literature or on equipment must be observed to ensure personal safety and to prevent damage to either the instrument or equipment connected to it. If equipment is used in a manner not specified by the manufacturer, the protection provided by the equipment may be impaired. Do not use this meter to directly command motors, valves, or other actuators not equipped with safeguards. To do so can be potentially harmful to persons or equipment in the event of a fault to the meter. CAUTION: Risk of Danger. Read complete instructions prior to installation and operation of the unit. CAUTION: Risk of electric shock. Note: Recommended minimum clearance (behind the panel) for mounting clip installation is 2.15" (54.6) H x 3.00" (76.2) W. .13 (3.3) ON 1.29 (32.8) 1.54 (39.1) SEL 1 .15 (3.8) 1.71 (43.4) 1 ECE 3 4 +.024 1.30 -.000 +6 (33 -0 ) RST 2.95 (74.9) 2 +.025 2.68 -.000 +8 (68 -0 ) Ordering Information TYPE CUB5 Optional Plug-in Cards MODEL NO. DESCRIPTION CUB5TR CUB5TB CUB5RLY Preset Timer and Cycle Counter with Reflective Display Preset Timer and Cycle Counter with Backlight Display Single Relay Option Card RS485 Serial Communications Card RS232 Serial Communications Card +12 VDC Micro-Line Power Supply, 85 to 250 VAC source, 400 mA max out +24 VDC Micro-Line Power Supply, 85 to 250 VAC source, 200 mA max out Programming Cable RS232 (RJ11-DB9) Communication Cable RS485 (RJ11-DB9) CUB5COM MLPS Accessories CBLPROG CBPRO PART NUMBER CUB5TR00 CUB5TB00 CUB5RLY0 CUB5COM1 CUB5COM2 MLPS1000 MLPS2000 CBLPROG0 CBPRO007 General Meter Specifications 1. DISPLAY: 8 digit LCD 0.46" (11.7 mm) high digits CUB5TR00: Reflective LCD with full viewing angle CUB5TB00: Selectable transmissive red or green backlight LED with viewing angle optimized. Display color change capability at preset when using a relay module. 2. POWER: Input voltage range is +9 to +28 VDC with short circuit and input polarity protection. Must use an RLC model MLPS or a Class 2 or SELV rated power supply. MODEL NUMBER DISPLAY COLOR INPUT CURRENT WITHOUT CUB5RLY0 INPUT CURRENT WITH CUB5RLY0 CUB5TR00 CUB5TB00 CUB5TB00 --Red (max intensity) Green (max intensity) 10 mA 85 mA 95 mA 30 mA 115 mA 125 mA 9. ENVIRONMENTAL CONDITIONS: Operating Temperature Range for CUB5TR00: -35 to 75°C Operating Temperature Range for CUB5TB00 depends on display color and intensity level as per below: INTENSITY LEVEL Red Display Green Display 1&2 3 4 5 1&2 3 4 5 TEMPERATURE -35 -35 -35 -35 -35 -35 -35 -35 to to to to to to to to 75°C 70°C 60°C 50°C 75°C 65°C 50°C 35°C Storage Temperature: -35 to 85°C Operating and Storage Humidity: 0 to 85% max. relative humidity (noncondensing) Vibration to IEC 68-2-6: Operational 5 to 500 Hz, 5 g. Shock to IEC 68-2-27: Operational 40 g Altitude: Up to 2000 meters 10. CERTIFICATIONS AND COMPLIANCES: CE Approved EN 61326-1 Immunity to Industrial Locations Emission CISPR 11 Class A Safety requirements for electrical equipment for measurement, control, and laboratory use: EN 61010-1: General Requirements EN 61010-2-030: Particular Requirements for Testing and Measuring Circuits RoHS Compliant UL Recognized Component: File #E179259 UL Listed: File #E137808 Type 4X Indoor/Outdoor Enclosure rating (Face only) IP65 Enclosure rating (Face only) IP20 Enclosure rating (Rear of unit) Refer to EMC Installation Guidelines for additional information. 11. CONSTRUCTION: This unit is rated for Type 4X/IP65 requirements for indoor/outdoor use. Installation Category I, Pollution Degree 2. High impact plastic case with clear viewing window. Panel gasket and mounting clip included. 12. WEIGHT: 3.2 oz (100 g) 3. TIMER DISPLAY: 7-digits Display Designator: “t” to the left side of the display Display Range: 0 to 9999999 Overflow/Underflow Indication: Display flashes “t OVEr” Minimum Digit Resolution: 0.001 Sec. Maximum Single Digit Resolution: 1 Hr. Timing Accuracy: ±0.01% 4. CYCLE COUNTER DISPLAY: 6-digits, may be disabled if not used Display Designator: “C” to the left side of the display Display Range: 0 to 999999 Overflow/Underflow Indication: Display flashes “C OVEr” Maximum Count Rate: All Count Sources except Input B: 10 Hz Input B Count Source: With Timer Input Filter ON: 10 Hz With Timer Input Filter OFF: 500 Hz 5. TIMER SIGNAL INPUTS (INP A and INP B) Logic Inputs, Current Sinking (active low) Input A: Internal 7.8KΩ pull-up resistor to +9 to 28 VDC Trigger levels: VIL = 1.25 V max; VIH = 2.75 V min; VMAX = 28 VDC Input B: Internal 10KΩ pull-up resistor to +9 to 28 VDC Trigger levels: VIL = 0.7 V max; VIH = 2.4 V min; VMAX = 28 VDC Inputs A and B: Timer Input Pulse Width: 1 msec min. Timer Start/Stop Response Time: 1 msec max. Filter: Software filtering provided for relay or switch contact debounce. Filter enabled or disabled through programming. If enabled, results in 50 msec start/stop response time for successive pulses applied to the same input terminal. 6. USER INPUT (USR): Programmable function input Logic Input, Current Sinking (active low) Internal 10KΩ pull-up resistor to +9 to 28 VDC Trigger levels: VIL = 0.7 V max; VIH = 2.4 V min; VMAX = 28 VDC Response Time: 5 msec typ.; 50 msec debounce (activation and release) 7. MEMORY: Nonvolatile E2PROM memory retains all programming parameters and timer/counter values when power is removed. 8. CONNECTIONS: Wire clamping screw terminals Wire Strip Length: 0.3" (7.5 mm) Wire Gage: 30-14 AWG copper wire Torque: 3.5 inch-lbs (0.395 N-m) max. 2 Optional Plug-in Cards ADDING OPTION CARDS WARNING: Disconnect all power to the meter before installing Plug-in card. The CUB5T meters can be fitted with optional relay card and/or serial communications cards. The details for the plug-in cards can be reviewed in the specification section below. The plug-in cards, that are sold separately, can be installed initially or at a later date. RS485 SERIAL COMMUNICATIONS CARD Type: RS485 multi-point balanced interface (non-isolated) Baud Rate: 300 to 38400 Data Format: 7/8 bits; odd, even, or no parity Bus Address: 0 to 99; max 32 meters per line Transmit Delay: Selectable. 2 msec min. or 50 msec min. RELAY CARD Type: Single FORM-C relay Isolation To Sensor & User Input Commons: 1400 Vrms for 1 min. Working Voltage: 150 Vrms Contact Rating: 1 amp @ 30 VDC resistive; 0.3 amp @ 125 VAC resistive Life Expectancy: 100,000 minimum operations Response Time: Turn On Time: 4 msec max. Turn Off Time: 4 msec max. Time Accuracy: ± 0.01% 1.0 Installing the RS232 SERIAL COMMUNICATIONS CARD Type: RS232 half duplex (non-isolated) Baud Rate: 300 to 38400 Data Format: 7/8 bits; odd, even, or no parity Meter INSTALLATION While holding the unit in place, push the panel latch over the rear of the unit so that the tabs of the panel latch engage in the slots on the case. The panel latch should be engaged in the farthest forward slot possible. To achieve a proper seal, tighten the latch screws evenly until the unit is snug in the panel (Torque to approx. 28 to 36 in-oz [0.202 to 0.26 N-m]). Do not over-tighten the screws. The meter meets NEMA 4X/IP65 requirements when properly installed. The unit is intended to be mounted into an enclosed panel. Prepare the panel cutout to the dimensions shown. Remove the panel latch from the unit. Slide the panel gasket over the rear of the unit to the back of the bezel. The unit should be installed fully assembled. Insert the unit into the panel cutout. INSTALLATION ENVIRONMENT The unit should be installed in a location that does not exceed the operating temperature and provides good air circulation. Placing the unit near devices that generate excessive heat should be avoided. The bezel should only be cleaned with a soft cloth and neutral soap product. Do NOT use solvents. Continuous exposure to direct sunlight may accelerate the aging process of the bezel. Do not use tools of any kind (screwdrivers, pens, pencils, etc.) to operate the keypad of the unit. NUT FASTENER BEZEL PANEL +.025 -.000 (68 +.8 ) -.0 MOUNTING SCREW 2.68 MOUNTING CLIP PANEL GASKET 2.0 DIP Switches The DIP switches on the main circuit board are not used with the CUB5T and must be left in the factory set position (all down). Setting any switch to the up position may cause improper operation of the meter. 3 +.024 -.000 (33 +.6) -.0 1.30 3.0 Installing Plug-In Cards The Plug-in cards are separately purchased option cards that perform specific functions. The cards plug into the main circuit board of the meter after the rear cover is removed WARNING: Disconnect all power to the meter before installing Plug-in Card. Comms Card ON 1 2 ECE 3 4 Relay Card REMOVE/REPLACE THE REAR COVER To remove the rear cover, locate the cover locking tab below the 2nd and 3rd input terminals. To release the tab, insert a small, flat blade screwdriver between the tab and the plastic wall below the terminals. Inserting the screwdriver will provide enough pressure to release the tab locks. To replace the cover, align the cover with the input terminals and press down until the cover snaps into place. 4.0 Wiring the Locking Tab CAUTION: The Plug-in cards and main circuit board contain static sensitive components. Before handling the cards, discharge static charges from your body by touching a grounded bare metal object. Ideally, handle the cards at a static controlled clean workstation. Also, only handle the cards by the edges. Dirt, oil or other contaminants that may contact the cards can adversely affect circuit operation. Meter WIRING OVERVIEW Fair-Rite part number 0443167251 (RLC part number FCOR0000) Line Filters for input power cables: Schaffner # FN2010-1/07 (Red Lion Controls # LFIL0000) 6. To protect relay contacts that control inductive loads and to minimize radiated and conducted noise (EMI), some type of contact protection network is normally installed across the load, the contacts or both. The most effective location is across the load. a. Using a snubber, which is a resistor-capacitor (RC) network or metal oxide varistor (MOV) across an AC inductive load is very effective at reducing EMI and increasing relay contact life. b. If a DC inductive load (such as a DC relay coil) is controlled by a transistor switch, care must be taken not to exceed the breakdown voltage of the transistor when the load is switched. One of the most effective ways is to place a diode across the inductive load. Most RLC products with solid state outputs have internal zener diode protection. However external diode protection at the load is always a good design practice to limit EMI. Although the use of a snubber or varistor could be used. RLC part numbers: Snubber: SNUB0000 Varistor: ILS11500 or ILS23000 7. Care should be taken when connecting input and output devices to the instrument. When a separate input and output common is provided, they should not be mixed. Therefore a sensor common should NOT be connected to an output common. This would cause EMI on the sensitive input common, which could affect the instrument’s operation. Electrical connections are made via screw-clamp terminals located on the back of the meter. All conductors should conform to the meter’s voltage and current ratings. All cabling should conform to appropriate standards of good installation, local codes and regulations. It is recommended that the power supplied to the meter (DC or AC) be protected by a fuse or circuit breaker. Strip the wire, leaving approximately 0.3" (7.5 mm) bare lead exposed (stranded wires should be tinned with solder.) Insert the lead under the correct screw-clamp terminal and tighten until the wire is secure. (Pull wire to verify tightness.) Each terminal can accept up to one #14 AWG (2.55 mm) wire, two #18 AWG (1.02 mm), or four #20 AWG (0.61 mm). EMC INSTALLATION GUIDELINES Although Red Lion Controls Products are designed with a high degree of immunity to Electromagnetic Interference (EMI), proper installation and wiring methods must be followed to ensure compatibility in each application. The type of the electrical noise, source or coupling method into a unit may be different for various installations. Cable length, routing, and shield termination are very important and can mean the difference between a successful or troublesome installation. Listed are some EMI guidelines for a successful installation in an industrial environment. 1. A unit should be mounted in a metal enclosure, which is properly connected to protective earth. 2. Use shielded cables for all Signal and Control inputs. The shield connection should be made as short as possible. The connection point for the shield depends somewhat upon the application. Listed below are the recommended methods of connecting the shield, in order of their effectiveness. a. Connect the shield to earth ground (protective earth) at one end where the unit is mounted. b. Connect the shield to earth ground at both ends of the cable, usually when the noise source frequency is over 1 MHz. 3. Never run Signal or Control cables in the same conduit or raceway with AC power lines, conductors, feeding motors, solenoids, SCR controls, and heaters, etc. The cables should be run through metal conduit that is properly grounded. This is especially useful in applications where cable runs are long and portable two-way radios are used in close proximity or if the installation is near a commercial radio transmitter. Also, Signal or Control cables within an enclosure should be routed as far away as possible from contactors, control relays, transformers, and other noisy components. 4. Long cable runs are more susceptible to EMI pickup than short cable runs. 5. In extremely high EMI environments, the use of external EMI suppression devices such as Ferrite Suppression Cores for signal and control cables is effective. The following EMI suppression devices (or equivalent) are recommended: Visit RLC’s web site at http://www.redlion.net/emi for more information on EMI guidelines, Safety and CE issues as they relate to Red Lion Controls products. 4 4.1 POWER WIRING 4.2 USER INPUT WIRING +9 to +28 VDC: +VDC Power Common: -VDC INP COMM USR Sinking Logic PWR COMMON INP B The user input of the meter is internally pulled up to +9 to +28 V with 10 K resistance. The input is active when it is pulled low. INP A Connect external switching device between the User Input terminal and Input Common. USR + } INP COMM INP B - INP A USR INP COMM DC Power +9-28 VDC +9-28 VDC PWR COMMON 4.3 INPUT WIRING CAUTION: Power input common is NOT isolated from user input common. In order to preserve the safety of the meter application, the power input common must be suitably isolated from hazardous live earth referenced voltage; or input common must be at protective earth ground potential. If not, hazardous voltage may be present at the User Inputs and User Input Common terminals. Appropriate considerations must then be given to the potential of the user input common with respect to earth ground; and the common of the plug-in cards with respect to input common. NPN O.C. INP A Input A INP B INP COMM INP A INP B Input A USR INP COMM INP A INP B Switch or Isolated Transistor; Current Sink USR Interfacing With TTL Input A USR INP COMM Current Sinking Output +5 V COMMON PWR COMMON +9-28 VDC PWR COMMON PWR COMMON +9-28 VDC +9-28 VDC 4.4 SETPOINT (OUTPUT) WIRING SETPOINT RELAY PLUG-IN CARD ELECTRICAL CONNECTIONS COM N.O. N.C. COM N.O. N.C. 4.5 SERIAL COMMUNICATION WIRING SERIAL COMMUNICATIONS PLUG-IN CARD N/C B- A+ COMM N/C N/C N/C TX COMM COMM RX N/C RJ11 CONNECTOR PIN OUTS 6 5 4 3 2 1 6 5 4 3 2 1 RS485 5 RS232 5.0 Reviewing Front Buttons the Display and 1 SEL KEY RST DISPLAY MODE OPERATION ENTERING PROGRAM MODE PROGRAMMING MODE OPERATION SEL Select display (timer or cycle counter) Press and hold for 2 seconds to activate Store selected parameter and index to next parameter RST Reset value(s) per Front Panel Reset setting Advances through the program menu Increments selected parameter value or selection OPERATING MODE DISPLAY DESIGNATORS “t” - To the left of the display is the timer value. “C” - To the left of the display is the cycle counter value. “1” - To the upper left of the display indicates the setpoint status. If display scroll is enabled, the display will toggle automatically every four seconds between the timer and cycle counter values. 6.0 Programming the Meter OVERVIEW DISPLAY MODE PROGRAMMING MENU SEL NO Pro Timer Input Parameters Cycle Counter Parameters Display and Front Panel Key Parameters Setpoint Output Parameters Serial Setup Parameters RST SEL 1-INPUt SEL SEL 2-Count 3-dSPLAY PROGRAMMING MODE ENTRY (SEL KEY) SEL 4-SEtPt SEL 5-SEriAL PROGRAMMING MODE EXIT (SEL KEY) It is recommended all programming changes be made off line, or before installation. The meter normally operates in the Display Mode. No parameters can be programmed in this mode. The Programming Mode is entered by pressing and holding the SEL key. If it is not accessible, then it is locked by either a security code, or a hardware lock (See Module 3). The Programming Mode is exited by pressing the SEL key with   displayed. This will commit any stored parameter changes to memory and return the meter to the Display Mode. (If power loss occurs before returning to the Display Mode, verify recent parameter changes.) PROGRAMMING TIPS MODULE ENTRY (SEL & RST KEYS) It is recommended to start with Module 1 and proceed through each module in sequence. When programming is complete, it is recommended to record the parameter programming and lock out parameter programming with the user input or programming security code. The Programming Menu is organized into separate modules. These modules group together parameters that are related in function. The display will alternate between  and the present module. The RST key is used to select the desired module. The displayed module is entered by pressing the SEL key. FACTORY SETTINGS MODULE MENU (SEL KEY) Factory Settings may be completely restored in Module 3. This is useful when encountering programming problems. Pressing the RST key on power-up will load the factory settings and display rESEt. This allows operation in the event of a memory failure or corrupted data. Each module has a separate module menu (which is shown at the start of each module discussion). The SEL key is pressed to advance to a particular parameter to be changed, without changing the programming of preceding parameters. After completing a module, the display will return to  . Programming may continue by accessing additional modules. ALTERNATING SELECTION DISPLAY In the explanation of the modules, the following dual display with arrows will appear. This is used to illustrate the display alternating between the parameter on top and the parameter’s Factory Setting on the bottom. In most cases, selections and values for the parameter will be listed on the right. SELECTION / VALUE ENTRY For each parameter, the display alternates between the present parameter and the selections/value for that parameter. The RST key is used to move through the selections/values for that parameter. Pressing the SEL key, stores and activates the displayed selection/value. This also advances the meter to the next parameter. For numeric values, press the RST key to access the value. The right hand most digit will begin to flash. Pressing the RST key again increments the digit by one or the user can hold the RST key and the digit will automatically scroll. The SEL key will advance to the next digit. Pressing and holding the SEL key will enter the value and move to the next parameter. Indicates Program Mode Alternating Display Parameter INPUtsOP   LEVEL Selection/Value Factory Settings are shown. 6 6.1 MODULE 1 - Timer Input Parameters (1-INPUt) PARAMETER MENU 1-INPUt SEL RANGE t-dir FILtEr INPUt OP Timer Input Operation Timer Range Timer Input Filter t-Strt Timing Direction Timer Start Value t-StOP t-FLASH Timer Stop Value Flash Timer Annunciator Pro Run P-UP RSt P-UP USEr INP USEr ASN Timer Run State At Power-up Timer Reset At Power-up User Input Function User Input Assignment TIMER INPUT FILTER TIMER RANGE  RANGE  5555555 RANGE MAXIMUM SELECTION DISPLAY SECONDS 5555555 555555.5 55555.55 5555.555 18 TIMER RANGE SELECTIONS (S DISPLAY RESOLUTION 1 SEC 9999999 999999.9 99999.99 9999.999 MINUTES NNNNNNN NNNNNN.N NNNNN.NN = SEC; 0.1 SEC 0.01 SEC 0.001 SEC 1 MIN 9999999 999999.9 99999.99 0.1 MIN 0.01 MIN N = MIN; = HR; H RANGE SELECTION d MINUTES/SECONDS NNNNN.SS NNNN.SS.S NNN.SS.SS HHHHHHH HHHHHH.H HHHHH.HH 1 HR 9999999 999999.9 99999.99 0.1 HR 0.01 SEC 1 MIN 99999.59 9999.59.9 999.59.99 0.1 MIN t-dir   UP t-Strt   0000000 HOLd-2 HOLdsrSt Time Time Stop Start t-StOP   NO Time Start Time Stop StOP VAL   0000000 YES 0000000 to 9999999 FLASH TIMER ANNUNCIATOR Time Stop Time Start INPUT A INPUT B - Timer Inhibit (Level Active) INPUT B - Timer Inhibit (Level Active) Ed9E-2, Ed-2srSt t-FLASH  Time Start INPUT A Time Start, Display Update RunsP-UP   StOP Display Update INPUT A Time Stop NO YES YES TIMER RUN STATE AT POWER-UP Edge Triggered Operation - 2 Input, with Display Hold Time Start, Display Update  Select YES to have the timer annunciator (t) flash when the timer is running. HOLd-2, HOLdsrSt Edge Triggered Operation - 2 Input INPUT B NO The Timer stops when this value is reached regardless of the signal levels on the timer inputs. Selecting YES displays a sub-menu where the Stop Value is entered in the same display format as the Timer Range selected. This stop condition is cleared when a Timer Reset occurs or another start edge is applied on the timer input. Select NO if a Stop Value is not desired. Edge Triggered Operation -1 Input Time Stop INPUT A Time Stop 9999999 Ed9E-1, Ed-1srSt Level Active (Gated) Operation Time Start to TIMER STOP VALUE For Reset Modes (rSt), the timer is reset at Time Start edge. Time Start 0000000 The Timer returns to this value whenever a Timer Reset occurs. The value is entered in the same display format as the Timer Range selected. Non-zero values are normally used for “timing down” applications, but they can also provide an offset value when timing up. This parameter determines how the Timer Input Signals affect the Run/Stop status of the Timer. Timing diagrams are shown below for level active and edge triggered (1-input or 2-input) operation. For single input modes (Input A only), Input B provides a level active Timer Inhibit function. In the Display Hold mode, the timer display value remains held and only updates when a Timer Start (Input A) or Timer Stop (Input B) edge occurs. The timer reset (rSt) operating modes are identical to the other modes in the diagrams, except the timer display value is reset at the Time Start edges. The Timer can also be stopped at a Timer Stop Value or at Setpoint output activation or deactivation. This type of Stop condition is cleared when a Timer Reset occurs, or another start edge is applied on the timer input. LEVEL, LEVsrSt dn TIMER START VALUE 1 MIN 999.23.59 Ed9E-2 Ed-2srSt UP 1 SEC 999.59.59 DAYS/HOURS/MINUTES Ed9E-1 Ed-1srSt OFF Bi-directional timing capability. Select the timing direction desired for the application. 0.01 MIN HOURS/MINUTES/SECONDS ON TIMING DIRECTION TIMER INPUT OPERATION LEVEL LEVsrSt ON Provides a 50 msec software debounce for the Timer Inputs (A and B). Select 0.01 HR INPUtsOP   LEVEL  0.1 SEC HOURS/MINUTES ddd.HH.NN  1 SEC 99999.59 9999.59.9 999.59.99 HHHHH.NN HHHH.NN.N HHH.NN.NN FILtEr ON when using relays or switch contacts as a signal source. MAXIMUM DISPLAY DISPLAY RESOLUTION HHH.NN.SS HOURS = DAY)) StOP SAVE Determines the Run/Stop state of the Timer at Power-up. This parameter does not apply to LEVEL Input Operation. StOP - Timer Stopped at power-up, regardless of prior Run/Stop state SAVE - Timer assumes the Run/Stop state it was in prior to power-down Time Stop, Display Update INPUT B 7 TIMER RESET AT POWER-UP RStsP-UP   YES NO USER INPUT FUNCTION (Cont’d) DISPLAY MODE YES The Timer can be programmed to Reset at each meter power-up. USErsINP   NO DISPLAY MODE Inhibit Inhibit timing or counting for the selected value(s). d-LEVEL Display Intensity Level (Edge Triggered) Increase intensity one level for each activation. (backlight version only) Print Request Serial transmit of the active parameters selected in the Print Options menu (Module 5). Prnt-r5t Print and Reset Same as Print Request followed by a momentary reset of the selected value(s). r5t OUt Reset Output Edge triggered deactivation of the Setpoint Output. DESCRIPTION NO Pro Loc d-SELECt rESEt No Function d-HOLd Display Hold Freeze display for the selected value(s) while allowing time or counts to accumulate internally. Hold and Reset Edge triggered reset of the selected value(s) after storing the time or count. HOLd-rSt Inhibit Print USER INPUT FUNCTION DESCRIPTION User Input disabled. See Programming Mode Access chart (Module 3). Toggle display with each activation. Level active reset of the selected value(s). Program Mode Lock-out Display Select (Edge triggered) Maintained Reset USER INPUT ASSIGNMENT t-VALUE C-VALUE both t-C USErsASN   t-VALVE The User Input Assignment only applies if the cycle counter is enabled and a selection of reset, display hold, hold and reset, inhibit, or print and reset is selected in the User Input Function menu. 6.2 MODULE 2 - Cycle Counter Parameters (2-Count) 2-Count SEL Cnt Enb Cnt Src Cycle Counter Enable Cycle Counter Count Source Cnt dir Cycle Counter Counting Direction CYCLE COUNTER ENABLE CntsEnb   YES NO Cnt Strt RSt P-UP Cycle Counter Start Value Cycle Counter Reset At Power-up CYCLE COUNTER COUNTING DIRECTION YES Cntsdir   UP CYCLE COUNTER COUNT SOURCE INPUtsb USrsINP t-rESEt UP dn Bi-directional counting capability. Select the counting direction desired for the application. When set to NO, the remaining Cycle Counter parameters are not accessible. CntsSrc   t-rESEt Pro PARAMETER MENU CYCLE COUNTER START VALUE CntsStrt   000000 OUt-ON OUt-OFF 000000 to 999999 The Cycle Counter returns to this value whenever a Counter Reset occurs. Non-zero values are normally used for “down counting” applications, but can also provide an offset value when counting up. This parameter selects the source from which the Cycle Counter derives counts. The Timer Reset (t-rESEt) selection generates a count when either a manual or automatic timer reset occurs (See Module 4 for programming Automatic Reset). The Input B (INPUt b) selection generates a count each time Input B is activated. This selection overrides the timer inhibit function of Input B, when the timer is programmed for Level or Edge-1 operating mode (See Module 1 for Timer Input Operating Modes). The User Input (USr1NP) selection generates a count each time the User Input is activated. When selected as the count source, the User Input can still be set to perform a User Function described in Module 1. In this case, the Cycle Counter will count the number of times the selected User Function occurred. The Output ON/OFF selections generate a count when the Setpoint output either activates or deactivates. These selections will only generate counts when an optional Setpoint module is installed. CYCLE COUNTER RESET AT POWER-UP RStsP-UP   NO NO YES The Cycle Counter can be programmed to Reset at each meter power-up. 8 6.3 MODULE 3 - Display and Front Panel Key Parameters (3-dSPLAY) PARAMETER MENU 3-dSPLAY Pro Backlight Unit Only SEL SEL Enb Front Panel Display Select RSt Enb d-ScroLL Front Panel Reset Enable Display Scroll Enable d-COLOr d-LEVEL Display Intensity Level Display Color   yES yES ProsCodE NO  The yES selection allows the SEL button to toggle between the timer and cycle counter displays.   YES yES NO NO t-VALUE C-VALUE Programming Security Code Load Factory Default Settings  000 0 to 999 The Security Code determines the programming mode and the accessibility of programming parameters. This code can be used along with the Program Mode Lock-out (Pro Loc) in the User Input Function parameter (Module 1). Two programming modes are available. Full Programming mode allows all parameters to be viewed and modified. Quick Programming mode permits only the Setpoint values and Timer Stop value to be modified, but allows direct access to these values without having to enter Full Programming mode. Programming a Security Code other than 0, requires this code to be entered at the Pro CodE prompt in order to access Full Programming mode. Depending on the code value, Quick Programming may be accessible before the Pro CodE prompt appears (see chart). FRONT PANEL RESET ENABLE (RST) RStsEnb FACt SEt PROGRAMMING SECURITY CODE FRONT PANEL DISPLAY SELECT ENABLE (SEL) SELsEnb Pro CodE both t-C dSPLAy The yES selection allows the RST button to reset the selected value(s). The shaded selections only appear if the cycle counter is enabled. USER INPUT USER INPUT SECURITY MODE WHEN “SEL” FUNCTION STATE CODE KEY IS PRESSED 0 DISPLAY SCROLL ENABLE d-ScroLL   NO not yES ______ Pro Loc NO The yES selection allows the display to automatically scroll between the timer and cycle counter values. The scroll rate is about every 4 seconds. DISPLAY COLOR (BACKLIGHT UNIT ONLY) d-COLOr  Active Not Active  rEd rEd  5 1 to 1-99 Quick Programming 100-999 Pro CodE prompt With correct code entry at Pro CodE prompt * 1-99 Programming Lock Quick Programming No Access No Access 100-999 Pro CodE prompt With correct code entry at Pro CodE prompt * 0-999 Full Programming Immediate Access LOAD FACTORY DEFAULT SETTINGS DISPLAY INTENSITY LEVEL (BACKLIGHT UNIT ONLY)  Immediate Access After Quick Programming with correct code entry at Pro CodE prompt * * Entering Code 222 allows access regardless of security code. 6rn Enter the desired display color, red or green. This parameter is active for backlight units only. d-LEVEL Full Programming 0 Pro Loc FULL PROGRAMMING MODE ACCESS FACtsSEt   MO NO yES The yES selection will return the meter to the factory default settings. The meter will display rESEt and then return to Pro, at which time all settings have been changed. Pressing the RST key on power-up will load the factory settings and display rESEt. This allows operation in the event of a memory failure or corrupted data. 5 Enter the desired Display Intensity Level (1-5). The display will actively dim or brighten as levels are changed. This parameter is active for backlight units only. 9 6.4 MODULE 4 - Setpoint Output Parameters (4-SEtPt) PARAMETER MENU 4-SEtPt SEL SPt ASN SPt ACt Setpoint Assignment Setpoint Output Action SPt ON SPt OFF SPt tOUt Setpoint On Setpoint Off Setpoint Output Time-out StOP-t The Setpoint Output Parameters are only active when the optional relay module is installed in the meter. Some parameters will not appear depending on the Setpoint Assignment and Setpoint Output Action selected. t-VALUE SPt rSt SPtstOUt   00.01.00 00.00.01 C-VALUE LAtCH t-OUt ON-OFF LAtCH t-OUt ON-OFF   VALUE SPtsOFF   VALUE  NO NO Out-ON Out-OFF AUtOsrSt   NO NO Out-ON Out-OFF SETPOINT OUTPUT RESET WITH DISPLAY RESET SPtsrSt to   YES NO YES Select YES to have the Setpoint Output deactivate (reset) when the Setpoint Assigned display resets. Reset can occur by the RST button or the User Input, if programmed for that function. Select  if the Setpoint output should not reset when the display resets. 9999999 CHANGE DISPLAY COLOR w/SETPOINT OUTPUT STATE Ch-COLOr  SETPOINT OFF  NO VALUE t-Strt t-StOP This parameter enables the backlight CUB5T to switch the display color when the Setpoint output activates. When the output deactivates, the display color will revert to the normal operating mode color. This parameter is only active for the backlight version. The Setpoint Off parameter only appears if the Setpoint Action is set to On-Off Output mode (ON-OFF). In this mode, the Setpoint OFF parameter determines when the Setpoint Output will deactivate. The output can be programmed to deactivate at a Setpoint Off Value or can be set to deactivate when the Timer starts (t-Strt) or stops (t-StOP). Selecting VALUE displays a sub-menu where the Setpoint Off Value is entered. If the Setpoint is assigned to the Timer, the value is entered in the same display format as the selected Timer Range. SPOF VAL   0000200  Automatically resets the Setpoint Assigned display value when the Setpoint Output activates (OUt-ON) or deactivates (OUt-OFF). Select NO if the output should not cause a display reset. VALUE t-Strt t-StOP 0000000 StOP-t TIMER/COUNTER AUTO RESET This parameter determines when the Setpoint output will activate. The output can activate at a programmed Setpoint Value or can be set to activate when the Timer starts (t-Strt) or stops (t-StOP). Selecting VALUE displays a sub-menu where the Setpoint Value is entered. If the Setpoint is assigned to the Timer, the value is entered in the same display format as the selected Timer Range. SPt VAL   0000100 99.59.99 OUTPUT DEACTIVATES When Time or Count At Manual Reset Latched Output Mode = Setpoint On value (if SPt rSt = YES) When Time or Count After Setpoint Timed Output Mode = Setpoint On value Output Time-Out When Time or Count When Time or Count On-Off Output Mode = Setpoint On value = Setpoint Off value SETPOINT ON SPtsON to Stops the Timer when the Setpoint output activates (OUt-ON) or deactivates (OUt-OFF). Select NO if the output should not affect the Timer Run/Stop status. The Timer Stop condition is cleared when a Timer Reset occurs, or a Time Start edge is applied on the Timer input. This parameter selects the action of the Setpoint output as shown below. OUTPUT ACTIVATES Setpoint Output Power-up State STOP TIMER SETPOINT OUTPUT ACTION SPT ACTION DESCRIPTION SPt P-UP This parameter is only active if the Setpoint Action is set to Timed Output mode (). Enter the time duration the Setpoint Output will remain ON once it is activated. This value is always entered in minutes, seconds, and hundredths of seconds format. The maximum value is 99 minutes 59.99 seconds. Select the display for Setpoint assignment. SPtsACt   LAtCH Ch-COLOr Setpoint Change Display Timer/Counter Output Reset Color with Auto Reset with Display Reset Setpoint Output State SETPOINT OUTPUT TIME-OUT SETPOINT ASSIGNMENT SPtsASN   t-VALUE AUtO rSt Stop Timer Pro Backlight Unit Only 0000000 to NO YES SETPOINT OUTPUT POWER-UP STATE SPtsP-UP   OFF OFF ON SAVE SAVE will restore the output to the same state it was at before the meter was powered down. ON will activate the output at power up. OFF will deactivate the output at power up. This parameter is not active when the Setpoint Action is selected for timed output mode. 9999999 10 6.5 MODULE 5 - Serial Communications Parameters (5-SEriAL) PARAMETER MENU 5-SEriAL Pro SEL PAritY bAUd dAtA Baud Rate Data Bit Parity Bit Addr Abbr Prnt OPt COPY Meter Address Abbreviated Printing Print Options Copy Program Settings Module 5 is the programming module for the Serial Communications Parameters. These parameters are used to match the serial settings of the CUB5T with those of the host computer or other serial device. The Serial Setup Parameters are only accessible when an optional RS232 or RS485 serial communications module is installed in the meter. ABBREVIATED PRINTING Abbr  This section replaces the bulletin shipped with the RS232 and RS485 serial communications plug-in cards. Discard the separate bulletin when using those serial plug-in cards with the CUB5T.   9600 300 600 1200 2400 4800 9600  7-bit Prnt OPt   NO 8-bit 7-bit PARITY BIT   NO Odd EVEN DISPLAY Odd t-VALUE C-VALUE t-Strt t-StOP Cnt Strt SPt ON SPt OFF SPt tOUt This parameter only appears when the Data Bit parameter is set to a 7-bit data word length. Set the parity bit to match that of the other serial equipment on the serial link. The meter ignores parity when receiving data and sets the parity bit for outgoing data. If parity is set to NO, an additional stop bit is used to force the frame size to 10 bits. METER ADDRESS Addr   0 to NO YES This parameter selects the meter values transmitted in response to a Print Request. A print request is also referred to as a block print because more than one parameter can be sent to a printer or computer as a block. Selecting YES displays a sublist for choosing the meter parameters to appear in the print block. All active parameters entered as YES in the sublist will be transmitted during a block print. Parameters entered as NO will not be sent. The “Print All” (Prnt ALL) option selects all meter values for transmitting (YES), without having to individually select each parameter in the sublist. Note: Inactive parameters will not be sent regardless of the print option setting. For example, the Cycle Counter and Cycle Counter Start values will only be sent when the Cycle Counter is enabled. If disabled, these parameters are inactive and will not be transmitted. Likewise, the Setpoint parameters will not be sent unless an optional setpoint card is installed in the meter. Select either 7- or 8-bit data word length. Set the word length to match the other serial communications equipment on the serial link. PAritY NO PRINT OPTIONS DATA BIT  YES 19200 38400 Set the baud rate to match that of other serial communications equipment. Normally, the baud rate is set to the highest value that all of the serial communications equipment is capable of transmitting and receiving. dAtA NO This parameter determines the formatting of data transmitted from the meter in response to a Transmit Value command or a Block Print Request. Select NO for a full print transmission, consisting of the meter address, mnemonics, and parameter data. Select YES for abbreviated print transmissions, consisting of the parameter data only. This setting is applied to all the parameters selected in the PRINT OPTIONS. (Note: If the meter address is 0, the address will not be sent during a full transmission.) BAUD RATE bAUd  99 00 Enter the serial node address. With a single unit, an address is not needed and a value of zero can be used (RS232 applications). Otherwise, with multiple bussed units, a unique address number must be assigned to each meter. The node address applies specifically to RS485 applications. 11 DESCRIPTION Timer Cycle Counter Timer Start Timer Stop Counter Start Setpoint ON Setpoint OFF Setpoint Time-out FACTORY SETTING YES NO NO NO NO NO NO NO MNEMONIC TMR CNT TST TSP CST SPT SOF STO Sending Serial Commands and Data Register Identification Chart When sending commands to the meter, a string containing at least one command character must be constructed. A command string consists of a command character, a value identifier, numerical data (if writing data to the meter) followed by a command terminator character, * or $. Command Chart Command Description N T V R P Notes Address a specific meter. Must be followed by one or two digit node address. Not required when node address = 0. Read a register from the meter. Must be Transmit Value (read) followed by a register ID character. Write to register of the meter. Must be Value Change (write) followed by a register ID character and numeric data. Reset a value or the output. Must be followed Reset by a register ID character Block Print Request Initiates a block print output. Registers in the (read) print block are selected in Print Options. Node (meter) Address Specifier Applicable Commands Transmit Details (T and V) TMR T, V, R 7 digit, per Timer Range Cycle Counter CNT T, V, R 6 digit C Timer Start TST T, V 7 digit, per Timer Range D Timer Stop TSP T, V 7 digit, per Timer Range E Counter Start CST T, V 6 digit F Setpoint ON (Reset Output) SPT T, V, R per Setpoint Assignment, same as Timer or Counter G Setpoint OFF SOF T, V per Setpoint Assignment, same as Timer or Counter H Setpoint Time-out STO T, V 6 digit, mm.ss.ss format ID Value Description MNEMONIC A Timer B Command String Examples: Command String Construction 1. Node address = 17, Write 350 to the Setpoint On value String: N17VF350$ The command string must be constructed in a specific sequence. The meter does not respond with an error message to illegal commands. The following procedure details construction of a command string: 2. Node address = 5, Read Timer value, response time of 50 msec min String: N5TA* 1. The first 2 or 3 characters consist of the Node Address Specifier (N) followed by a 1 or 2 character node address number. The node address number of the meter is programmable. If the node address is 0, this command and the node address itself may be omitted. This is the only command that may be used in conjunction with other commands. 2. After the optional address specifier, the next character is the command character. 3. The next character is the register ID. This identifies the register that the command affects. The P command does not require a register ID character. It prints all the active selections chosen in the Print Options menu parameter. 4. If constructing a value change command (writing data), the numeric data is sent next. 5. All command strings must be terminated with the string termination characters * or $. The meter does not begin processing the command string until this character is received. See timing diagram figure for differences in meter response time when using the * and $ terminating characters. 3. Node address = 0, Reset Setpoint output String: RF* 4. Node address = 31, Request a Block Print Output, response time of 2 msec min String: N31P$ Transmitting Data to the Meter Numeric data sent to the meter must be limited to Transmit Details listed in the Register Identification Chart. Leading zeros are ignored. The meter ignores any decimal point and conforms the number to the appropriate display format. (For example: The Timer range is set for tenths of a second and 25 is written to the Timer Start register. The value of the register is now 2.5 seconds. In this case, write a value of 250 to equal 25.0 seconds). Note: Since the meter does not issue a reply to value change commands, follow with a transmit value command for readback verification. Receiving Data From The Meter data within bytes 9 to 18 is right-aligned with leading spaces for any unfilled positions. The end of the response string is terminated with a and . After the last line of a block print, an extra , and are added to provide separation between the print blocks. Full Field Transmission Abbreviated Transmission Data is transmitted from the meter in response to either a transmit command (T), a block print request command (P) or a User Input print request. The response from the meter is either a full field transmission or an abbreviated transmission, depending on the selection chosen in Module 5. Byte Description Byte 1, 2 2 byte Node Address field [00-99] 1-12 3 (Space) 4-6 3 byte Register Mnemonic field 7-18 12 byte data field; 9 bytes for number and three bytes for decimal points Description 13 12 byte data field, 9 bytes for number and three bytes for decimal points (carriage return) 14 (line feed) 15 * (Space) 16 * (carriage return) 17 * (line feed) 19 (carriage return) 20 (line feed) 21 * (Space) * These characters only appear in the last line of a block print. 22 * (carriage return) 23 * (line feed) The abbreviated response suppresses the node address and register mnemonic, leaving only the numeric part of the response. * These characters only appear in the last line of a block print. The first two characters transmitted are the meter address. If the address assigned is 0, two spaces are substituted. A space follows the meter address field. The next three characters are the register mnemonic, as shown in the Register Identification Chart. The numeric data is transmitted next. The numeric field (bytes 7 to 18) is 12 characters long. When a display overflow exists for a requested timer or cycle counter value, an * (used as an overflow character) replaces a space in byte 7. Byte 8 is always a space. The remaining ten positions of this field consist of seven positions for the requested value with decimal points positioned for the selected timer range. The Meter Response Examples: 1. Node address = 17, full field response, Cycle Counter = 875 17 CNT 875 2. Node address = 0, full field response, Setpoint On value = 250.5 SPT 250.5 3. Node address = 0, abbreviated response, Setpoint On value= 250, last line of block print 250 12 Command Response Time At the beginning of time interval t3, the meter responds with the first character of the reply. As with t1, the time duration of t3 is dependent on the number of characters and baud rate of the channel. At the end of t3, the meter is ready to receive the next command. The meter can only receive data or transmit data at any one time (half-duplex operation). During RS232 transmissions, the meter ignores commands while transmitting data, but instead uses RXD as a busy signal. When sending commands and data to the meter, a delay must be imposed before sending another command. This allows enough time for the meter to process the command and prepare for the next command. At the start of the time interval t1, the computer program prints or writes the string to the com port, thus initiating a transmission. During t1, the command characters are under transmission and at the end of this period, the command terminating character (* or $) is received by the meter. The time duration of t1 is dependent on the number of characters and baud rate of the channel. t3 = (10 times the # of characters) / baud rate The maximum serial throughput of the meter is limited to the sum of the times t1, t2 and t3. NO REPLY FROM METER Ready t1 = (10 times the # of characters) / baud rate At the start of time interval t2, the meter starts the interpretation of the command and when complete, performs the command function. This time interval t2 varies. If no response from the meter is expected, the meter is ready to accept another command. If the meter is to reply with data, the time interval t2 is controlled by the use of the command terminating character. The ‘*’ terminating character results in a response time of 50 msec. minimum. This allows sufficient time for the release of the sending driver on the RS485 bus. Terminating the command line with ‘$’ results in a response time (t2) of 2 msec. minimum. The faster response time of this terminating character requires that sending drivers release within 2 msec. after the terminating character is received. Command String Transmission Meter Response Time t1 t2 Ready RESPONSE FROM METER Ready t1 t2 Command Terminator Received First Character of Reply t3 Ready Reply Transmission Time Timing Diagram Figure Communication Format Start Bit and Data Bits Data transmission always begins with the start bit. The start bit signals the receiving device to prepare for reception of data. One bit period later, the least significant bit of the ASCII encoded character is transmitted, followed by the remaining data bits. The receiving device then reads each bit position as they are transmitted. Data is transferred from the meter through a serial communication channel. In serial communications, the voltage is switched between a high and low level at a predetermined rate (baud rate) using ASCII encoding. The receiving device reads the voltage levels at the same intervals and then translates the switched levels back to a character. The voltage level conventions depend on the interface standard. The table lists the voltage levels for each standard. LOGIC INTERFACE STATE RS232* RS485* 1 mark (idle) TXD,RXD; -3 to -15 V a-b < -200 mV 0 space (active) TXD,RXD; +3 to +15 V a-b > +200 mV Parity Bit After the data bits, the parity bit is sent. The transmitter sets the parity bit to a zero or a one, so that the total number of ones contained in the transmission (including the parity bit) is either even or odd. This bit is used by the receiver to detect errors that may occur to an odd number of bits in the transmission. However, a single parity bit cannot detect errors that may occur to an even number of bits. Given this limitation, the parity bit is often ignored by the receiving device. The CUB5T meter ignores the parity bit of incoming data and sets the parity bit to odd, even or none (mark parity) for outgoing data. * Voltage levels at the Receiver Data is transmitted one byte at a time with a variable idle period between characters (0 to ∞). Each ASCII character is “framed” with a beginning start bit, an optional parity bit and one or more ending stop bits. The data format and baud rate must match that of other equipment in order for communication to take place. The figures list the data formats employed by the meter. Stop Bit The last character transmitted is the stop bit. The stop bit provides a single bit period pause to allow the receiver to prepare to re-synchronize to the start of a new transmission (start bit of next byte). The receiver then continuously looks for the occurrence of the start bit. If 7 data bits and no parity is selected, then 2 stop bits are sent from the meter. Character Frame Figure 13 This page intentionally left blank. 14 NO 15 RST 5-SEriAL RST 4-SEtPt RST 3-dSPLAY RST 2-Count RST 1-INPUt RST Pro Cnt Enb Timer Range RANGE Exit Programming End SEL SEL SEL Baud Rate bAUd Setpoint Assignment SPt ASN Front Panel Display Select SEL Enb Cycle Counter Enable SEL SEL SEL Press and hold SEL key to enter Programming Mode. Data Bit dAtA Setpoint Output Action SPt ACt Front Panel Reset Enable RSt Enb Cycle Counter Count Source Cnt Src Timer Input Operation INPUt OP Parity Bit PAritY Setpoint On SPt ON Display Scroll Enable d-ScroLL t-Strt Cycle Counter Reset at Power-up Meter Address Addr Setpoint Off SPt OFF Display Color d-COLOr Abbreviated Printing Abbr Setpoint Output Time-out SPt tOUt Display Intensity Level d-LEVEL Backlight Unit Only Cycle Counter Start Value Print Options Prnt OPt Stop Timer StOP-t Programming Security Code AUtO rSt Load Factory Default Settings FACt SEt Timer Run State At Power-up Run P-UP Timer/Counter Auto Reset Flash Timer Annunciator t-FLASH Pro CodE Timer Stop Value t-StOP RSt P-UP Timer Start Value Cnt Strt Timing Direction t-dir Cycle Counter Counting Direction Cnt dir Timer Input Filter FILtEr Setpoint Output Reset with Display Reset SPt rSt Timer Reset At Power-up RSt P-UP Change Display Color with Setpoint Output State Ch-COLOr Backlight Unit Only User Input Function USEr INP Setpoint Output Power-up State SPt P-UP User Input Assignment USEr ASN CUB5T PROGRAMMING QUICK OVERVIEW LIMITED WARRANTY (a) Red Lion Controls Inc., Sixnet Inc., N-Tron Corporation, or Blue Tree Wireless Data, Inc. (the “Company”) warrants that all Products shall be free from defects in material and workmanship under normal use for the period of time provided in “Statement of Warranty Periods” (available at www.redlion.net) current at the time of shipment of the Products (the “Warranty Period”). EXCEPT FOR THE ABOVE-STATED WARRANTY, COMPANY MAKES NO WARRANTY WHATSOEVER WITH RESPECT TO THE PRODUCTS, INCLUDING ANY (A) WARRANTY OF MERCHANTABILITY; (B) WARRANTY OF FITNESS FOR A PARTICULAR PURPOSE; OR (C) WARRANTY AGAINST INFRINGEMENT OF INTELLECTUAL PROPERTY RIGHTS OF A THIRD PARTY; WHETHER EXPRESS OR IMPLIED BY LAW, COURSE OF DEALING, COURSE OF PERFORMANCE, USAGE OF TRADE OR OTHERWISE. Customer shall be responsible for determining that a Product is suitable for Customer’s use and that such use complies with any applicable local, state or federal law. (b) The Company shall not be liable for a breach of the warranty set forth in paragraph (a) if (i) the defect is a result of Customer’s failure to store, install, commission or maintain the Product according to specifications; (ii) Customer alters or repairs such Product without the prior written consent of Company. (c) Subject to paragraph (b), with respect to any such Product during the Warranty Period, Company shall, in its sole discretion, either (i) repair or replace the Product; or (ii) credit or refund the price of Product provided that, if Company so requests, Customer shall, at Company’s expense, return such Product to Company. (d) THE REMEDIES SET FORTH IN PARAGRAPH (c) SHALL BE THE CUSTOMER’S SOLE AND EXCLUSIVE REMEDY AND COMPANY’S ENTIRE LIABILITY FOR ANY BREACH OF THE LIMITED WARRANTY SET FORTH IN PARAGRAPH (a). Red Lion Controls Headquarters 20 Willow Springs Circle York PA 17406 Tel +1 (717) 767-6511 Fax +1 (717) 764-0839 Red Lion Controls Europe Softwareweg 9 NL - 3821 BN Amersfoort Tel +31 (0) 334 723 225 Fax +31 (0) 334 893 793 Red Lion Controls India 201-B, 2nd Floor, Park Centra Opp 32 Mile Stone, Sector-30 Gurgaon-122002 Haryana, India Tel +91 984 487 0503 Red Lion Controls China Unit 1102, XinMao Plaza Building 9, No.99 Tianzhou Road ShangHai, P.R. China 200223 Tel +86 21 6113 3688 Fax +86 21 6113 3683
CUB5TB00 价格&库存
很抱歉,暂时无法提供与“CUB5TB00”相匹配的价格&库存,您可以联系我们找货
CUB5TB00
    • 1+2148.73907
    • 5+2088.57834
    • 25+2025.91828
    库存:1
