99793712
99793712
    CROUZET(高诺斯)
    COUNTER7CHAR115VPANELMOUNT
99793712 数据手册
Electromechanical hour counters ➜ DIN rail mounting hour counters - CHMDR ■ ■ ■ ■ ■ ■ ■ ■ Width equivalent to 2 modules Capacity 100.000 hrs (99.999.99 hrs) Extended temperature range: -10 ➞ +70°C (a version) DIN rail mounted according to EN 50022 IP65 on panel Highly resistant to shocks and impacts Colour: RAL 7035 grey Screw terminals Part numbers Type CHMDR Operating frequency (Hz) 50 50 50 c Voltages 24 Va 115 Va 230 Va 10 ➞ 27 Vc Accessories General characteristics General characteristics Counting capacity Reset to zero Read accuracy Height digits (mm) Colour of hour numbers Colour of decimal digits Accuracy Counting input mode Degree of protection front face Tolerance Temperature limits use (°C) 99.999.99 Not included 1/100 h 3.5 White on a black background Black on a white background Va /Vc : < 0.01% (24 hrs) Addition IP 65 face avant Va ± 10% Va : -10 ➞ +70 Vc : -10 ➞ +50 (sans condensation) -40 ➞ +80 CE Screw terminals Va : approx. 2.5 VA Vc : approx. 1 W 1G (10-500 Hz) 2 000 Va 50 Hz 60 Temperature limits stored (°C) Certifications Connection Consumption Vibration resistance Test voltage for AC models Weight (g) Dimensions (mm) CHMDR 1 45 h 60 44 90 6 36 Code 99793710 99793712 99793714 99793810 2
99793712 价格&库存
很抱歉,暂时无法提供与“99793712”相匹配的价格&库存,您可以联系我们找货
