700TN001048150D10023
    CURTISINSTRUMENTSINC.(科蒂斯)
    COUNTER LCD 6 CHAR 100-230V PNL
700TN001048150D10023 数据手册
7 0 0 S E R I E S S O L I D S TAT E HOUR METERS & COUNTERS Applications HOURS 88888.8 1 10 A wide variety of industrial and commercial applications, including scheduled maintenance, warranty and leasing – for medical equipment, transport and industrial vehicles and other industrial equipment. Features D E S C R I P T I O N 48±0.3 (1.89) The Curtis 700 Series are highly reliable solid state hour meters and counters that offer an unprecedented combination of patented technology, performance, reliability and value. MODEL 700: 2-Wire Hour Meter, displays only when powered. Available in AC/DC. MODEL 701: 3-Wire Hour Meter, has a provision for continuous display. Available in AC/DC and DC-only. MODEL 703: Pulse Counter. Available in AC/DC and DC-only. • All-8’s LCD function test: each digit displays an eight for one second after power-up. • Attractive 6-digit LCD 5mm or 7mm high digits (7mm with optional backlighting) are much easier to read than electro-mechanical meters, which have only 3mm high digits. • Silent operation – no moving parts. Eliminates annoying gear and motor noise. • Exceptional reliability due to nonvolatile memory (EEPROM) which retains data for 25+ years. • Wide voltage ranges, for example, one unit can be powered from 75 to 270 VAC anywhere between 48 and 440 Hz – ideal for distribution and worldwide markets without having to stock multiple model types. • Electrical reset (optional). • Available in ten case styles – all fit in standard hour meter/counter cutouts. • Multiple mountings available – Metal U-bracket, “U” clamp/stud (D, Q, R and S cases), flange mount with hardware (F, G, J cases), or mounting clip (G, L, Y, Z, cases). • Backlit units allow external illumination control, i.e., on/off or dimmer (12VDC only). • Flashing hourglass icon indicates when the hour meter is accumulating time. • Memory will arm only when power has been applied for five seconds (with no loss of time or counts). WA R R A N T Y • Low power consumption. Two-year replacement warranty. • UL and CE recognized. 700 Series Specifications Case Style Bezel Shape Lens Material Case Material IP Rating Front/Rear Termination UL5/CE D Rectangular Acrylic ABS 65/50 3/16" Spade Yes F Hexagonal Acrylic ABS 65/65 1/4" Spade Yes Suggested Panel Cutout mm 45.0 x 22.2 (1.77 x 0.87) 36.8 x 24.1 (1.45 x 0.95) G Hexagonal Acrylic ABS 65/651 Packard (2 pin) 2 Yes 36.8 x 24.1 (1.45 x 0.95) J Hexagonal Acrylic ABS 65/651 Packard (4 pin) 3 Yes 36.8 x 24.1 (1.45 x 0.95) L Rectangular Polycarbonate Polycarbonate 65/40 Molex 4 Yes 36.8 x 24.1 (1.45 x 0.95) Q Round Glass Polycarbonate 65/506 1/4" Spade Yes ø52 (ø2-1/16) R (5mm display) Round Glass Polycarbonate 65/506 3/16" Spade Yes ø52 (ø2-1/16) R (7mm display) Round Glass Polycarbonate 65/50 1/4" Spade Yes ø52 (ø2-1/16) S Square Glass ABS 52/50 1/4" Spade Yes 45.0 x 45.0 (1.77 x 1.77) Y Rectangular Acrylic ABS 65/651 Packard (4 pin) 3 Yes 36.8 x 24.1 (1.45 x 0.95) Z Rectangular Acrylic ABS 65/65 1/4" Spade Yes 36.8 x 24.1 (1.45 x 0.95) Display 6 digit LCD, 5 or 7mm high Range & Resolution Hour meters: Counters: 99,999.9 hours 999,999 counts Accuracy Hour meters: Counters: 0.1% ±1 count Humidity 95%, non-condensing at 38°C Operating Temperature -40°C to +85°C Storage Temperature -50°C to +85°C Mechanical Shock SAE J 1378, 55g Mechanical Vibration SAE J 1378, 20g Operating Frequency (AC powered units) 48 to 440 Hz Memory Main power must be applied for 5 seconds to arm memory (with no loss of time/counts). EEPROM, data retained for 25+ years without power. Current Consumption (Power Terminals) 0.5mA max. @ 5VDC (0512D models) 0.8mA max. @ 12VDC (1248D models) 1.0mA max. @ 120VAC 2.0mA max. @ 230VAC Input Signal (DC-only) Counters (703 only): 500 Hz. max., 50% duty cycle (1ms low, min., between consecutive highs) Input Signal (AC/DC) Hour meters (701 only): Counters (703 only): Power must be applied for 0.5s, min., to accumulate time. 1 Hz. max., 50% duty cycle (500ms low, min., between consecutive highs) Reset 5ms min. at operating voltage. Main power must be applied for a minimum of 250ms prior to reset signal. NOTES: 1. Mating connector must be installed. 2. Equivalent to Delphi-Packard connector P/N 12162000 2-pin. 3. Equivalent to Delphi-Packard connector P/N 15336035 4-pin. 4. Equivalent to Molex connector P/N 43045-0412. 5. UL files AU1841 and E45175. 6. R(5mm) and Q housings also available in a 65/65 version (see model encodement). 700 Series Model Encodement 700 MODEL R Case Style R Resetability 001 Additional Feature O Logo* 0512D0612A Operating Voltage 700 = (2-wire hour meter, AC/DC only) D R = Electrically resettable 001 = 5mm, non-backlit display (Standard) 0512D = 5-12VDC nom., 4.75-15VDC abs. N = Nonresettable 091 = Epoxy filled unit (moisture resistant, Q, R (5mm), cases only) O= Curtis Logo 701 = (3-wire hour meter, AC/DC or DC-only 703 = (3-wire counter, AC/DC or DC-only) F G1 J L2 N= No Logo R Y 0512D0612A = 5-12VDC nom., 4.75-15VDC abs. 6-12VAC nom., 5-15VAC abs. 48150D100230A = 48-150VDC nom., 36-185VDC abs. 100-230VAC nom., 75-270VAC abs. 701 = 7mm, non-backlit display (R or S case only) S 48150D = 48-150VDC nom., 36-185VDC abs. 1248D2060A = 12-48VDC nom., 9-60VDC abs. 20-60VAC nom., 15-75VAC abs. 601 = 7mm, backlit display (R or S case only) Q 1248D = 12-48VDC nom., 9-60VDC abs. Z 1. Only model offered: 700GN001N1248D2060A 2. Only models offered: 700LN001N1248D2060A, 700LN001N48150D100230A and 701LN001N1248D * Custom logos are available Backlight available on 7mm R or S cases only. 700 Series Wiring Guide Case Style D, F, J,Q, R (5mm), Y & Z G L R (7mm), S V+ VI R L NC Pin 1 Pin 2 Pin 3 Pin 4 Pin 5 Pin 6 V+ V+ V+ V+ VVVV- I N/A I R R N/A N/A I N/A N/A N/A L N/A N/A N/A N/A Operating voltage Common (ground) Enable (Optional, use operating voltage to power this pin to record elapsed time (701) or increment count (703).) Reset (Optional, supply with operating voltage when unit is to be reset to 0.) Lighting control (Optional, 9-15VDC absolute only, regardless of operating voltage.) No connection 700 Series Dimensions: mm D Case: 32.0 1 HOURS 2 22.1 4 88888.8 3 44.9 14.3 48.3 4.20 1 10 24.3 700 Series Dimensions: mm F Case: 28.8 53.2 MAX. 18.0 44.5 3.2 35.5 1.5 1 2 HOURS 31.2 MAX. 23.8 3 22.7 1/10 4 Ø3.8 (2X) 36.7 G Case: 3.60 2.0 32.6 14.9 53.3 36.6 HOURS 2 23.7 1 23.0 31.4 1/10 44.8 4.0 DIA 2 PLACES J Case: 35.8 36.5 53.2 MAX. 18.0 44.5 3.2 35.5 1.5 HOURS 31.2 MAX. 23.8 1 2 3 4 22.7 1/ 10 Ø 3.8 (2X) 36.7 700 Series Dimensions: mm cont. L Case: 3 2 HOURS 88888.8 24.0 4 27.5 1 1/10 36.6 14.0 2.80 40.6 21.0 36.5 Y Case: 40.6 18.0 36.7 4.7 HOURS 23.8 1 2 3 4 27.5 1/10 28.8 Z Case: 40.6 18.0 36.7 1 4.7 2 HOURS 23.8 3 4 27.5 1/10 700 Series Dimensions: mm cont. Q Case: QUARTZ 1 2 HOURS 4 1 10 88888.8 48.3 3 58.4 8.90 13.2 28.6 R (5mm) Case: QUARTZ 1 2 HOURS 88888.8 51.7 4 1 10 3 58.4 8.90 13.2 28.6 R (7mm) Case: 9.0 1 2 QUARTZ HOURS 5 6 51.5 DIA. 1/10 3 4 28.0 45.0 58.4 700 Series Dimensions: mm S Case: 1 2 HOURS 5 44.5 SQUARE 6 48.0 1/10 3 4 48.0 4.0 28.0 44.0 700 Series Hardware Case Style F G, J D, Q, R, S Shipping Style Carton Bulk Carton Bulk Steel Slot Screws 2 2 2 2 Steel Hex Nuts 2 Plastic Thumb Nuts 2 Lock Washers 2 Faston Terminals 4 2 2 2 Carton 2 Bulk Carton Z Bulk Carton Bulk 2 2 2 2 2 4 4 Plastic Bracket 1 Metal U Bracket Note: Y 1 1 1 1 1 L case does not require hardware. Accessories Curtis P/N Description 17607303 Plastic mounting bracket for F, G, J, Y & Z models 17607800 100 mounting clips for F, G, J, Y & Z case 12237003 Dash Mounting Bracket, L-shape 13210001 Meter Guard (1 box of 10 meter guards) R & Q models 13515801 3-Hole Mounting Kit, for Ø2.53” mounting holes 13515905 3-Hole Mounting Kit, for Ø2.44” mounting holes 15336002 Gasket for F, G and J cases 15336003 Gasket for R (5mm) case 15336005 Gasket for Q and R (7mm) cases is a registered trademark of Curtis Instruments, Inc. Specifications subject to change without notice ©2002 Curtis Instruments, Inc. 50011 REV I 06/02
700TN001048150D10023 价格&库存
很抱歉,暂时无法提供与“700TN001048150D10023”相匹配的价格&库存,您可以联系我们找货
