ENC8B000
ENC8B000
    REDLIONCONTROLS(美国红狮)
    ENCLOSURE CUB4/CUB5 CHASSIS MNT
ENC8B000 数据手册
Bulletin No. ENC8/8B-F Drawing No. LP0389 Released 04/13 Tel +1 (717) 767-6511 Fax +1 (717) 764-0839 www.redlion.net MODEL ENC8 - NEMA 4 ENCLOSURES FOR CUB4, CUB5, DT8 & DT9 UNITS ENC8A & ENC8B - PLASTIC ENCLOSURES ENC8A DIMENSIONS In inches (mm) 3.04 (77.2) 5.12 (130.0) 3.14 (79.8) DESCRIPTION These enclosures are designed for applications requiring a water resistant instrument enclosure. The enclosures are fabricated of polycarbonate and are designed to withstand NEMA 4X/IP65 wash-down applications. The enclosures must be drilled to accept conduit fittings or other types of wiring connectors. The enclosures can be used free-standing, or securely fastened to a mounting surface. ENC8B DIMENSIONS In inches (mm) 4.80 (121.9) ORDERING INFORMATION MODEL NO. DESCRIPTION PART NUMBER ENC8A Plastic Enclosure for single units ENC8A000 ENC8B Plastic Enclosure for units with an MLPS1 attached ENC8B000 For More information on Pricing, Enclosures & Panel Mount Kits, refer to the RLC Catalog or contact your local RLC Distributor. ENC8A INSTALLATION 9. Connect the necessary wires to the unit for the application desired. 10. Assemble the enclosure with the screws provided. Alternately tighten each screw to ensure uniform gasket pressure. It is recommended to wire the unit before mounting it in the enclosure to ensure good electrical connections. The following steps outline the most common sequence for installing a unit without an MLPS1 attached. 1. Determine the location of the conduit fitting and drill the necessary hole. Install the fitting and bring the wiring into the enclosure. 2. Slide the panel gasket over the rear of the unit to the back of the bezel. 3. Assemble nut fastener and mounting screw onto both sides of the mounting clip. The tip of the screw should not project from the hole in mounting clip. 4. Install the unit through the opening in the front of the lid until the bezel flange contacts the panel. 5. Slide the mounting plate over the rear of the unit until it is against the inside front of the enclosure. 6. Slide the mounting clip over the rear of the unit until the mounting clip is against the inside of the enclosure. The mounting clip has latching features which engage into mating features on the unit’s housing. Note: It is necessary to hold the unit in place when sliding UNIT the mounting clip into position. GASKET 7. Alternately tighten each screw to ensure uniform gasket pressure. Visually inspect the front panel gasket. The gasket should be compressed to about 75 to 80% of its LATCHING original thickness (Recommended torque is 28 to 36 FEATURE in-oz.). If not, gradually turn mounting screws to further compress the gasket. 8. If the gasket is not adequately compressed, and the mounting screws can no longer be turned, loosen the mounting screws and check that the mounting clip is latched as close as possible to the inside of enclosure. Repeat the procedure for tightening the screws. 3.77 (95.8) 4.72 (119.9) ENCLOSURE, REAR NUT FASTENER MOUNTING PLATE ENCLOSURE, FRONT MOUNTING SCREW MOUNTING CLIP UNIT 1 CONTROL LINES ENC8B w/ MLPS1 Installation 8. Alternately tighten each screw to ensure uniform gasket pressure. Visually Installing a unit with an MLPS1 attached requires some planning. It is inspect the front panel gasket. The gasket should be compressed to about 75 recommended that the unit with the MLPS1 attached be temporarily installed to 80% of its original thickness (Recommended torque is 28 to 36 in-oz.). If in the enclosure to determine the best location for the conduit fitting to avoid not, gradually turn mounting screws to further compress the gasket. interference with the MLPS1. 9. If the gasket is not adequately compressed, and the mounting screws can no 1. Determine the location of the conduit fitting and drill the necessary hole. longer be turned, loosen the mounting Install the fitting and bring the wiring into the enclosure. screws and check that the mounting clip 2. Slide the panel gasket over the rear of the unit to the back of the bezel. ENCLOSURE, is latched as close as possible to the 3. Remove the common and V+ screw terminals from the rear of the unit (save REAR inside of enclosure. Repeat the for later use) and replace them with the stand-offs (supplied with the procedure for tightening the screws. MLPS1). 4. Assemble nut fastener and mounting screw onto both sides of the mounting clip. The tip of the screw should not project from the hole in mounting clip. 5. Install the unit through the opening in the front of the lid until the bezel flange contacts the panel mounted gasket. 6. Slide the mounting plate over the rear of the unit until it is against the inside front of the enclosure. 7. Slide the mounting clip over the rear of the unit until the mounting clip is AC POWER against the inside of the enclosure. The mounting clip has latching features FOR MLPS which engage into mating features on the unit’s housing. SCREW TERMINALS FROM REAR OF UNIT Note: It is necessary to hold the unit in place when sliding the mounting clip into position. SENSOR EXCITATION (OPTIONAL) NUT FASTENER SQUARE WASHER MOUNTING SCREW ENCLOSURE, FRONT MLPS HEX STAND-OFF ( 2 ) UNIT GASKET MOUNTING CLIP LATCHING FEATURE 10. Mount the MLPS1 and optional sensor wires needed, to the stand-offs using the screw terminals from the unit with the supplied square washers. 11. Connect AC power to the terminal block of the MLPS1. 12. After all electrical connections have been made, assemble the enclosure with the screws provided. Alternately tighten each screw to ensure uniform gasket pressure. MOUNTING PLATE CONTROL UNIT LINES ENC8 - STEEL ENCLOSURE DIMENSIONS In inches (mm) 4.50 (114.3) 3.50 (88.9) 4.00 (101.6) 4.15 (105.4) DESCRIPTION This enclosure is designed for use with the CUB4, CUB5, DT8 & DT9 units. The enclosures are large enough to accommodate a Micro-line Power Supply (MLPS1) attached to the unit. These rugged enclosures are fabricated of formed steel with all seams welded to withstand NEMA 4/IP65 wash-down applications. The kits are coated with a durable black polyurethane finish. The holes for conduit fittings or other types of wiring connectors can be drilled through the removable rear access panel, or through the enclosure itself. The enclosures can be free standing or securely fastened to a mounting surface with the brackets and hardware found in the mounting kit (provided with the enclosure). The brackets also allow the enclosure to be raised and/or tilted from the mounting surface in order to achieve the most favorable operating position. Provided are four self-stick foot pads that can be applied to the bottom of the enclosure to protect the mounting surface. The foot pads are particularly useful for free standing installations. ORDERING INFORMATION MODEL NO DESCRIPTION PART NUMBER ENC8 NEMA 4/IP65 ENCLOSURE ENC80000 For More information on Pricing, Enclosures & Panel Mount Kits, refer to the RLC Catalog or contact your local RLC Distributor. 2 ENC8 INSTALLATION 10. If the gasket is not adequately compressed, and the mounting screws can no longer be turned, loosen the mounting screws and check that the ACCESS mounting clip is latched as close as possible to PANEL the inside of the enclosure. Repeat the procedure for tightening the screws. SCREW 11. Attach the rear access panel to the enclosure (8 PLACES) with the eight screws provided. It is recommended to wire the unit before mounting it in the enclosure to ensure good electrical connections. The following steps outline the most common sequence for installing a unit without an MLPS1 attached. 1. Determine the location of the conduit fitting and drill the necessary hole. 2. Apply adhesive side of panel gasket to rear enclosure opening. DO NOT APPLY THE ADHESIVE SIDE OF THE GASKET TO THE ACCESS PANEL. 3. Slide the panel gasket over the rear of the unit to the back of the bezel. 4. Assemble nut fastener and mounting screw onto both sides of the mounting clip. The tip of the screw should not project from the hole in mounting clip. 5. Route the wire to be connected to the unit from the conduit fitting through the mounting clip, and then through the rear of the enclosure and out the front. 6. Connect the necessary wires to the unit for the application desired. 7. Install the unit through the opening in the front of the enclosure until the bezel flange contacts the panel. UNIT 8. Slide the mounting clip over the rear of the unit until the GASKET mounting clip is against the inside of the enclosure. The mounting clip has latching features which engage into LATCHING FEATURE mating features on the unit’s housing. Note: It is necessary to hold the unit in place when sliding the mounting clip into position. 9. Alternately tighten each screw to ensure uniform gasket pressure. Visually inspect the front panel gasket. The gasket should be compressed to about 75 to 80% of its original thickness (Recommended torque is 28 to 36 in-oz.). If not, gradually turn mounting screws to further compress the gasket. NUT FASTENER PANEL GASKET CONDUIT FITTING LATCHING FEATURE ENCLOSURE MOUNTING SCREW CONTROL LINES 12. Alternately tighten each screw to ensure uniform gasket pressure. Visually inspect the sponge rubber gasket. The gasket should be compressed to about 75 to 80% of its original thickness. UNIT ENC8 w/ MLPS1 Installation Installing a unit with an MLPS1 attached requires some planning. It is recommended that the unit with the MLPS1 attached be temporarily installed in the enclosure to determine the best location for the conduit fitting to avoid interference with the MLPS1. 1. Mark the location of the conduit fitting and drill the necessary hole. 2. Apply adhesive side of panel gasket to rear enclosure opening. 10. Alternately tighten each screw to ensure uniform gasket pressure. Visually inspect the front panel gasket. The gasket should be compressed to about 75 to 80% of its original thickness (Recommended torque is 28 to 36 in-oz.). If not, gradually turn mounting screws to further compress the gasket. 11. If the gasket is not adequately compressed, and the mounting screws can no longer be turned, loosen the mounting screws and check that the mounting clip is latched as close as possible to the inside of enclosure. Repeat the procedure for tightening the screws. 12. Connect AC power to the terminal block of the MLPS1. DO NOT APPLY THE ADHESIVE SIDE OF THE GASKET TO THE ACCESS PANEL. 3. Slide the panel gasket over the rear of the unit to the back of the bezel. 4. Remove the common and V+ screw terminals from the rear of the unit (save for later use) and replace them with the hex drive stand-offs (supplied with the MLPS1). 5. Assemble nut fastener and mounting screw onto both sides of the mounting clip. The tip of the screw should not project from the hole in mounting clip. 6. Route the wire to be connected to the unit from the conduit fitting through the mounting clip, and then through the rear of the enclosure and out the front. 7. Connect the necessary wires to the unit for the application desired. SCREW TERMINALS 8. Install the unit through the opening in the front of the enclosure until the FROM REAR OF UNIT bezel flange contacts the panel mounted gasket. 9. Slide the mounting clip over the rear of the unit until the mounting clip is against the inside of the enclosure. The mounting clip has latching features which engage into mating features on the unit’s housing. NUT Note: It is necessary to hold the unit in FASTENER PANEL place when sliding the GASKET MOUNTING ENCLOSURE mounting clip into SCREW position. SCREW (8 PLACES) CONDUIT FITTING REAR ACCESS PANEL AC POWER FOR MLPS SENSOR EXCITATION (OPTIONAL) ACCESS PANEL SQUARE WASHER MLPS HEX STAND-OFF (2 TYP) UNIT GASKET TO ENSURE ADEQUATE ROOM TO ROUTE WIRES, CONDUIT SHOULD BE CONNECTED IN SHADED AREA MOUNTING CLIP LATCHING FEATURE 13. Mount the MLPS1 and optional sensor wires needed, to the stand-offs using the screw terminals from the unit with the supplied square washers. 14. After all electrical connections have been made, attach the rear access panel to the enclosure with the eight screws provided. 15. Alternately tighten each screw to ensure uniform gasket pressure. Visually inspect the sponge rubber gasket. The gasket should be compressed to about 75 to 80% of its original thickness. CONTROL LINES UNIT 3 MOUNTING THE ENCLOSURE 1. Self-stick foot pads may be applied to the features on the bottom of the enclosure to protect the mounting surface. 2. To securely mount the enclosure, attach the adjustable mounting brackets to the enclosure using the plastic washers and screws. Mounting brackets may be attached to the top or bottom of the enclosure. 3. Secure the adjustable mounting brackets to mounting location with the screws provided. TYPICAL MOUNT WITH WATERTIGHT CABLE ENTERING THROUGH BACK COVER ENCLOSURE GASKET ACCESS PANEL SCREW (8 PLACES) UNIT WITH OR WITHOUT POWER SUPPLY PLASTIC WASHER FOOT PADS (4 PLACES) PLASTIC WASHER SCREW FOOT PADS (4 PLACES) ADJUSTABLE MOUNTING BRACKET (BOTH SIDES) LIMITED WARRANTY The Company warrants the products it manufactures against defects in materials and workmanship for a period limited to two years from the date of shipment, provided the products have been stored, handled, installed, and used under proper conditions. The Company’s liability under this limited warranty shall extend only to the repair or replacement of a defective product, at The Company’s option. The Company disclaims all liability for any affirmation, promise or representation with respect to the products. The customer agrees to hold Red Lion Controls harmless from, defend, and indemnify RLC against damages, claims, and expenses arising out of subsequent sales of RLC products or products containing components manufactured by RLC and based upon personal injuries, deaths, property damage, lost profits, and other matters which Buyer, its employees, or sub-contractors are or may be to any extent liable, including without limitation penalties imposed by the Consumer Product Safety Act (P.L. 92-573) and liability imposed upon any person pursuant to the Magnuson-Moss Warranty Act (P.L. 93-637), as now in effect or as amended hereafter. No warranties expressed or implied are created with respect to The Company’s products except those expressly contained herein. The Customer acknowledges the disclaimers and limitations contained herein and relies on no other warranties or affirmations. Red Lion Controls Headquarters 20 Willow Springs Circle York PA 17406 Tel +1 (717) 767-6511 Fax +1 (717) 764-0839 Red Lion Controls Europe Softwareweg 9 NL - 3821 BN Amersfoort Tel +31 (0) 334 723 225 Fax +31 (0) 334 893 793 Red Lion Controls India 201-B, 2nd Floor, Park Centra Opp 32 Mile Stone, Sector-30 Gurgaon-122002 Haryana, India Tel +91 984 487 0503 Red Lion Controls China Unit 302, XinAn Plaza Building 13, No.99 Tianzhou Road ShangHai, P.R. China 200223 Tel +86 21 6113 3688 Fax +86 21 6113 3683
ENC8B000 价格&库存
很抱歉,暂时无法提供与“ENC8B000”相匹配的价格&库存,您可以联系我们找货
