MPAXR020
MPAXR020
    REDLIONCONTROLS(美国红狮)
    Module
    OPTIONCARDCOUNT/RATELPAX
MPAXR020 数据手册
MPAX PERSONALITY MODULE SELECTOR GUIDE FOR LPAX Our la rge displays have various input options, determined by the installation of a MPAX personality module. These MPAX modules are based on standard PAX panel meters, and use the same data sheet as the PAX meter for specifications and wiring. About the MPAX Input Modules The MPAX Module serves as the input to the LPAX Display. There are several different modules to cover a variety of inputs. The MPAX module provides input scaling which allows the LPAX to display most any engineering unit. Once the MPAX is inserted into the LPAX, the unit has the same functions and capabilities of our PAX Series Intelligent Panel Meters. A full set of PAX programming instructions will be included with the MPAX Module. Note: The MPAX provides the operating power for the LPAX, therefore you must select either the AC or DC MPAX corre sponding with your application and available power. Selecting Your Display Components To build a complete display unit, you will need an LPAX and an MPAX Input Module. The LPAX is only a display and will not operate without an MPAX Module. Please use the following chart to identify the appropriate MPAX Module (including supply power) and LPAX Display that will satisfy your application. MPAX Modules for LPAX5 (Analog units) MPAX MODULES SIGNAL TYPE INPUT RANGES * LPAX DISPLAYS 85-250 VAC 11 to 36 VDC/ 24 VAC Universal DC Inpu ts DC Voltage 200 m V, 2 V, 20 V, 300 V DC Current 200 µA, 2 mA, 20 mA, 200 mA, 2 Amp Resi stance 100 ohm, 1000 ohm, 10 K ohm MPAXD000 MPAXD010 LPAX0500 Process Inputs 0-20 mA or 0-10 V DC MPAXP000 MPAXP010 LPAX0500 Temperature Inputs Thermocouples -T, E, J, K, R, S, B, N, C, or Custom Scaling RTDs - 100 ohm Pt (platinum) 385/392, 120 ohm Nickel 672, or 10 ohm Copper 427 MPAXT000 MPAXT010 LPAX0500 Strain Gage/Load Cell 24 mV or 240 mV MPAXS000 MPAXS010 LPAX0500 True RMS AC Voltage/Current AC Voltage 200 m V, 2 V, 20 V, 300 V AC Current 200 uA, 2 mA, 20 mA, 200 mA, 5 Amp MPAXH000 N/A LPAX0500 *For detailed Module specifications, see corresponding PAX literature. (i.e. For MPAXD specifications, see the PAXD literature) MPAX modules for LPAX5 units work with Crimson. Clicking on any blue text in the above table will download the appropriate PAX panel meter data sheet for that MPAX module. MPAX Modules for LPAX6 (Digital units) MPAX MODULES* SIGNAL TYPE 85-250 VAC 11 to 36 VDC / 24 VAC OPTIONAL PLUG-IN CARD COMPATIBILITY LPAX DISPLAYS SETPOINT COMMS ANALOG REAL-TIME CLOCK Count/Rate/Serial Slave MPAXI02‚ MPAXI03‚LPAX0600 YES YES YES - Count MPAXC020 MPAXC03LPAX0600 YES - - - Rate MPAXR020 MPAXR0 LPAX0600 YES - - - Clock/Timer MPAXCK0 0†† MPAXCK1 0†† LPAXCK0 0** YES YES - YES Timer MPAXTM00†† MPAXTM10†† LPAXCK0 0** YES YES - - *For detailed module and plug-in card specifications, see corresponding PAX literature. (i.e. For MPAXI specifications, see the PAXI literature) **The LPAXCK will only operate with the Clock/ Timer MPAX input module. † MPAXI works with Crimson. †† MPAXCK00, MPAXCK10, MPAXTM00 and MPAXTM10 work with RLCPro. Clicking on any blue text in the above table will download the appropriate PAX panel meter data sheet for that MPAX module. MPAX Modules for LPAXDA (Dual Analog Unit) MPAX MODULES SIGNAL TYPE Dual Process Inputs INPUT RANGES 0-20 mA or 0-10 VDC * 85-250 VAC 11 to 36 VDC/ 24 VAC MPAXDP00 MPAXDP10 LPAX DISPLAY LPAXDA00 *For detailed Module specifications, see corresponding PAX literature. (i.e. For MPAXDP specifications, see the PAXDP literature) MPAX modules for LPAXDA units work with Crimson. Clicking on any blue text in the above table will download the appropriate PAX panel meter data sheet for that MPAX module.
MPAXR020 价格&库存
很抱歉,暂时无法提供与“MPAXR020”相匹配的价格&库存,您可以联系我们找货
