26546846
26546846
    CROUZET(高诺斯)
    Adapter Plate Panel Mount, Square 55mm x 55mm Outside Dim
26546846 数据手册
Electromechanical hour counters ➜ Hour counters 48 X 48 - CHM48 ■ ■ ■ ■ ■ AC: capacity 100.000 hrs (99.999.99 hrs) DC: capacity 1.000.000 hrs (999.999.99 hrs) Operation indicator Panel mounted DIN rail mounted with connector base (accessory part number: 26546845) ■ IP52 ■ Highly resistant to shocks and impacts ■ Excellent visibility due to the large digit size Part numbers Type CHM48 Operating frequency (Hz) 50 50 50 50 50 60 60 60 60 60 c c c Voltages 20 ➞ 30 Va 42 ➞ 48 Va 100 ➞ 130 Va 360 ➞ 440 Va 187 ➞ 264 Va 100 ➞ 130 Va 187 ➞ 264 Va 360 ➞ 440 Va 20 ➞ 30 Va 42 ➞ 48 Va 10 ➞ 30 Vc 36 ➞ 80 Vc 100 ➞ 130 Vc Code 99772710 99772711 99772712 99772713 99772714 99772715 99772716 99772717 99772718 99772719 99772810 99772811 99772812 Accessories Description Adaptor for 72 x 72 mm cut-out Adaptor for 55 x 55 mm cut-out DIN rail adaptor Code 26546842 26546846 26546845 General characteristics General characteristics Counting capacity Reset to zero Read accuracy Height digits (mm) Colour of hour numbers Colour of decimal digits Accuracy Counting input mode Operation indicator Degree of protection front face Mounting Temperature limits use (°C) Temperature limits stored (°C) Certifications Connections (panel mounted version) Connections (DIN rail mounted version) Connection capacity Consumption Vibration resistance Test voltage for AC models Weight (g) 60 Va : 99 999.99 Vc : 999.999.99 Not included 1/100 h 4 White on a black background Red on a black background Va : frequency + 30 ms Vc : < 0.003% (24 hrs) Addition Va : rotating red lines Vc : 1/100 hr 1 digit in 36 s IP52 Any -15 ➞ +50 -40 ➞ +80 UL (pending) Screw terminals - 6.35 mm Faston connectors Screw terminals with accessory 26 546 845 2.5 mm2 Vc : 10 ➞ 30 approx. 500 mW/100 ➞ 130 approx. 750 mW/ Va 50 Hz: 20 ➞ 30 approx. 0.3 VA/42 ➞ 48 approx. 0.25 VA/100 ➞ 130 approx. 0.6 VA/187 ➞ 264 approx. 1.2 VA/360 ➞ 440 approx. 1.65 VA 50 m/s2 (10-500 Hz) IEC 068-2-6 2 000 Va 50 Hz 50 www.crouzet.com Dimensions (mm) Panel mounted Panel cut-out 26546842 - Adaptor for 72 x 72 mm cut-out 7,4 48 50 72 45,4 Ø 45 +0.6 0 h 45 max.9 +0.6 7 45 0 1 28 1 Screw terminals 26546846 - Adaptor for 55 x 55 mm cut-out 26546845 - DIN rail mounted 0 5 61,5 32 48,1 0 38 48 6 ±0,1 45,4 +0,2 55 -0,2 7,4 ±0,1 19 48,5 www.crouzet.com 41,1 61
26546846 价格&库存
很抱歉,暂时无法提供与“26546846”相匹配的价格&库存,您可以联系我们找货
    库存:7
