26546805
26546805
    CROUZET(高诺斯)
    BEZEL 99761 SERIES SQUARE 45MM
26546805 数据手册
COUNT/RATE COUNT/RATE 99761 SERIES ELAPSED TIME INDICATOR UL-E47668 • • • • • CSA-LR44080 7 Digit .15˝ High Display Front Panel Mounting Low Cost Capacity: 99999.99 Hours DIN-Sized (48 x 48mm) with Bezel GENERAL FEATURES: ACCESSORIES: The 99761 Elapse Time Indicators are AC synchronous Hour Meters which are ruggedly constructed true time mechanisms for recording the “ON” time of electrical equipment and machinery. The instrument is connected in parallel with the equipment being monitored to determine maintenance intervals, routine and component life. • DIN-Rail Adapter • Square Bezel SPECIFICATIONS: Display . . . . . . . . . . . . . . . . . 7 Digit .15˝ high Capacity . . . . . . . . . . . . . . . . 99999.99 Hours Input Power . . . . . . . . . . . . . 24 VAC, 110 VAC, 220 VAC +10%, -15% 60 Hz (50 Hz Special Order) Vibration Resistance . . . . . . 5 G (10-2000 Hz) Digit Color . . . . . . . . . . . . . . Hours: white on black . . . . . . . . . . . . . . . . . . . . . . Decimals: red on black Body Material . . . . . . . . . . . . Noryl Weight . . . . . . . . . . . . . . . . . 2 oz. (60g) Order: 26546803 Order: 26546805 MOUNTING: DIMENSIONS: / 1.772 (45 ) +.004 +.0 +.110 +.0 1.89 (48) 2.17 (55) 0000 00 1.89 (48) 1.97 O (50) h ø1.968 (50 ) +.004 +.0 +.110 +.0 CH 48 G 1.30 (33) 1.57 (40) 1.17 (45) NOTE: Round cutout is only possible if square bezel accessory is used. ORDERING INFORMATION: 99761 SERIES SERIES 99761 715 INPUT POWER INPUT POWER 716 : 220 VAC 60Hz 715 : 115 VAC 60Hz 718 : 24 VAC 60Hz Products and specifications subject to change without notice. Consult factory for application assistance. 204 Airline Drive, Suite 300, Coppell, Texas 75019 / Tel: (800) 677-5311 / FAX: (800) 677-3865 / www.crouzet-usa.com 7-10
26546805
PDF文档中提到的物料型号为99761系列,是Crouzet品牌的计时器。
以下是关于该物料的详细信息:
- 器件简介:99761系列是AC同步小时计,用于记录电气设备和机械的“开启”时间,以确定维护间隔、常规和组件寿命。
- 引脚分配:文档中未提供引脚分配信息。
- 参数特性: - 显示:7位数字,0.15英寸高 - 容量:99999.99小时 - 输入电源:24 VAC, 110 VAC, 220 VAC ±10%,-15% 60 Hz(50Hz特殊订单) - 抗振性:5G(10-2000 Hz) - 数字颜色:小时:白色在黑色上;小数点:红色在黑色上 - 机身材料:Noryl - 重量:2盎司(60克) - 功能详解:该计时器与被监控的设备并联连接,用于确定维护间隔。
- 应用信息:用于记录电气设备和机械的运行时间,以确定维护周期。
- 封装信息:DIN尺寸(48 x 48mm)带边框,提供DIN导轨适配器。
请注意,产品和规格如有更改,恕不另行通知。
如需应用协助,请咨询工厂。
26546805 价格&库存
很抱歉,暂时无法提供与“26546805”相匹配的价格&库存,您可以联系我们找货
  • 19+54.42161
库存:24
