CHEMTRONICS
Technical Data Sheet
TDS # QbE
QbE® Cleaning System
TYPICAL PRODUCT DATA AND
PHYSICAL PROPERTIES
PRODUCT DESCRIPTION
QbE® is the patented Precision Wipe
System for cleaning fiber optic end-faces.
It is a self-contained cleaning tool that can
be used “dry” or “wet.” The QbE® is
convenient and economical for use in field
or OEM applications.
The Complete Fiber Optic Cleaning
System
Platen side of box provides surface
for cleaning
Effective “Wet” or “Dry” cleaning
Provides an ideal Cleaning System
for field or OEM applications
Convenient Size - Portable system
easily fits in tool cases and is handy
to use on work benches
Heavy Duty Lint-Free wiping
material tough-enough to remove
buffer-gel; soft enough for all end
face cleaning
Wipe material won’t shred or tear
TYPICAL APPLICATIONS
QbE® wipes are used in Fiber Optic and
Telecommunications applications for:
• End-Face Connector Cleaning
• Splice Preparation
• Buffer Gel Removal
QbE® wipes are 100% noncontaminating
material. These wipes have high
absorbency and contamination entrapment
capacity, as well as high wet strength.
Excellent solvent resistance
Excellent particle entrapment
High absorbency capacity and rate
Very low solvent extractables
High wet strength
COMPATIBILITY
QbE® wipes are compatible with most
common solvents such as alcohols,
hydrocarbons and chlorinated solvents.
The wipes are also generally compatible
with dilute or weak acids.
TECHNICAL AND APPLICATION
ASSISTANCE
ITW Chemtronics provides a technical
hotline to answer your technical and
application related questions. The toll free
number is: 1-800-TECH-401.
Visit us at
www.combinationcleaning.com, or
www.chemtronics.com
AVAILABILITY
QbE® Wipes3" x 3" 200/Box
USAGE INSTRUCTIONS
“Dry” Cleaning with the QbE®
1. Pull one QbE Wipe over the fiber-safe
foam platen.
2. Hold the end face at a 90 degree
perpendicular to the platen.
3. Draw the end face lightly over the platen in a
smooth linear motion - do not press too hard.
4. Do not retrace your cleaning procedure in the
same area.
5. Do not use a figure-eight motion; do not use
a “twist & turn” motion.
6. Check your work with a fiber scope or
measuring device.
“Wet” Cleaning with the QbE
ith the QbE
1. Lightly “spot” the QbE wipe on the platen
with Electro-Wash PX Fiber Optic Cleaner.
2. Draw the end-face from the solvent wetted
area to the dry area.
3. Check your work with a fiber scope or
measuring device.
For Splice Preparation
1. Lightly moisten QbE® wipe and gently
wipe away fiber contaminants.
2. Lightly dampen a 38540ESD swab,
remove soil from V-grooves on fusion
splicer.
Buffer Gel Removal
1.
2.
3.
4.
Buffer Gel Removal
Pull three single QbE® Wipers out of the
container.
Spray a small amount of Electro-Wash
PX Fiber Optic Cleaner into the folded
wipers.
Pull the cable through the first wiper and
discard.
Repeat until the cable “squeaks” clean.
MANUFACTURED BY:
ITW CHEMTRONICS®
8125 Cobb Center Drive
Kennesaw, GA 30152
1-770-424-4888
REV. B (09/05)
Chemtronics, Electro-Wash® and QbE® are
registered trademarks of ITW Chemtronics. All
rights reserved.
CombinationCleaning is a trademark of ITW
Chemtronics. All rights reserved
NOTE: This information is believed to be
accurate. It is intended for professional end users
having the skills to evaluate and use the data
properly. ITW Chemtronics® does not guarantee
the accuracy of the data and assumes no liability
in connection with damages incurred while using
it.
DISTRIBUTED BY:
很抱歉,暂时无法提供与“QBE2”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+301.11610
- 5+292.07689
- 10+283.31885
