CHEMTRONICS
Technical Data Sheet
TDS # pQbE
pQbE Pocket Cleaning Platform
PRODUCT DESCRIPTION
pQbE® is the patented Precision Wipe System for
cleaning fiber optic end-faces. It is a selfcontained cleanin tool that is best used wet (with
solvent) but can be used dry for light applications.
The pQbE® is convenient and economical for use
in field or OEM applications. Its compound
cleaning platen surfaces facilitates cleaning of the
end-face, chamfer and ferrule. The wipe material
is a proven 55% cellulose/45% polyester fabric
specially processed to impart softness and extra
absorbency.
Compound platen surface cleans all endface geometries: SC, LC, FC, APC,
MT and FTTH
Effective dry; very effective wet
Provides an ideal cleaning system for
Convenient Size - Portable system easily
fits into tool cases or pockets.
Heavy Duty Lint-Free wiping material
tough-enough to remove buffer-gel;
soft enough for all end face cleaning
Wipe material won’t shred or tear
Clear, tough waterproof box protects
wipes from contamination and shows
remaining wipe count.
Clip-on lanyard ensures convenient
access
TYPICAL APPLICATIONS
pQbE® wipes are used in Fiber Optic and
Telecommunications applications for:
• Complete end-face cleaning for all end-face
types
• Splice Preparation
• Buffer Gel Removal
TYPICAL PRODUCT DATA AND
PHYSICAL PROPERTIES
pQbE® wipes are 100% noncontaminating
material. These wipes have high absorbency and
contamination entrapment capacity, as well as
high wet strength.
Excellent solvent resistance
Excellent particle entrapment
High absorbency capacity and rate
Very low solvent extractables
High wet strength
COMPATIBILITY
pQbE® wipes are compatible with most common
solvents such as alcohols, hydrocarbons and
water-based cleaners.
TECHNICAL AND APPLICATION
ASSISTANCE
Chemtronics provides a technical hotline
to answer your technical and application
related questions. The toll free number is:
1-800-TECH-401.
Visit us at
www.combinationcleaning.com, or
www.chemtronics.com
AVAILABILITY
pQbE® Wipes
1.375" x 3”
(3.6 cm x 7.6 cm),
200 wipes/box
USAGE INSTRUCTIONS
“Dry” Cleaning with the pQbE®
1. Pull one QbE®-2 Wipe over the fiber-safe
foam platen.
2. Hold the end face at a 90 degree
perpendicular to the platen.
3. Draw the end face lightly over the platen in a
smooth linear motion - do not press too hard.
4. Do not retrace your cleaning procedure in the
same area.
5. Do not use a figure-eight motion; do not use
a “twist & turn” motion.
6. Check your work with a fiber scope or
measuring device.
“Wet” Cleaning with the pQbE®
1. Lightly “spot” the pQbE® wipe on the platen
with Electro-Wash PX Fiber Optic Cleaner,
orwith the Fiberwash™ or MX pen.
2. Draw the end-face from the solvent wetted
area to the dry area.
3. Check your work with a fiber scope or
measuring device.
For Splice Preparation
1. Lightly moisten pQbE® wipe and gently
wipe away fiber contaminants.
2. Lightly dampen a 38540ESD swab,
remove soil from V-grooves on fusion
splicer.
Buffer Gel Removal
1. Pull three single pQbE® Wipers out of the
container.
2. Spray a small amount of Electro-Wash PX
Fiber Optic Cleaner or MX into the folded
wipers.
3. Pull the cable through the first wiper and
discard.
4. Repeat until the cable “squeaks” clean.
CHEMTRONICS
8125 Cobb Center Drive
Kennesaw, GA 30152
1-770-424-4888
REV. A (05/14)
Chemtronics, Electro-Wash® and QbE® are
registered trademarks of Chemtronics. All rights
reserved.
CombinationCleaning and Fiberwash™ are
trademarks of Chemtronics. All rights reserved
NOTE: This information is believed to be
accurate. It is intended for professional end users
having the skills to evaluate and use the data
properly. Chemtronics does not guarantee the
accuracy of the data and assumes no liability in
connection with damages incurred while using it.
DISTRIBUTED BY:
很抱歉,暂时无法提供与“PQBE”相匹配的价格&库存,您可以联系我们找货
