TM
Technical Data Sheet
Rev. E (8/18)
Page 1 of 3
QbE® Cleaning System
Product# QbE, QbE-R, QbE-2,
Pocket QbE
Product Description
The QbE Cleaning Platforms are the patented
Precision Wipe System for cleaning fiber optic endfaces. They are self-contained cleaning tools that can
be used wet-to-dry for the most thorough end face
cleaning possible. The QbE is convenient and
economical for use in field or OEM applications.
Complete fiber optic cleaning system – no refills to
buy or investment in expensive mechanisms to
maintain
Effective wet-to-dry Combination Cleaning™ - for
cleaner, use Fiber-Wash MX pen for tough soils,
Fiber-Wash AQ pen for eco-friendly cleaner, and
Fiber-Wash NF pen for fast drying nonflammable
cleaner.
Provides the ideal cleaning surface – The QbE
cleaning platen is perfect for outside plant or OEM
application
Convenient size – portable cleaning system easily
fits on work benches
Heavy duty lint-free wiping material – tough
enough to remove buffer-gel; soft enough for all
end-face cleaning. Won’t shred or tear
Patented - U. S Patent Number 6,865,770 and
foreign patents
Typical Applications
QbE wipes are used in Fiber Optic and
Telecommunications applications for:
End-face connector cleaning
Splice preparation
Buffer gel removal
Typical Product Data and Physical Properties
QbE wipes are 100% noncontaminating material. These
wipes have high absorbency and contamination
entrapment capacity, as well as high wet strength.
Excellent solvent resistance
Excellent particle entrapment
High absorbency capacity and rate
Very low solvent extractables
High wet strength
Compatibility
QbE wipes are compatible with most common
solvents such as alcohols, hydrocarbons and
chlorinated solvents. The wipes are also generally
compatible with dilute or weak acids.
1-770-424-4888 • www.chemtronics.com
TM
Rev. E (8/18)
Page 2 of 3
Product# QbE, QbE-R, QbE-2, Pocket QbE
Availability
3" x 3" wipes, with 200 wipes per box and a
flat cleaning platen
For connectors without alignment pins
Up to 800 cleaning per platform
QbE
QbE-R Cleaning Platform
3" x 3" wipes, 200/Box
raised/ridged cleaning platform
Cleans all FTTx connector geometries, including
SC/LC, MT-Type, OptiFit, and e2000 by cleaning
the entire connector
QbE-R
QbE-2 Cleaning Platform
1.375" x 3" wipes, with 200 wipes per box and a
Up to 400 cleaning per platform
Pocket QbE Cleaning Platform
QbE-2
Pocket QbE
8125 Cobb Center Drive • Kennesaw, GA 30152
TM
Rev. E (8/18)
Page 3 of 3
Usage Instructions
Combination Cleaning with the QbE
Pull one QbE Wipe over the fiber-safe foam
platen.
Hold the end face at a 90 degree perpendicular
to the platen.
Draw the end face lightly from the solvent wetted
area to the dry area over the platen, using a
smooth linear motion - do not press too hard.
Do not retrace your cleaning procedure in the
same area.
Do not use a figure-eight motion; do not use a
“twist & turn” motion.
Check your work with a fiber scope or measuring
device.
Wet
Dry
Combination Cleaning Process
For Splice Preparation
Lightly moisten QbE wipe and gently wipe away
fiber contaminants.
Lightly dampen a 38540ESD swab, remove soil
from V-grooves on fusion splicer.
Buffer Gel Removal
Pull three single QbE Wipers out of the container.
Spray a small amount of Electro-Wash PX Fiber
Optic Cleaner into the folded wipers.
Pull the cable through the first wiper and discard.
Repeat until the cable “squeaks” clean.
Technical and Application Assistance
Chemtronics provides a technical hotline to answer
your technical and application related questions.
The toll free number is: 1-800-TECH-401.
Note:
This information is believed to be accurate. It is
intended for professional end users having the skills to
evaluate and use the data properly. CHEMTRONICS
does not guarantee the accuracy of the data and
assumes no liability in connection with damages
incurred while using it.
Chemtronics®, and QbE® are registered trademarks of
Chemtronics. All rights reserved. Fiber-Wash™ is a trademark
of Chemtronics. All rights reserved.
很抱歉,暂时无法提供与“QBE”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+595.112621+74.47205
- 10+543.0865910+67.96155
- 25+526.8605525+65.93103
- 50+515.9031750+64.55983
- 100+505.93864100+63.31287
