WST.OU.110.20PN
WST.OU.110.20PN
    LEMO(雷莫)
    TOOL CLEAVER FOR PRETERM FO CONT
WST.OU.110.20PN 数据手册
SMPTE & ARIB HDTV CONNECTION SYSTEM CONNECTORS, CABLES AND MEDIA CONVERTERS ® ® Precision modular connectors to suit your application Since its creation in Switzerland in 1946 the LEMO Group has been recognized as a global leader of circular Push-Pull connectors and connector solutions. Today LEMO and its affiliated companies, REDEL and COELVER, are active in more than 80 countries with the help of over 40 subsidiaries and distributors. Over 75000 connectors The modular design of the LEMO range provides over 75000 connectors from miniature ø 3 mm to ø 50 mm, capable of handling cable diameters up to 30 mm and for up to 114 contacts. This vast portfolio enables you to select the ideal connector configuration to suit almost any specific requirement in most markets, including medical devices, test and measurement instruments, machinery, audio video broadcast, telecommunications and military. LEMO’s Push-Pull Self-Latching Connection System This self-latching system is renowned worldwide for its easy and quick mating and unmating features. It provides absolute security against vibration, shock or pull on the cable, and facilitates operation in a very limited space. The LEMO self-latching system allows the connector to be mated by simply pushing the plug axially into the socket. Once firmly latched, connection cannot be broken by pulling on the cable or any other component part other than the outer release sleeve. When required, the connector is disengaged by a single axial pull on the outer release sleeve. This first disengages the latches and then withdraws the plug from the socket. UL Recognition LEMO connectors are recognized by the Underwriters Laboratories (UL). The approval of the complete system (LEMO connector, cable and your equipment) will be easier because LEMO connectors are recognized. CE marking CE marking means that the appliance or equipment bearing it complies with the protection requirements of one or several European safety directives. CE marking applies to complete products or equipment, but not to electromechanical components, such as connectors. RoHS LEMO connector specifications conforms the requirements of the RoHS directive (2011/65/EU) of the European Parliament and the latest amendments. This directive specifies the restrictions of the use of hazardous substances in electrical and electronic equipment marketed in Europe. Product safety notice & disclaimers Please read and follow all instructions specified on the last page or on our website carefully and consult all relevent national and international safety regulations for your application. Improper handling, cable assembly, or wrong use of connectors can result in hazardous situations. LEMO products and services are provided “as is.” LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. In no event shall LEMO be liable for any direct, indirect, punitive, incidental, special consequential damages, to property or life, whatsoever arising out of or connected with the use or misuse of LEMO’s products. ­2 www.lemo.com ® ® Table of Contents HDTV System Overview............................................................................................................................................................................................4 LEMO pioneered and set the standard for HDTV.........................................................................................................................................6 3K.93C series Interconnections.................................................................................................................................................................................................7 Part section showing internal components...............................................................................................................................................8 Technical characteristics.................................................................................................................................................................................8 Part number example.......................................................................................................................................................................................9 Models................................................................................................................................................................................................................ 10 Insert configurations...................................................................................................................................................................................... 12 Fibre optic contact.......................................................................................................................................................................................... 12 Accessories....................................................................................................................................................................................................... 13 Patch panel....................................................................................................................................................................................................... 15 Tooling................................................................................................................................................................................................................ 16 NORTHWIRETM HDTV cables NORTHWIRE hybrid camera cable according to SMPTE 311 and ARIB standards............................................................. 17 Hybrid HDTV fibre optic cable part number.......................................................................................................................................... 18 Cable assembly............................................................................................................................................................................................... 19 SMPTE 311M standard cable assemblies............................................................................................................................................ 22 ARIB cable standard cable assemblies.................................................................................................................................................. 22 MEERKATTM HD converter A compact solution for Sony ® SD, Grass Valley™ (Thomson ® ) SD/HD camera based systems..................................... 23 Technical characteristics.............................................................................................................................................................................. 24 List of SD or HD compatible cameras..................................................................................................................................................... 24 Local camera power...................................................................................................................................................................................... 25 Accessories....................................................................................................................................................................................................... 26 SERBALTM converter SERBAL TM - SMPTE Electrical Reconfigurable Bidirectional Alternative Link............................................................................. 27 Technical characteristics.............................................................................................................................................................................. 28 SHACKTM converter SHACKTM - SMPTE conversion device for singlemode fibre (SC, ST, FC or LC) ................................................................... 29 Technical characteristics.............................................................................................................................................................................. 30 Models................................................................................................................................................................................................................ 30 MULTISHACK 3XTM or 6XTM converter Introduction....................................................................................................................................................................................................... 31 MULTISHACK 3XTM - conversion system .............................................................................................................................................. 32 Technical characteristics.............................................................................................................................................................................. 32 MULTISHACK 6XTM - conversion system .............................................................................................................................................. 33 Technical characteristics.............................................................................................................................................................................. 33 HD Z-LINKTM fibre optic link system HD Z-LINKTM .................................................................................................................................................................................................... 34 www.lemo.com ­3 ® ® HDTV System Overview CCU SIDE Outside Broadcast Van Configuration CCU FXW PUW FMW PUW SMPTE / ARIB cable CCU SERBAL™ HD/SDI 4 way fibre cable Coax cables Local 12V source (1.5 A max) Stadium/building application CCU FXW PUW PHW SHACK™ FMW 2 x SC / 2 x ST / 2 x FC / 2 x LC CCU Singlemode cable or any commonly available duplex cable Triax HD CCU MEERKAT ™ FXW PUW 12 V - 1.5 A max 2 km - SMPTE 311 cable (for Grass Valley™ systems: 1 km - SMPTE 311 cable) Studio application FMW PUW ® Wall box SMPTE / ARIB cable INFRASTRUCTURE FMW PUW Wall box FXW PUW SMPTE / ARIB cable ® SMPTE 311M cable / ARIB BTA S-1005B CCU HD Z-Link ­4 www.lemo.com ® ® CAMERA SIDE SMPTE / ARIB cable FUW FUW EDW HDTV Camera HDTV Camera PUW FXW EDW 6 way fibre cable FXG FGG PHG SERBAL™ EGG Mains power Mains power HD/SDI HDTV Camera Local 12V source (1.5 A max) Coax cables FGW SHACK™ EDW Local power Remote Camera Power (SMPTE 311 cable) HDTV Camera MEERKAT™ FUW Triax HD Local 12 V source (1.5 A max) Wall box FUW HDTV Camera Wall box INFRASTRUCTURE FXW PEW PUW SMPTE / ARIB cable FUW HDTV Camera FUW EDW HDTV Camera SMPTE / ARIB cable HD Z-Link HD Camcorder www.lemo.com ­5 ® ® LEMO pioneered and set the standard for HDTV The global standard for HDTV fibre connector LEMO developed the 3K.93C Series connectors in the early stages of the introduction of HDTV, becoming the standard for high-definition TV. It is one of the only connectors being used worldwide that complies fully with SMPTE, ARIB and EBU standards for both signal and cable. LEMO’s 3K.93C connectors are the standard in national and international broadcast companies. Fast transition to HDTV Transition to HDTV is easier than ever with LEMO. The wide range of shell styles and termination procedures, for even non-fibre experts, makes it possible for everyone to be successful in HDTV. The LEMO 3K.93C connector uses two single-mode fibre contacts, two high voltage contacts, and two signal contacts. Cable drums and cable assemblies with standard lengths are available off the shelf. Over 20’000 stainless steel shells mating cycles offered The rugged stainless steel outer shell of the LEMO 3K.93C connectors ensures a very long product life, when properly cleaned. The fibre optic contact can will last many years. Simple maintenance The optical contacts are accessible for fast cleaning; an optional simple, lightweight and portable fibre inspection unit helps the user view the condition of the fibre optic contact to ensure reliable operation. Highest performance with LEMO standard F2 fibre contact The advantage of using epoxy and polish contacts is the reliability of the termination and longevity of the connector to assure a quality signal transmission. These contacts are very robust and can withstand wide outdoor temperature variations. Extend the quality of your connection LEMO offers quality assembly service for HDTV connection systems. The connector assembly is done in-house by qualified personnel. F2 fibre optic contacts in various dimensions LEMO now offers 3 choices of F2 ferrule size to fit your fibre dimensions. Fibres are manufactured to about 125 microns, but in some occasion the fibres might be larger. LEMO’s choice of inner ferrule diameter are fit for 125 µm, 125.5 µm and 126 µm fibres. Designed for use with the LEMO 3K.93C, these contacts can be used directly into any LEMO connector where the F2 contact is used. Benefits • Quick disconnect Push-Pull self latching system • Over 11 shells to meet various application needs • Stainless steel shell for rugged and harsh environment • Optional pre-terminated F2 contacts for simple and rapid field assembly • UL certified connectors • ARIB (BTA S-1005B), ANSI/SMPTE (304 and 311) and EBU (R100-1999) compatible ­6 www.lemo.com ® ® 3K.93C Series The LEMO 3K.93C connectors with keys (W) were developed to meet the critical requirements of the new generation of digital HDTV cameras. The main features of this series are as follows: – Security of the LEMO Push-Pull self-latching system – Fitted with the standard LEMO F2 fibre optic contacts. – Conforms to the Japanese ARIB technical report BTA S-1005B, to the ANSI/SMPTE 304 M-1998 and 311M-1998 standards and to the European EBU Technical Recommendation R100-1999. – Qualified for use in UL approved equipment such as those specified in UL 1419 «Professional Video and Audio Equipment». – Cabled connectors have obtained the EC Attestation of conformity No: N8 00 03 39058 001 from the German TÜV Product Service. The 3K.93C series consists of eleven models which will accept cables specific to this application. It includes the HEAVY DUTY line with stainless steel shells that is guaranteed to at least 20,000 mating cycles and offer more resistance to heavy wear conditions. Models (page 10) Straight plugs Fixed sockets Free sockets FUW PUW EDW FGW PHW Fixed sockets Fixed plugs EBW FXW PEW ENW FMW PBW Outside Broadcast Van Configuration HDTV Camera EDW FUW FMW PUW FXW CCU PUW Outside Broadcast Van Studio Configuration HDTV Camera EDW fixed socket FUW straight plug FMW fixed plug PUW free socket FXW fixed plug CCU PUW free socket www.lemo.com Patch unit Camera Control Unit ­7 ® ® Part section showing internal components Fixed socket 6 3 7 8 17 2 3 12 6 16 17 14 15 5 10 split-insert carrier 1 outer shell 1 shell 11 anchor with screws 2 latch sleeve 2 grounding crown 12 female LV contact 3 inner shell with tag 13 earthing body 4 front ring 3 retaining ring 14 crimp ring 5 collet nut 4 insulator 6 insulator 5 female HV contact 7 male HV cont. 6 FO contact 7 O-ring 8 male LV contact Straight plug 5 4 2 1 4 9 7 8 1 17 10 11 13 15 collet with gaskets 16 extended shell 8 FO contact 17 o-ring 9 FO alignment device Technical characteristics Materials and treatments Component Outer shell, collet nut and oversized collet Grounding crown Latch sleeve Material (Standard) Brass (UNS C 38500) Surface treatment (µm) chrome nickel gold Cu Ni Cr Cu Ni Cu Ni Au 0.5 3 0.3 Stainless steel (AISI 303) without treatment Special brass 0.5 3 Stainless steel (AISI 416) without treatment Special brass 0.5 3 0.3 Stainless steel (AISI 416) without treatment Locking washer Bronze (UNS C 52100) 0.5 3 Hexagonal nut or round nut Brass (UNS C 38500) 0.5 3 Male crimp contact Brass (UNS C 34500) 0.5 3 1.0 Female crimp contact Bronze (UNS C 54400) 0.5 3 1.5 Clips Cu-Be (FS-QQ-C-530) without treatment Insulator PEEK Crimping tube Copper (UNS C 18700) 0.5 3 Brass (UNS C 38500) 0.5 3 Other metallic components O-ring and gaskets Stainless steel (AISI 303) without treatment Silicone MQ/MVQ, FPM/FKM (Viton®) or Nitril NBR Electrical Optical Characteristics Value Standard Characteristics Value Standard Method Insulation resistance > 1012 Ω IEC 60512-2 test 3a Shell electrical continuity < 1.6 mΩ IEC 60512-2 test 2f Contact resistance (signal) < 4.8 mΩ IEC 60512-2 test 2a Contact resistance (power) < 3.6 mΩ IEC 60512-2 test 2a Radiated emission freq. 30-220 MHz < 30 dBµV/m EN 55022 class B freq. 220-1000 MHz < 37 dBµV/m EN 55022 class B ­8 Average insertion loss fibre 9/125 µm 0.10 dB IEC 61300-03-04 Return loss fibre 9/125 µm (UPC) ≥ 45 dB Branching IEC 61300-03-06 Device Met. Return loss fibre 9/125 µm (Hand polish) ~30 dB Branching IEC 61300-03-06 Device Met. Insertion Method B www.lemo.com ® ® Vibration Mechanical and environmental Mating durability (Brass+Brass) 10000 cycles IEC 61300-02-02 Mating durability (Brass+Stainless steel) 8000 cycles IEC 61300-02-02 Mating durability (Stainless steel+St. steel) 20000 cycles IEC 61300-02-02 Damp heat steady state up to 95% at 60°C IEC 61300-02-19 High temperature +80°C IEC 61300-02-18 Low temperature -40°C IEC 61300-02-17 Temperature cycling -55°C + 90°C Cable retention 1000 N IEC 61300-02-04 Impact (Method A) 2 m onto concrete floor IEC 61300-02-12 Shock (3 cycles in 2 directions) 100 g, 10-50 ms; 20 g 6-9 ms IEC 61300-02-09 Water resistance (Depth of 1.8 for 48 h) IP 68 1) IEC 60529 > 1000 h IEC 60512-6 test 11f Salt spray corrosion test 2) Spectral density acceleration (G2/Hz) Characteristics Value Standard 0.1 20 Hz 20-60 Hz 60-200 Hz 200-320 Hz 320-600 Hz 600-2000 Hz 2000 Hz duration 0.01 0.001 10 20 50 100 2 0.009 G /Hz +9 dB / octave 2 0.24 G /Hz -3 dB / octave 2 0.147 G /Hz -6 dB / octave 2 0.014 G /Hz 180 s / axis 200 500 1K 2K 5K Frequency (Hz) Note: 1) except FXl and FMl models. 2) for chrome plated product (« C» material code).    Part number example Straight plug and free socket F U W . 3 K . 9 3 C . T L E C 9 6 Z Variant Cable ø: 74 = 6.2 to 7.4 mm 96 = 8.9 to 9.5 mm 12 = 11.6 to 12.5 mm Model Series: 3K Cable fixing type: C = collet adapter T = cable adapter Type: 93C Fibre contact: (page 12) Housing: T = stainless steel Insulator: L = PEEK FUW.3K.93C.TLEC96Z = Straight plug with keys (W), 3K series, mixed type to accept 2 F2 type fibre optic contacts, 2 power and 2 signal electrical contacts, stainless steel housing, PEEK insulator, female crimp signal contacts, cable fixing type T for 9.2 mm diameter cable, and nut for fitting a bend relief. Fixed socket E D W . 3 K . 9 3 C . T L E Model Fibre contact: (page 12) Series: 3K Insulator: L = PEEK Type: 93C Housing: T = stainless steel EDW.3K.93C.TLE = Fixed socket with rear square flange, keys (W), 3K series, mixed type to accept 2 F2 type fibre optic contacts, 2 power and 2 signal electrical contacts, stainless steel housing, PEEK insulator, male crimp signal contacts. www.lemo.com ­9 ® ® Models 3 K 9 3 C FGW Straight plug, cable adapter, for bend relief FUW Straight plug, cable collet adapter and long shell for fitting a bend relief with cap 135 maxi 115 maxi ~94 ø 19.5 ø 19 ø 9.2 ± 0.3 ~74 Note: The bend relief must be ordered separately (see page 13). Note: The bend relief must be ordered separately (see page 13). FXW Fixed plug, round flange (4 holes mounting), without collet FMW Fixed plug, round flange (4 holes mounting), cable adapter, for bend relief 30 10 ø 38 10 Panel cut-out 0.1 ø 23.2 + 0 0.1 ø 3.5 + 0 20.6 0.1 ø 23.2 + 0 0.1 ø 3.5 + 0 20.6 101 maxi 30 ø 38 ~61 Panel cut-out Note: Only available for IP 50 in mated condition. Note: Only available for IP 50 in mated condition. The bend relief must be ordered separately (see page 13). EDW Fixed socket with rear square flange, (4 holes mounting), and earthing tag EBW Fixed socket with front square flange, (4 holes mounting) 0.1 ø 23.2 + 0 29 3 6 22.5 Panel cut-out ­10 23 0.1 ø 23.2 + 0 29 3 0.1 ø 3.5 + 0 42.5 23 0.1 ø 3.5 + 0 42.5 Panel cut-out www.lemo.com ® ® ENW Fixed socket, nut fixing and earthing tag PUW Free socket, cable collet adapter and long shell for fitting a bend relief with cap 0.1 ø 24.2 + 0 ø 31 M24x1 42.5 0.1 ø 22.6 + 0 6 ~98 ø 23 ø 9.2 ± 0.3 11.3 max Panel cut-out Note: The bend relief must be ordered separately (see page 13). PEW Fixed socket, nut fixing, cable adapter, for bend relief (back panel mounting) PHW Free socket, cable adapter, for bend relief ø 23 ø 30 139 maxi 4.5 7.5 max Note: The bend relief must be ordered separately (see page 13). 0.1 ø 24.2 + 0 ~136 maxi 0.1 ø 22.6 + 0 Panel cut-out Note: The bend relief must be ordered separately (see page 13). PBW Fixed socket with rear square flange, (4 holes mounting, cable adapter, for bend relief 3 0.1 ø 23.2 + 0 23 0.1 ø 3.5 + 0 22.5 29 ˜136 maxi Panel cut-out Note: The bend relief must be ordered separately (see page 13). www.lemo.com ­11 ® Insert configurations 2 N 2 signal LV male 0.9 20-24 Rated current (A) Test voltage (V rms) Working voltage (V rms) Creepage distance and air clearance (mm) AWG range Contact type for plug Number of contacts Contact function Electrical crimp contacts Ferrule bore inside ø (µm) Socket insulator Fibre core/cladding (µm) Plug insulator Contact type for plug Fibre optic contact Reference Number of fibre optic contacts 9 3 C Contact ø (mm) ® ≤ 42 1000 3 2 power HV male 1.3 14-18 > 6.5 ≤ 600 2250 10 93C fem. 9/125 125 N Fibre optic contact FFS.F2 Male F2 Fibre Optic Contact PSS.F2 Female F2 Fibre Optic Contact ~ 31.2 11.9 ø 4.4 ø 4.4 ø2 ø2 ~ 31.2 Ref. Ferrule Contact hole E FFS.F2.BA2.LCE30 K X Type Gender Note Ref. Ferrule Contact hole 125 µm Crimp Male l E PSS.F2.BA2.LCE30 FFS.F2.BA2.LCT10 125 µm Epoxy Male l K FFS.F2.BX2.LCE30 125.5 µm Crimp Male l X V FFS.F2.BX2.LCT10 125.5 µm Epoxy Male l F FFS.F2.BB2.LCE30 126 µm Crimp Male N FFS.F2.BB2.LCT10 126 µm Epoxy Male Type Gender Note 125 µm Crimp Female l PSS.F2.BA2.LCT10 125 µm Epoxy Female l PSS.F2.BX2.LCE30 125.5 µm Crimp Female l V PSS.F2.BX2.LCT10 125.5 µm Epoxy Female l l F PSS.F2.BB2.LCE30 126 µm Crimp Female l l N PSS.F2.BB2.LCT10 126 µm Epoxy Female l l First choice alternative l Special order alternative ­12 www.lemo.com ® ® Accessories GMA Bend relief L øA Part number Dim. (mm) A L GMA.3B.090.DN 9 42 GMA.4B.011.DN 11 60 Note: The last letter «N» of the part number indicates the colour black of the bend relief. For others colour, refer to the table below and replace letter «N» by the letter of the colour required. Ref. Colour Ref. Colour Ref. Colour A blue J yellow R red B white M brown S orange G grey N black V green GMF Bend relief with cap for FUW plug Part number GMF.3K.085.EANZ l Material: black ALCRYN® GMP Bend relief with cap for PUW free socket Part number GMP.3K.085.EANZ l Material: black ALCRYN® GMF Coloured ring for bend relief with cap Part number Colour GMF.3K.265.RG grey GMF.3K.265.RN black GMF.3K.265.RR red GMF.3K.265.RV green l Material: Silicone www.lemo.com ­13 ® ® Bll Blanking caps Part number BHA.3K.100.EAN BRA.3K.200.EAN BFG.3K.100.EAN BHA.3K.100.715EN BRF.3K.200.EAN BRA.3K.100.715EN For connector model BHA.3K.100.EAN FMW, FXW BRA.3K.200.EAN EDW, PEW BFG.3K.100.EAN FUW BRF.3K.200.EAN PUW BHA.3K.100.715EN FMW, FXW BRA.3K.100.715EN EBW, EDW, ENW, PBW, PEW l Material: black ALCRYN® GMl Gaiters Colour Dimension L (mm) For connector model GMP.3K.140.165PER red 165 PUW GMP.3K.140.165PEN black 165 PUW GMF.3K.140.156PEV green 156 FUW GMF.3K.140.156PEN black 156 FUW ø 14 mm Part number L l Material: PVC BRR Spring loaded dust cap for EDW and EBW L øC B øA Part number M N BRR.3K.200.PZSG Dimensions (mm) A B C L 29 29 23 8.1 M N 3 33.2 Note: On request, this cap is available in black. If so replace the last letter «G» of the part number by «N». l Material: Polyoxymethylene (POM) grey (or black) WRE Cable drum for SMPTE cable Part number ­14 Cable Nb of length rings (m) Width Height Weight (mm) (mm) (kg) WRE.3K.93C.200SA 2 200 180 615 7.00 WRE.3K.93C.400SA 2 400 270 615 7.50 WRE.3K.93C.200TA 3 200 240 615 8.50 WRE.3K.93C.300TA 3 300 295 615 8.85 WRE.3K.93C.500TA 3 500 330 615 9.05 www.lemo.com ® ® Patch panels PBl Patch panel 2U panel with one row of 6 or 10 plugs or sockets of the 3K.93C Series. P B G . 3 K . 9 3 C . M W 9 6 0 6 Ref. Colour Ref. Front side connection Ref. Cable ø (mm) Nb of connectors C beige MW Plug FMW 9606 8.9 to 9.5 6 G grey EW Socket PEW 1206 11.6 to 12.4 6 N black BW Socket PBW 9610 8.9 to 9.5 10 T nat. anod. 1210 11.6 to 12.4 10 Integrated 3U panel with splice tray and connector junctions 2U Rack mounted splice tray with connector junctions An integrated panel with built in splice tray and connector junctions for use where space is limited, either at a wallbox or a patching unit. Up to 3 can be mounted side-by-side to fit in 3U rack dimensions. Rack mounted splice tray of 2U height with connector junctions for patch unit. Can accommodate up to 10 LEMO connectors. The modular design of the unit along with blanking plates provides opportunity for increasing numbers of channels up to 10. Note: Available on request. www.lemo.com Note: Available on request. ­15 ® ® Tooling DCS.F2.N02.PA Fibre Optic one-click cleaner DCT.F2.125.PA Fibre Optic ferrule cleaner Insert the one-click cleaner into the insulator and push until an audible “click” is heard. The cleaner uses a mechanical push action to advance an optical grade cleaning tape. More than 500 cleaning per cleaner. Product includes special LEMO F2 ferrule adaptor. This cleaning tool comes with a bush for different cleaning configurations. More than 500 cleaning per cleaner. This cleaner is for on-site purposes only and should not replace regular maintenance cleaning with cotton buds and alcohol. DCS.F2.035.PN Alignment device tool WST.KI.125.34 Cleaning kit F2 contact Simple tool with two threaded end for installation/extraction of the F2 contact alignment device. For use with WST.KI.125.34 kit above. Fibre optic cleaning kit of 2 cotton buds, 1 dry and 1 being soaked in IPA (Isopropyl Alcohol) used for cleaning the fibre optic contacts. WST.FB.CI1.10US2 Video inspection viewer DCS.3K.175.72LN Cable puller A portable fibre optic viewer for F2 contact consisting of handset probe, LCD display, ferrule tips for LEMO contacts & software & United States AC power supply all in a rugged case. European power supply version (WST.FB.CI1.10EU2). An optional USB capture device is also available (part number: WST.FB.CI1.00USB2). The LEMO cable puller, is a pull through tool that allows passing the cable through narrow sections and protects the optical fibre during installation. DRV.FO.MOB.LAB3KC Mobile Lab for 3K.93C with F2 fibre optic contact WST.TE.HDTV HD cable tester This cable tester provides a quick and easy means of checking the functionality of HD hybrid fibre cables and cable systems. A laser source checks the fibres giving an indication of the attenuation through the whole cable or cable system, and electrical tests check for continuity of both the power and control conductors. Note: Available on request. ­16 www.lemo.com ® ® NORTHWIRETM HDTV cables NORTHWIRE hybrid camera cable according to SMPTE 311 and ARIB standards This composite cable combines power conductors for TV camera, control wires, and optical fibres for video and audio transmission in a single cable. Specially designed to cope with the heavy demands of outside broadcast. The cable fully meets the requirements of the SMPTE 311M standard for camera cables. Primary features and benefits of this cable are: l High durability construction. l Excellent flexing and twist capability coping with rough handling by rigging crews. l Superior load bearing capabilities – can be driven over by trucks whilst in operation. l High tensile strength. PVC (-20°C/+80°C) PVC (-20°C/+80°C) PUR (LSZH) (-40°C/+80°C) Commercial quality – SMPTE 311M standard cable CFN.3K.93C.092PNCS (multipurpose) CFN.3K.93C.160PNCS (studio application) CFN.3K.93C.068PNCS (6.8mm not SMPTE 311M) High quality – ARIB standard cable CFN.3K.93C.092PNCA (multipurpose) CFN.3K.93C.160PNCA (studio application) High flex quality – for studio or low temperature CFN.3K.93C.092UNCS (SMPTE 311M) CFN.3K.93C.092UNCK (Aramid strength member similar to Kevlar®) Power wire Black (x2) Optical fibre #1 Blue Power wire Black (x2) Optical fibre #1 Yellow Power wire Black (x2) Optical fibre #1 Blue Signal wire Red Signal wire Grey Signal wire Red Signal wire Green Signal wire Red Signal wire Grey Power wire White (x2) Strength member Optical fibre #2 Yellow Strength member Power wire White (x2) Strength member Power wire White (x2) Optical fibre #2 Blue Optical fibre #2 Yellow Cable specification Core type Power (Aux) Control (Signal) Optic fibre Strength member Nb of cores 4 2 2 1 Conductor sizes - AWG 20 24 – – Conductor construction - Nb/mm 19/0.185 7/0.193 Mode field diameter - µm – Cladding diameter - µm – Approx. diameter of conductor - mm 0.88 0.58 – 1.75 Nominal insulation thickness - mm 0.41 0.30 – 0.38 Approx. core diameter - mm 1.72 1.22 – 19/0.330 – 8.9 ± 0.8 at 1310 – – 125 ± 1 µm – Approx. thickness of tin-coated annealed copper braid - mm 0.127 Nominal thickness of jacket - mm 1.14 Approx. overall diameter - mm 9.2 Approx. net weight - g/m7 137 Max. conductor resistance - (20°C) Ω/km 0.9 2.51 43 184 (SMPTE) – – AC withstanding voltage - Vrms at 60 Hz, 1 min 1750 1750 (SMPTE) – – Min. insulation resistance - (20°) MΩkm 10’000 – – UL Listing Allowable tension 10’000 AWM STYLE 21971 700N Temperature range (PUR version) -40°C / +80°C Temperature range (PVC version) -20°C / +80°C Bending radius PVC version (mm) 55 www.lemo.com ­17 ® ® Cable specification (optical fibre) Conversion Conversion Item Wavelength Characteristics condition (km) formula Transmission loss l = 1.31 µm Less than .8 dB/km up to ≥ 0.4 0.5xLdB≥ l = 1.31 µm Less than .8 dB/km L < 0.4 0.5x0.4dB≥ Hybrid HDTV fibre optic cable part number SMPTE standard C F N . 3 K . 9 3 C . 0 9 2 P N C S Version S = SMPTE 311M K = Aramid strength member similar to Kevlar® Shielding C = Tinned copper Jacket color N = Black RAL 9005 (other colours on request) Cable Fiber optic Jacket material P = PVC U = PUR 1) Vendor: N = Northwire Jacket max ø 068 = 6.8 mm 2) 092 = 9.2 mm 160 = 16.0 mm Series Type Note: 1) PUR outer jacket for high flex and LSZH (Low smoke zero halogen). Recommended for cold temperatures (-40°C). 2) Recommended for assembly length up to 5 meters. ARIB standard C F N . 3 K . 9 3 C . 0 9 2 P N C A Version A = ARIB standard Cable Fiber optic Vendor: N = Northwire Series Type ­18 Shielding C = Tinned copper Jacket color N = Black RAL 9005 (other colours on request) Jacket material P = PVC Jacket max ø 092 = 9.2 mm 160 = 16.0 mm www.lemo.com ® ® Cable assembly Part Number Example Cable M F P . 3 K . 9 3 C . A M 0 2 5 N S S = SMPTE 311M A = ARIB K = Aramid strength member similar to Kevlar® Model 1 (table 1) Model 2 (table 1) Cable supplier & sheath color (table 4) Sheath ø & material (table 2) Length unit & gaiters (table 3) Cable length MFP.3K.93C.AM025NS = 1 FUW plug and 1 PUW socket (key W), 3K.93C series, on a SMPTE 311M screened cable, 25 m length, sheath ø 9.2 mm, black RAL 9005 jacket color, with GMF/GMP bend relief with cap. Table 1 Model Table 2 Sheath ø & material Table 3 Length unit & gaiters Table 4 Cable supplier & sheath color Code No Red gaiter free socket 2 black 2 yellow Gaiter Green gaiter plug gaiters gaiters Cable supplier & sheath color F 9.2 A R cm C E N Northwire Black FMW M 4.2 B S dm D F G Northwire Grey PUW P 6.8 C T m M PEW E 12.0 D U km K L PBW B 16.0 E V inch I feet T Code FUW Code PUR Sheath ø (mm) PVC 1) Model 1&2 G N J A Northwire Blue F Furukawa Black B Belden Black Note: 1) PVC not recommended for temperatures below -20°C. www.lemo.com ­19 ® ® MFP Outside broadcast cable assembly Assembly cable with one straight plug (FUW) and one straight socket (receptacle) (PUW), both complete with GMF/GMP bend relief with cap. FUW + GMF PUW + GMP MFP Outside broadcast cable assembly Assembly cable with one straight plug (FUW) and one straight socket (receptacle) (PUW), both complete with GMF/GMP bend relief with cap and gaiters. FUW + GMF PUW + GMP MMP Internal OB van cable assembly Assembly cable with one fixed plug (FMW) and one straight socket (receptacle) (PUW), both complete with BHA/BRF caps. BHA FMW BRF PUW MME Studio/Infrastructure cable assembly Assembly cable with one fixed plug (FMW) and one straight socket (receptacle) (PEW), complete with BHA cap. BHA ­20 FMW PEW www.lemo.com ® ® Part Number Example Pigtails M X T . 3 K . 9 3 C . Z Z Z C 0 5 0 Model X = FXW D = EDW Cable length (cm) T = Pigtail (LC) MXT.3K.93C.ZZZC050 = 1 FXW plug (key W), 3K.93C series and one pigtail (LC) on the other side, 50 cm length. MXT ECU side pigtails Assembly cable with one fixed plug (FXW) and one pigtail (LC) complete with BHA cap. FXW BHA MDT Camera side pigtails Assembly cable with one fixed socket (EDW) and one pigtail (LC) complete with BRA cap. BRA www.lemo.com EDW ­21 ® ® SMPTE 311M standard cable assemblies Outside Broadcast FUW-PUW Part number Internal OB van Description Part number Description MFP.3K.93C.AM025NS 25 meter length MMP.3K.93C.AM003NS 3 meter length MFP.3K.93C.AM050NS 50 meter length MMP.3K.93C.AM005NS 5 meter length MFP.3K.93C.AM100NS 100 meter length MMP.3K.93C.AM010NS 10 meter length MFP.3K.93C.AM200NS 200 meter length MMP.3K.93C.AM015NS 15 meter length MFP.3K.93C.AM300NS 300 meter length MMP.3K.93C.AM020NS 20 meter length MFP.3K.93C.AM400NS 400 meter length MFP.3K.93C.AM500NS 500 meter length Studio/Infrastructure Part number Description MME.3K.93C.AM020NS 20 meter length MME.3K.93C.AM050NS 50 meter length ARIB standard cable assemblies Outside Broadcast FUW-PUW Part number Internal OB van Description Part number Description MFP.3K.93C.AM025NA 25 meter length MMP.3K.93C.AM003NA 3 meter length MFP.3K.93C.AM050NA 50 meter length MMP.3K.93C.AM005NA 5 meter length MFP.3K.93C.AM100NA 100 meter length MMP.3K.93C.AM010NA 10 meter length MFP.3K.93C.AM200NA 200 meter length MMP.3K.93C.AM015NA 15 meter length MFP.3K.93C.AM300NA 300 meter length MMP.3K.93C.AM020NA 20 meter length MFP.3K.93C.AM400NA 400 meter length MFP.3K.93C.AM500NA 500 meter length Studio/Infrastructure Part number Description MME.3K.93C.AM020NA 20 meter length MME.3K.93C.AM050NA 50 meter length Other cable assemblies, patch cords and pig tails available on request. ­22 www.lemo.com ® ® MEERKATTM HD converter A compact solution for Sony ® SD, Grass Valley™ (Thomson ®) SD/HD camera based systems The LEMO MEERKAT™ Triax media converter system provides the solution the broadcast industry has been waiting for. This compact «plug and play» transmission system provides a fibre link between Triax cameras and OB vans. The LEMO Media Converter offers mobile facility providers, production centres and broadcast studios an approp­riate and professional solution for long distance signal transmission. Get more from your cables The camera is powered via a hybrid cable from the CCU with both the camera signals and the return monitor signals being digitally encoded and transmitted over fibre. The SMPTE 311 hybrid cable uses the well proven technology of the LEMO 3K.93C series. If power from the CCU/OB van is not required, i. e. local power is available, a two fibre cable using 2 x FC-PC or 2 x SC may be used for signal transmission. Applications • Golf, skiing, auto racing, olympic games • Pre-fibred venues • Stadiums, racing tracks Advantages • Plug & play solution • Lightweight and portable, compact • No need for bulky / heavy triax cables • High quality signal transmitted over fibre • LED functionality display Features • CE and FCC class B certified • Immune to EMI • NTSC & PAL • Digital encoding and transmission • Portable device • No repeaters needed Accessories • Tripod clamps (WST.MT.286.DZZ) • MEERKAT™ carry belt (WST.MT.170.TZZ) • 3K.93C assembled cable • 3K.93C – SC or FC/PC adapter cable • Option in-line power supply Every triax-to-fibre Media Converter comes with power supply (110V/220V) adapter and its specific dongle (either Grassvalley™ or Sony®). Remote Camera Power (SMPTE 311 cable) MEERKAT™ (A) POWERKAT ™ * optional 1m - TRIAX Local 12 V source (1.5 A max) or POWERKAT™ * MEERKAT™ (B) 2 km - SMPTE 311 cable ** 1m - TRIAX * No local power required when using the MEERKAT™ with the POWERKAT™. ** For Grass Valley™ systems : 1 km - SMPTE 311 cable www.lemo.com 12 V - 1.5 A max ­23 ® ® Technical characteristics Input/outputs Connectors Signals Values I/O ports Triaxial connector 75 Ω 1) Optical RX sensitivity -3 dB to -21 dB DC in LEMO 0K series, 2 pin in-line transformer Data rate 2x2.5 GB/s Optical Tx output 200 µW (250 µW max) Transmission wavelength 1310 nm / 1550 nm General Values Dimensions 125W x 270L x 50H mm Mass (approx.) 2 kg Power requirements 2) 100 to 120 Vac, 50/60 Hz Fuse 4 x 4 Amp Wickmann TR5 requirements 3) 220 to 240 Vac, 50/60 Hz AC/DC power supply 2 with UK, USA, Europe adaptors Power consumption 16 W User’s guide 1 Operating voltage 12 Vdc / 1.5 A max Operating temperature -20°C to +55°C Humidity up to +95% Index protection IP66 (when mated) Power Note: 1) LEMO Supplied accessories Quantity 3K.93C series (HDTV). 2) In North America, Japan and areas of South America. 3) In Europe, Africa, Australia, Scandinavia, China. List of HD compatible cameras Manufacturer Grass ValleyTM Grass ValleyTM Grass ValleyTM List of SD compatible cameras Triax Camera camera adaptor Part Nr Type Part Nr LDK 3000 LDK 4000 Base station Part Nr Type Manufacturer Triax Camera camera adaptor Part Nr Type Part Nr Base station Part Nr Type HD LDK 5630 LDK 4580 HD SONY® BVP-E30 SD CA590 CCU-790 SD HD LDK 5460 LDK 4502 HD SONY® BVP550 SD CA550 CU-550 SD BVP950 SD CA570 CCU-700 SD LDK 4000 HD LDK 5860 LDK 4506 HD SONY® Grass ValleyTM LDK 6000 HD LDK 5460 LDK 4502 HD SONY® BVP700 SD CCU-700 Grass ValleyTM LDK 6200 HD LDK 5462 LDK 4506 HD SONY® BVP750 SD CCU-700 Grass ValleyTM LDK 8000 HD LDK 5860 LDK 4502 HD SONY® CCU-750 Grass ValleyTM LDK 8000 (S) HD SONY® CCU-500 Grass ValleyTM LDK20s SD LDK5400 LDK4053 SD Grass ValleyTM LDK20s SD LDK5430 LDK4501 SD Grass ValleyTM LDK100 SD LDK5400 LDK4053 SD Grass ValleyTM LDK200 SD LDK5430 LDK4501 SD Grass ValleyTM LDK300 SD LDK5400 Grass ValleyTM LDK 5860 LDK 4506 HD Each MEERKAT™ is delivered in a black watertight flightcase. ­24 SD LDK300 SD LDK5430 LDK4501SL SD Grass ValleyTM LDK400 SD LDK5400 Grass ValleyTM LDK400 SD LDK5430 LDK4501SL SD Grass ValleyTM LDK500 SD LDK5400 Grass ValleyTM LDK500 SD LDK5430 LDK4501SL SD SD SD Notes : Do not connect any camera other than those on the list above without contacting the LEMO Technical Support Group. www.lemo.com ® ® Option 2 - Local Camera Power With the Local Camera Power setup, the camera is powered with its AC or DC voltage from a local source of power either - a generator or a power pack. Local Camera Power (2 x SC or 2 x FC/PC optic cable) MEERKAT™ (A) 1m - TRIAX Local 12 V source (1.5 A max) Local power ≥ 20 km - 2 x SC or 2 x FC/PC optic cable Maximum transmission distance determined by the camera system power budget MEERKAT™ (B) 1m - COAX/TRIAX 12 V - 1.5 A max LEMO triax connector on the camera Part number of the MEERKATTM (A) on the camera side Electrical triax connector on cable LEMO triax connector on the CCU Part number of the MEERKATTM (B) on the CCU side Electrical triax connector on cable Socket 4M.650 PHW.MT.3••.TFRP10 FGG.4M.650.CTLC90 Plug 4M.650 FGW.MT.3••.TPRP10 PHG.4M.650.CTAC90 Plug 4M.650 PHW.MT.3••.TPRP10 PHG.4M.650.CTAC90 Socket 4M.650 FGW.MT.3••.TFRP10 FGG.4M.650.CTLC90 Socket 4E.675 PHW.MT.3••.TFUP10 FFA.4E.675.CTAC90 Plug 4E.675 FGW.MT.3••.TPUP10 PCA.4E.675.CTLC90 Plug 4E.675 PHW.MT.3••.TPUP10 PCA.4E.675.CTLC90 Socket 4E.675 FGW.MT.3••.TFUP10 FFA.4E.675.CTAC90 Socket 4A.675 PHW.MT.3••.TFVP10 FXB.4A.675.CTCC85 Plug 4A.675 FGW.MT.3••.TPVP10 PXA.4A.675.CTRC85 Plug 4A.675 PHW.MT.3••.TPVP10 PXA.4A.675.CTRC85 Socket 4A.675 FGW.MT.3••.TFVP10 FXB.4A.675.CTCC85 Socket REDEL F PHW.MT.3••.TFWP10 FAZ.T7.675.CTA02C Plug REDEL F FGW.MT.3••.TPWP10 PCZ.T7.675.CTL02C Socket 3T.675 PHW.MT.3••.TFTP10 FFA.3T.675.CTAY92S Plug 3T.675 FGW.MT.3••.TPTP10 PCA.3T.675.CTLY92S Camera system •• KC SONY® SD / Grass ValleyTM SD TH Grass ValleyTM HD / Grass ValleyTM SD / SONY® SD Cable camera to MEERKATTM (A) Type Cable CCU to MEERKATTM (B) MAP.MC.TAA.MM012G 4A series MAM.MC.TAA.CM012G MAF.MC.TRA.AM012G REDEL T7 MAR.MC.TRA.AM012G MAC.MC.TMA.AM012G 4M series MAG.MC.TMA.LM012G MAL.MC.TEA.LM012G 4E series MAA.MC.TEA.AM012G MAA.MC.TTA.AM012G 3T series MAC.MC.TTA.LM012G MEERKAT ™ (A) MEERKAT ™ (B) Additional triax cables can be ordered for specific cameras. One set of cable comes with fully working MEERKAT™ System. www.lemo.com ­25 ® ® Accessories EDW POWERKAT ™ GSF Tripod clamp EDW.MT.126.TE3K GSF.MT.283.DZZ It retrieves the power directly from the CCU and allows powering both the camera and HD MEERKAT™ directly from the SMPTE cable. Delivered with 1 meter cable to HD MEERKAT™ (PUW-FUW). The tripod clamp allows the camera operator to fix the HD MEERKAT™ to the camera tripod. WST Hang up strap kit WSK Belt carrier WST.MT.170.TZZ Belt: WSK.MT.285.PN The hang up strap kit allows the camera operator to easily hang up the HD MEERKAT™ while shooting. (Strap length: 0.25 m). The belt carrier allows the cameraman to carry the MEERKAT™ or the POWERKAT™ on the hip. Simply slide the belt throught two buckles. Buckles: WSK.MT.284.RT Note: Two buckles are necessary to carry the MEERKAT™. MGY Cable lead for battery FGG Programming dongle MGY.0K.302.YAM020N The HD MEERKAT™ is delivered with its original dongle. An additional dongle is available ( Grass Valley ® / Sony ®). The second dongle allows switching from one system to another. Cable lead for professional battery belt, it allows powering the HD MEERKAT™. Cable (length 2 meters) with 2 pin LEMO connector (FGG.0K) to a 4-Pin XLR male Neutrik connector. To be used with commercialy available battery belts (12V) ­26 Grass Valley ® SD : FGG.0K.309.CB70TS Sony ® SD : FGG.0K.309.CD70SS Grass Valley ® HD : FGG.0K.309.CA00TH www.lemo.com ® ® SERBALTM converter SERBAL TM - SMPTE Electrical Reconfigurable Bidirectional Alternative Link The LEMO SERBAL TM is a 4 channel multiplexer that makes HD/SDI to fibre conversion possible. The SERBAL TM provides a compact conver­sion unit which allows out­put from up to 4 cameras to be transmit­ted over a single standard LEMO 3K.93C SMPTE cable. The optical multiplexers of the SERBAL TM use Wavelength Division Multiplexing (WDM). Each signal within a fibre has a different optical wave length, enabling interference free transmission over longer distance. The system is available in three versions: it can send 4x HD/SDI signals from the cameras to the OB van using one SMPTE cable. The second version can send 2x HD/SDI signals from the cameras to the OB van, while using the remaining 2 signals for monitor feedback. If only one monitor feedback is required, the third version can send up to 3 camera signals to the OB van. Applications • Golf, skiing, auto racing, olympic games • Pre-fibred venues • Stadiums, racing tracks Advantages • Plug & play solution • High quality signal transmitted over fibre • Compact Features • Converts from Coaxial BNC input to transmission over standard 3K.93C cable assemblies • Multiple transmission options available - 4 x Tx - 2 x Tx + 2 x Rx - 3 x Tx + 1 x Rx • Audio/Data: passes pre-embedded Audio • Supports all NRZI data formats from 10 Mb/s to 1.5 Gb/s • Signal format: HD/SDI SMPTE 292M, SDI, DVB-ASI, 19.4 Mb/s SMPTE 310, 142-540 Mb/s SMPTE 259M, SDTI. CAMERA SIDE HD/SDI COAX www.lemo.com CCU SIDE SERBAL™ SERBAL ™ FIBRE Local 12V source (1.5 A max) Local 12V source (1.5 A max) HD/SDI COAX ­27 ® ® Broadcast setup Camera side Broadcast setup CCU side SERBALTM Part number SERBALTM Part number 4 cameras PHW.MS.3C4.TPBCC 4 Rx signals FGW.MS.3C4.TPBCM 2 cameras / 2 monitors PHW.MS.3C2.TPBCC 2 Rx signals + 2 Tx signals FGW.MS.3C2.TPBCM 3 cameras / 1 monitor PHW.MS.3C3.TPBCC 3 Rx signals + 1 Tx signals FGW.MS.3C3.TPBCM Note: Every coax-to-fibre Media Converter comes with power supply (110V/220V) adapter. Technical characteristics Characteristics Values Characteristics Values Weight / dimension 2 kg / 172 x 125 x 50 mm Optical launch power - 4.5 dB @ 1550 nm Transmission wavelength 1310 nm / 1550 nm Optical receive sensitivity - 30 dB @ 1310 nm Cable (hybrid) SMPTE 311 Optical receive sensitivity - 30 dB @ 1550 nm Cable (2 fibre 9/125) 2 fibre single mode cable Equalisation (camera side) up to 300 m @ 270 Mb/s Fibre type Single mode Equalisation (camera side) up to 100 m @ 1.485 Gb/s Optical connector LEMO 3K.93C series Temperature range -30°C to +55°C Electrical coax connector BNC 75Ω Humidity range Up to 95% Optical launch power - 6 dB @ 1310 nm Input voltage 12 Vdc @ 1.5 A maximum Coaxial HD/SDI SMPTE cable Fibre optic Camera 1 Camera 2 Camera 3 SERBAL™ SERBAL™ 4 x Tx signal Coaxial HD/SDI OB van 4 x Rx signal Camera 4 Coaxial HD/SDI Camera 1 Camera 2 Feedback monitor 1 Feedback monitor 2 SMPTE cable Fibre optic Camera 2 ­28 OB van 2 x Rx signal 2 x Tx signal SERBAL™ SERBAL™ 2 x Tx signal 2 x Rx signal Coaxial HD/SDI Camera 1 Coaxial HD/SDI SMPTE cable Fibre optic Coaxial HD/SDI OB van 2 x Rx signal 2 x Tx signal SERBAL™ SERBAL™ Camera 3 1 x Tx signal 1 x Rx signal Feedback monitor 1 1 x Rx signal 1 x Tx signal www.lemo.com ® ® SHACKTM converter SHACKTM - SMPTE conversion device for singlemode fibre (SC, ST, FC or LC) The SHACKTM is a conversion system from SMPTE connectors/cable to standard singlemode connectors. The system provides a transition from optical communication over hybrid (copper and fibre) cables to optical communication over commonly available singlemode fibre optic cables. The SHACKTM permits the camera to be locally powered while allowing the optical signals to be transmitted. It is a lightweight and very compact solution for stadiums, sports arenas or outside broadcast applications. Applications • Golf, skiing, auto racing, olympic games • Pre-fibred venues • Stadiums, racing tracks Advantages • Plug & play solution • High quality signal transmitted over fibre • Compact • Uses inexpensive SC, ST, FC or LC connectors • Camera brand independant Features • Converts from SMPTE 304 connectors to standard duplex fibre optic cable assemblies • Plugs directly into camera/base station FGW SHACK™ PHW SHACK™ 2 x SC / 2 x ST / 2 x FC / 2 x LC SMPTE 304 Local power www.lemo.com EDW.3K.93C Singlemode cable Any commonly available duplex cable SMPTE 304 FXW.3K.93C ­29 ® ® Technical characteristics Characteristics Values Characteristics Values Fibre type Singlemode Electrical 1) Hybrid connector LEMO 3K.93C series Laser safety 2) Singlemode fibre connector SC, ST, FC, LC Humidity range Up to 95% Temperature range -20°C to +60°C Warranty 5 years CCU supply voltage range 15 V to 360 V Return loss ≤ 45 dB per unit EMI/RFI Complies with 89/336/EEC Average insertion loss 0.4 dB per unit Note: 1) Complies with EN 61000-6-1, EN61000-6-2. 2) Complies with Class 1 laser product 24 CFR 1040.10 & 1040.11. FGW Straight plug 3K.93C - singlemode ø 39 124 Part number Singlemode fibre connector Note FGW.3K.93C.CLMSC SC l FGW.3K.93C.CLMST ST l FGW.3K.93C.CLMFC FC l FGW.3K.93C.CLMLC LC l Part number Singlemode fibre connector Note PHW.3K.93C.CLCSC SC l PHW.3K.93C.CLCST ST l PHW.3K.93C.CLCFC FC l PHW.3K.93C.CLCLC LC l l Standard l Upon request PHW Free socket 3K.93C - singlemode ø 39 136 l Standard l Upon request ­30 www.lemo.com ® ® MULTISHACK 3XTM or 6XTM converter The MULTISHACK TM is a conversion system from multiple SMPTE connectors/cable to a single multiway fibre cable. The system provides a transition from HD over hybrid (copper and fibre) cables to HD over a single multiway fibre optic cable. The MULTISHACK TM enables up to 3 or 6 cameras to be individually powered from one remote source (i.e. a local generator) through the 3K.93C connectors and cables. The optical signals will continue to be transmitted through individual pairs of fibres within a multiway fibre optic cable. The power is inserted at the Camera end MULTISHACK TM via a waterproof mains / power connector and is distributed to the hybrid cables through individual circuits. The CCU / OB MULTISHACK TM is powered by the output voltage from the CCU. The MULTISHACK TM uses the technology proven in the SHACK TM and has individual transmission circuits ensuring a manufacturer protection handshake for each channel. Applications • Golf, skiing, auto racing, olympic games • Stadiums, racing tracks • Wherever multiple cameras are needed in a remote location Advantages • Plug & play solution • One multiway cable is cheaper than multiple SMPTE 311 hybrid cables • The 6 cameras can be powered without additional mains / DC leads to every camera MULTISHACK 3XTM www.lemo.com Features • Converts from SMPTE 304 connectors to a single multiway fibre optic cable • Plugs directly into camera/base station via cable • Allows connection of up to 6 cameras • Redundant power supply MULTISHACK 6XTM ­31 ® ® MULTISHACK 3XTM conversion system Technical characteristics Characteristics Values Characteristics Values Fibre type Singlemode Electrical 1) Hybrid connector LEMO 3K.93C series Laser safety 2) Multifibre connector LEMO 4K series Humidity range Up to 95% Temperature range -20°C to +60°C Warranty 5 years CCU supply voltage range 15 V to 360 V Return loss Better than 45 dB per channel EMI/RFI Complies with 89/336/EEC Average insertion loss 0.4 dB per channel Note: 1) Complies with EN 61000-6-1, EN61000-6-2. 2) Complies with Class 1 laser product 24 CFR 1040.10 & 1040.11. Manufacturer Part number PXG.MX.C31.AT PHD.MX.V13.AT PHT.MX.R13.AT PTG.MX.R31.AT PHC.MX.R13.AT PCG.MX.R31.AT Description No Grass ValleyTM (grey) Camera end/for Grass ValleyTM model/3 way TM 1 Grass Valley TM (grey) CCU end/for Grass Valley Grass Valley TM (grey) Break out box for ST fibre Camera end 3 Grass Valley TM (grey) Break out box for ST fibre CCU end 4 Grass Valley TM (grey) Break out box for SC fibre Camera end 3 Grass Valley TM (grey) Break out box for SC fibre CCU end 4 CAMERA SIDE camera model/3 way 2 Notes: For a Sony ® version, replace last digit of the part number «T» by «S». Grass ValleyTM version is grey and Sony ® version is blue. CCU SIDE CCU SIDE SMPTE 304 1 Mains power * EDW 2 FXW FXG EGG 4 SMPTE 304 EDW (3x ) EGG Mains power * SMPTE 304 2 FGG FXG PHG 6 way fibre cable up to 10 km distance up to 10 km distance 3 SC/ST fan out patch cord 3 FXG PHG * Mains power with automatic transfer switch (redundant mains input) to suit camera type 240Vac or 110Vac (IEC 60309) ­32 www.lemo.com ® ® MULTISHACK 6XTM conversion system Technical characteristics Characteristics Values Characteristics Values Fibre type Singlemode Electrical 1) Hybrid connector LEMO 3K.93C series Laser safety 2) Multifibre connector LEMO 5K series Humidity range Up to 95% Temperature range -20°C to +60°C Warranty 5 years CCU supply voltage range 15 V to 360 V Return loss Better than 45 dB per channel EMI/RFI Complies with 89/336/EEC Average insertion loss 0.4 dB per channel Note: 1) Complies with EN 61000-6-1, EN61000-6-2. 2) Complies with Class 1 laser product 24 CFR 1040.10 & 1040.11. Part number Manufacturer Description No PXE.MX.C61.AS SONY® (blue) PFD.MX.V16.AS SONY® Camera end/for Sony® model/6 way (blue) CCU end/for PFT.MX.R16.AS SONY® (blue) Break out box for ST fibre Camera end 3 PTE.MX.R61.AS SONY® (blue) Break out box for ST fibre CCU end 4 PFC.MX.R16.AS SONY® (blue) Break out box for SC fibre Camera end 3 PCE.MX.R61.AS SONY® (blue) Break out box for SC fibre CCU end 4 Sony® CAMERA SIDE camera model/6 way 1 2 Notes: For a Grass Valley™ version, replace last digit of the part number «S» by «T». Sony® version is blue and Grass ValleyTM version is grey. CCU SIDE CCU SIDE SMPTE 304 1 EDW 2 Mains power * FXG FXW EGG 4 SMPTE 304 EDW (6x) up to 10 km distance 6 SC/ST fan out patch cord 2 3 EGG Mains power * SMPTE 304 FXG PHG FGG FXG PHG 12 way fibre cable up to 10 km distance * Mains power with automatic transfer switch (redundant mains input) to suit camera type 240Vac or 110Vac (IEC 60309) www.lemo.com ­33 ® ® HD Z-LINKTM fibre optic link system The HD Z-Link fibre optic camera link system from LEMO provides multi-channel system camera-style video and audio connections, and control for studio cameras and camcorders alike over a single hybrid cable using LEMO 3K.93C connectors. The use of high bandwidth fibre optics and the multiplexing of numerous forward and return video, audio, talkback and data channels provides full communication with any camera position. The HD Z-Link is compatible with a wide ranges of cameras from top end digital cinematography cameras, broadcast system cameras and cam­corders, professional cameras and camcorders and top end consumer cameras from Sony, Thomson, Hitachi, Ikegami, and Panasonic, to name a few, to low cost handheld camcorders. The dual 1.5Gb/s HD SDI option allows support of stereoscopic (3D) implementations of the Red One® (and other cameras). The HD Z-Link is able to carry 3Gb/s HD SDI which gives it a competitive advantage over the 2.5Gb/s products that do not support 1080P. The base unit incorporates a menu-driven front panel control for ease of configuration of your camera system. The system offers automatic Genlock/synchroniser management facilities. Additional features include full audio with 8 digital stereo channels and intercom systems. An extensive range of connectors is provided to enable connection of most camera types and ethernet connectivity is also provided. A clip-on in-line power supply option is also available providing up to 120W. HD Z-Link Camera side FUW.3K.93C 2 km - SMPTE 311 M cable / ARIB BTA S-1005B ® ® PUW.3K.93C HD Z-Link - CCU side ­34 www.lemo.com ® HD Z-Link CCU side HD Z-Link camera side Part number Description Part number Description CHD.MZ.3KC.NVVF HD Z-LINK FULL FEATURE (Camera side) RHD.MZ.3KC.NZZB HD Z-LINK BASIC (CCU side) RHD.MZ.3KC.NZZF HD Z-LINK FULL FEATURE (CCU side) PHD.MZ.3KC.NVVZ HYBRID POWER (Camera side) CHD.MZ.3KC.NVVB HD Z-LINK BASIC (Camera side) THD.MZ.3KC.NZZZ HYBRID POWER (CCU side) HD Z-Link with all options Basic HD Z-Link l l 3G 1080P 50Hz or 59.94Hz programme video l l HD 1.5Gb/s programme video l l Dual HD channel programme video for stereoscopic (3D) l l Dual link HD to 3G conversion (Level B) l l 3G 1080P return video l l Analogue video l l Basic camera reference connection l l Gearsync (Automatic Genlock/ Synchroniser management) l l 8 stereo digital audio channels + 1 stereo analogue audio channel l l Two-channel intercom l l Multisystem intercom l l Front panel menu-driven control unit l l Test pattern generator l l HD to SD monitoring down converter l l Ethernet port l l Compatible with all SD cameras l l 1) Description Compatible with all HD cameras l l 9V supply for Camcorders l l Hybrid power option (120W) www.lemo.com ® Note: 1) not 3G 1080P. ­35 ® ® Note ­36 www.lemo.com ® ® Note www.lemo.com ­37 ® ® Note ­38 www.lemo.com ® ® Product safety notice PLEASE READ AND FOLLOW ALL INSTRUCTIONS CAREFULLY AND CONSULT ALL RELEVENT NATIONAL AND INTERNATIONAL SAFETY REGULATIONS FOR YOUR APPLICATION. IMPROPER HANDLING, CABLE ASSEMBLY, OR WRONG USE OF CONNECTORS CAN RESULT IN HAZARDOUS SITUATIONS. 1. SHOCK AND FIRE HAZARD Incorrect wiring, the use of damaged components, presence of foreign objects (such as metal debris), and / or residue (such as cleaning fluids), can result in short circuits, overheating, and / or risk of electric shock. Mated components should never be disconnected while live as this may result in an exposed electric arc and local overheating, resulting in possible damage to components. 2. HANDLING Connectors and their components should be visually inspected for damage prior to installation and assembly. Suspect components should be rejected or returned to the factory for verification. Connector assembly and installation should only be carried out by properly trained personnel. Proper tools must be used during installation and / or assembly in order to obtain safe and reliable performance. 3. USE Connectors with exposed contacts should never be live (or on the current supply side of a circuit). Under general conditions voltages above 30 VAC and 42 VDC are considered hazardous and proper measures should be taken to eliminate all risk of transmission of such voltages to any exposed metal part of the connector. 4. TEST AND OPERATING VOLTAGES The maximum admissible operating voltage depends upon the national or international standards in force for the application in question. Air and creepage distances impact the operating voltage; reference values are indicated in the catalog however these may be influenced by PC board design and / or wiring harnesses. The test voltage indicated in the catalog is 75% of the mean breakdown voltage; the test is applied at 500 V/s and the test duration is 1 minute. 5. CE MARKING CE marking means that the appliance or equipment bearing it complies with the protection requirements of one or several European safety directives. CE marking applies to complete products or equipment, but not to electromechanical components, such as connectors. 6. PRODUCT IMPROVEMENTS The LEMO Group reserves the right to modify and improve to our products or specifications without providing prior notification. 7. WARNING (Prop 65 State of California) Proposition 65 requires businesses to provide warnings to Californians about significant exposures to chemicals that cause cancer, birth defects or other reproductive harm. LEMO products are exempt from proposition 65 warnings because they are manufactured, marketed, and sold solely for commercial and industrial use. For further information, please visit https://www.lemo.com/quality/LEMO-Prop-65-compliance-declaration.pdf. Disclaimers LEMO works constantly to improve the quality of its products; the information and illustrations figuring in this document may therefore vary and are not binding. In any case, LEMO makes no specific warranty of merchantability, fitness for a particular purpose, third party components as such or included in assembly, non-infringement, title, accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO component. In no event shall LEMO, its affiliates, officers, agents or employees be liable for any incidental, indirect, special or consequential damages in connection with the products or services provided by LEMO, including (without limitation) loss of profits or revenues, interruption of business, loss of use of the products or any associated equipment, materials, components or products, damages to associated equipment or in combination with other components, materials. Reproduction of significant portions of LEMO information in LEMO data books or data sheets is permissible only if reproduction is without alteration and is accompanied by all associated warranties, conditions, limitations, and notices. LEMO is not responsible or liable for such altered documentation. Information of third parties may be subject to additional restrictions. www.lemo.com ­39 LEMO HEADQUARTERS SWITZERLAND LEMO SA Chemin des Champs-Courbes 28 - P.O. Box 194 - CH-1024 Ecublens Tel. +41 21 695 16 00 - e-mail: info@lemo.com SUBSIDIARIES AUSTRIA LEMO Elektronik GesmbH Lemböckgasse 49/E6-3 1230 Wien Tel: +43 1 914 23 20 0 Fax:+43 1 914 23 20 11 salesAT@lemo.com BRAZIL LEMO Latin America Ltda Av. Dr. Adhemar de Barros, 566 – Sala 1407, Vila Adyana CEP: 12245-011 São José dos Campos - SP - Brazil Tel: +55 11 94242 4293 info-la@lemo.com CANADA LEMO Canada Inc 44 East Beaver Creek Road, unit 20 Richmond Hill, Ontario L4B 1G8 Tel: +1 905 889 56 78 Fax: +1 905 889 49 70 info-canada@lemo.com CHINA / HONG KONG LEMO Electronics (Shanghai) Co., Ltd First Floor, Block E, 18 Jindian Road, Pudong Shanghai, China, 201206 Tel: +86 21 5899 7721 Fax: +86 21 5899 7727 cn.sales@lemo.com DENMARK LEMO Denmark A/S Mandal Allé 16A 5500 Middelfart Tel: +45 45 20 44 00 Fax: +45 45 20 44 01 info-dk@lemo.com FRANCE LEMO France Sàrl 24/28 Avenue Graham Bell Bâtiment Balthus 4 Bussy Saint Georges 77607 Marne la Vallée Cedex 3 Tel: +33 1 60 94 60 94 Fax: +33 1 60 94 60 90 info-fr@lemo.com GERMANY LEMO Elektronik GmbH Hanns-Schwindt-Str. 6 81829 München Tel: +49 89 42 77 03 Fax: +49 89 420 21 92 info@lemo.de HUNGARY REDEL Elektronika Kft Nagysándor József u. 6-12 1201 Budapest Tel: +36 1 421 47 10 Fax: +36 1 421 47 57 info-hu@lemo.com ITALY LEMO Italia srl Viale Lunigiana 25 20125 Milano Tel: +39 02 66 71 10 46 Fax: +39 02 37 90 80 46 sales.it@lemo.com JAPAN LEMO Japan Ltd 2-7-22, Mita, Minato-ku, Tokyo, 108-0073 Tel: +81 3 54 46 55 10 Fax: +81 3 54 46 55 11 info-jp@lemo.com LEMO NETHERLANDS / BELGIUM LEMO Connectors Nederland B.V. Jacques Meuwissenweg 6 2031 AD Haarlem Tel. +31 23 206 07 01 info-nl@lemo.com NORWAY / ICELAND LEMO Norway A/S Soerumsandvegen 69, 1920 Soerumsand Tel: +47 22 91 70 40 Fax: +47 22 91 70 41 info-no@lemo.com SINGAPORE LEMO Asia Pte Ltd 4 Leng Kee Road, #06-09 SiS Building Singapore 159088 Tel: +65 6476 0672 Fax: +65 6474 0672 sg.sales@lemo.com SPAIN / PORTUGAL IBERLEMO SAU Brasil, 45, 08402 Granollers Barcelona Tel: +34 93 860 44 20 Fax: +34 93 879 10 77 info-es@lemo.com SWEDEN / FINLAND LEMO Nordic AB Gunnebogatan 30 163 53 Spånga Tel: +46 8 635 60 60 Fax: +46 8 635 60 61 info-se@lemo.com SWITZERLAND LEMO Verkauf AG Grundstrasse 22 B, 6343 Rotkreuz Tel: +41 41 790 49 40 ch.sales@lemo.com TAIWAN TAOYUAN TAIWAN Tel: +886 967 132 824 speng@lemo.com UNITED ARAB EMIRATES LEMO Middle East Connectors LLC Concorde Tower 11th Floor, Office 1102, Dubai Media City, P.O. Box 449849 Dubai, United Arab Emirates Tel: +971 4 568 1904 info-me@lemo.com UNITED KINGDOM LEMO UK Ltd 12-20 North Street, Worthing, West Sussex, BN11 1DU Tel: +44 1903 23 45 43 lemouk@lemo.com USA LEMO USA Inc P.O. Box 2408 Rohnert Park, CA 94927-2408 Tel: +1 707 578 88 11 +1 800 444 53 66 Fax: +1 707 578 08 69 info-US@lemo.com DISTRIBUTORS ARGENTINA, AUSTRALIA, BRAZIL, CHILE, COLOMBIA, CZECH REPUBLIC, GREECE, INDIA, ISRAEL, NEW ZEALAND, PERU, POLAND, SOUTH AFRICA, SOUTH KOREA, TURKEY, UKRAINE www.lemo.com CAT.MD.LEN.P0415, © LEMO / Data subject to change, printed in Switzerland, updated September 2022 LEMO
WST.OU.110.20PN 价格&库存
很抱歉,暂时无法提供与“WST.OU.110.20PN”相匹配的价格&库存,您可以联系我们找货
