0155-25A
0155-25A
    GREENLEECOMMUNICATIONS(格林利)
    RULE POWER RETURN 25'
0155-25A 数据手册
RULE,POWER RETURN 25' (POP) Power Return Tape Measure, double tang/sided, 25' Cat No: 0155-25A UPC No: 783310124795 Description • • • • • • • • Compact housing fits easliy in the hand or pouch Easy to use Click Lock holds tape securely Tough ABS case with rubber over mold Rigid 1" wide nylon coated blade is double-sided Multi-riveted double tang foot for strength 16 IN and 19.2 IN stud markings 0155-7MA has Metric and English markings Note: This is not an insulated tool Specifications • • • • • • • Case Material : Tough ABS Case With Rubber Over Mold Coating : Nylon Blade Length : 25.000 FT Standout : 6.000 FT Type : Power Return Weight : 0.890 LB (0.400 KG) Width : 1.000 IN (2.500 CM)
0155-25A 价格&库存
很抱歉,暂时无法提供与“0155-25A”相匹配的价格&库存,您可以联系我们找货
