0155-7MA
0155-7MA
    GREENLEECOMMUNICATIONS(格林利)
    RULE POWER RETURN 7.5M DUAL
0155-7MA 数据手册
RULE,POWER RETURN 7.5M DUAL (POP) Power Return Tape Measure, double tang/sided, 7.5 meter Cat No: 0155-7MA UPC No: 783310124771 Description • • • • • • • • "Compact housing fits easliy in the hand or pouch Easy to use Click Lock holds tape securely Tough ABS case with rubberover mold Rigid 1"" wide nylon coated blade is double-sided Multi-riveted double tang foot for strength 16 IN and 19.2 IN stud markings 0155-7MA has Metric and English markings Note: This is not an insulated tool " Specifications • • • • • • • • Case Material : Tough ABS Case With Rubber Over Mold Coating : Nylon Blade Length : 7.500 FT Marking Type : Metric And English Standout : 6.000 FT Type : Power Return Weight : 0.890 LB (0.400 KG) Width : 1.000 IN (2.500 CM)
0155-7MA 价格&库存
很抱歉,暂时无法提供与“0155-7MA”相匹配的价格&库存,您可以联系我们找货
