ESSENTIAL TOOLS
TO KEEP THE JOB SITE SAFE AND PRODUCTIVE
WORK@HEIGHT T O O L S
In private industry, falling objects accounted for 10% of worker fatalities in 2013.
In 2012, falling objects caused 18% of contractor deaths, a 7% increase from 2011.
OSHA ranks being “struck by objects” as the third leading cause of disabling workplace injuries.
Klein Tools’ growing line of tethers and tools for Work@Height are designed to protect
workers on the job site as well as their tools.
Tool Tethers
Triple-locking
carabiner for
additional safety
• Keep your tools close at hand while working at height
• Allow for easy tool recovery in case of accidental drops
Always use choke hitch
formation
Attach tether through tether
hole when available
Always use a load bearing
anchor or attachment point
Cat. No.
UPC Code
0-92644-
Maximum
Load Capacity
Relaxed
Length
Stretched
Length
TT1
46000-5
10 lbs (4.5 kg)
32" (813 mm)
60" (1.5 m)
TT2
59006-1
15 lbs (4.5 kg)
32" (813 mm)
51" (1.3 m)
WARNINGS:
• Inspect for wear before each use.
• Do not use for human support.
• Never connect over 5 lbs. (2.3 kg) to a person.
• Do not use around moving or rotating equipment.
WARNINGS:
• Tethers extend to anywhere from 3.5' to 5' (1.3 m to 1.5 m).
Rig to avoid contact with objects below.
• Always ensure cinch remains snug while in use.
• Always attach carabiner end to anchor point.
• Do not attach tether back onto itself.
• Do not tie knots in tether.
TT2
TT1
36" (914 mm) Round Bar
• Forged fit-up bar is pointed on one end
for aligning bolt holes
• 15° angle chisel-end provides greater leverage
Cat. No.
3246TT
UPC Code
0-92644+
66000-9
Diameter
Length
7/8" (22 mm)
36" (914 mm)
3246TT
Tether hole
Provides extra leverage when positioning
steel members and aligning bolt holes
Split ring for
tethering
D228-8TT
D248-9STT
D213-9NETT
D213-9STT
D201-7CSTT
Pliers with Tether Ring
• High-leverage designs. Rivet is closer to the cutting edge for greater cutting power than other plier designs
• Angled head design of the diagonal-cutting pliers allow for easy work in confined spaces
• Side-cutting pliers feature a streamlined design with sure-gripping, cross-hatched knurled jaws
• Cat. No. D248-9STT, D213-9STT and D201-7CSTT feature a hook-bend in the handle for added grip and
leverage. Unique handle tempering helps absorb the “snap” when cutting wire.
UPC Code
0-92644+
Cat. No.
Nose Type
Jaw
Length
Jaw
Thickness
Jaw
Width
Knife
Length
Overall
Length
High-Leverage Diagonal-Cutting Pliers
D228-8TT
72037-6
13/16" (21 mm)
7/16" (11 mm)
1-3/16" (30 mm)
8-1/16" (205 mm)
D248-9STT
72049-9
13/16" (21 mm)
7/16" (11 mm)
1-3/16" (30 mm)
9-3/16" (233 mm)
High-Leverage Side-Cutting Pliers
D213-9NETT
70104-7
New England
1-19/32" (41 mm)
5/8" (16 mm)
1-1/4" (32 mm)
25/32" (20 mm)
9-3/8" (238 mm)
D213-9STT
70087-3
Square
1-9/32" (33 mm)
5/8" (16 mm)
1-1/4" (32 mm)
25/32" (20 mm)
9-1/8" (232 mm)
D201-7CSTT
70102-3
Square
1-9/32" (33 mm)
1/2" (13 mm)
1-5/32" (29 mm)
5/8" (16 mm)
9-1/4" (235 mm)
Headlamp
Anti-slip silicone strap keeps headlamp securely
150
150
fastened to hard hat
Lumens
Lumens
6h
6h
• Strap comes pre-adjusted for quick fit to hard hat
• 45-degree tilt for varied beam direction to point light
where it is needed most
50
50
Code Lumens
10h
10h
Lumens
LumensUPC
0-92644-
Run Time
Drop
Height
Batteries
56220
6 hrs / 10 hrs
6 ft.
3xAAA
Cat. No
66ftft
56220-4
150 / 50
FL 1 STANDARD
Spotlight
Two Modes:
150
Lumens
Floodlight
FL 1 STANDARD
150
Lumens
6h
50
Lumens
10h
Impact and water resistant
6h
FL 1 STANDARD
50
Lumens
6 ft
10h
Erection Wrenches with Tether Hole
Tether hole
• Forged from select alloy steel to withstand high-leverage and heavy loads
• Continuous taper of handle makes lining-up bolt holes easy and works on
a range of bolt-hole sizes without binding
• Extra-large hub area works on larger diameter holes better than other wrenches
• Catalog number, bolt size and nominal opening size are stamped on every
wrench for easy identification
Cat. No
Bolt Size
Nominal
Opening
3/4" (19 mm) 1-1/4" (32 mm)
Head Width
3212TT
UPC Code Nut Type
0-9264468071-7
U.S. Heavy
3213TT
68069-4
U.S. Heavy
7/8" (22 mm) 1-7/16" (37 mm)
3214TT
68070-0
U.S. Heavy
1" (25 mm)
3-5/8" (92 mm)
1-1/8" to 1/4" (29 mm to 6 mm)
1-5/8" (41 mm)
Taper Diameter
Length
2-1/2" (64 mm)
1" to 1/4" (25 mm to 6 mm)
16-5/8" (422 mm)
3" (76 mm)
1-1/8" to 9/32" (29 mm to 7 mm) 17-3/4" (451 mm)
3212TT
18" (457mm)
Adjustable Head Wrenches with Tether Hole
• Each wrench fits a variety of sizes of nuts and bolts
• Continuous-taper handle to help align bolt and rivet holes
• Industrial black finish for corrosion resistance
• Lanyard hole for easy tool tethering
Tether hole
Cat. No
UPC Code
0-92644-
Description
Maximum Size
Capacity
Length
3227
67017-6
10" (254 mm) Spud Wrench
1-5/16" (33 mm)
11" (279 mm)
3239
67095-4
16" (406 mm) Construction Wrench
1-1/2" (38 mm)
16" (406 mm)
3227
Bull-Pins with Tether Hole
Tether hole
• Broad-head design provides larger striking surface and reduces
chance of slipping from the hand when aligning holes
Machined from quality alloy steel that is heat-treated for strength
Rust resistant
Cat. No.
3255TT
3256TT
UPC Code
0-92644+
48001-0
48002-7
Material
Length
Point Diameter
Top Diameter
Steel
Steel
13-3/4" (349 mm)
10" (254 mm)
5/16" (8 mm)
1/4" (6 mm)
1-1/4" (32 mm)
1-1/16" (27 mm)
Bull-Pin and Bolt Bags
Tether anchor points
• Bull pin loops on each side for easy access
• Double bottom provides additional strength
• Cat. No. 5416OCTO has two D-rings on the front of the pouch
3255TT
and four on the inside for plenty of space to connect tethers
Cat. No. 5416TC and 5416TCP have drawstring closure on top
Cat. No
UPC Code
0-92644-
Belt
Capacity
Belt
Length
Connection
Width
Depth
5416OCTO
55387-5
up to 3" (76 mm) wide loop
5" (127 mm)
9" (229 mm)
9" (229 mm)
5416TC
55229-8
up to 3" (76 mm) wide tunnel
5" (127 mm)
9" (229 mm)
10" (254 mm)
5416TCP
20017-5
5" (127 mm)
9" (229 mm)
12" (305 mm)
5416OCTO
5416TCP
Load Rated Bucket with Connection Points
• Six small D-rings sewn to the interior of the bucket
100 lbs. (45kg)
provide secure connection points for tethers
Extra large hook to fit onto oversized rigging equipment
Leather reinforced bottom
Made of heavy-duty canvas to withstand harsh job site conditions
Features web straps extending down the side for additional strength
Cat. No
UPC Code
0-92644-
Height
Diameter
5104OCTO
61000-4
17" (432 mm)
12" (305 mm)
5104OCTO
Load Rated Top Closing Canvas Buckets
• Made of heavy-duty canvas to withstand harsh job site conditions
• Leather reinforced bottom extends 3" (76 mm) up the side
• Durable top ring maintains bucket shape
• 5104CLR17 and 5104CLR22 feature web straps extending
Cat. No.
UPC Code
0-92644-
Load
Rating
Top
Closure
Diameter
Height
5104CLR17
62017-1
150 lbs. (68 kg)
zipper
14" (356 mm) 17" (439 mm)
5104CLR22
62016-4
150 lbs. (68 kg)
zipper
5104VT
55285-4
100 lbs. (45 kg)
VELCRO
14" (356 mm) 22" (559 mm)
12" (305 mm) 17" (432 mm)
VELCRO® is a registered trademark of Velcro Industries B.V.
WARNINGS: Completely close top before each use.
14" diameter accommodates
standard 5 gallon bucket.
5104CLR17
5104CLR22
5104VT
Vinyl Bucket Top
• Compatible with Klein Tools 5104 and 5109 series buckets
• Attaches with Velcro
• Includes safety strap loop to ensure connection to bucket
• Bucket not included
51TOP
Cat. No
UPC Code 0-92644-
Height
Diameter
51TOP
61000-4
3.5" (89 mm)
12.5" (318 mm)
Flame-Retardant Storage
• Provides added protection when welding and grinding in the field
• Pouches meet the performance requirements of NFPA-701
Cat. No.
UPC Code Belt
0-92644+
Capacity
#4 Flame-Retardant Canvas Bolt Bag
5416TFR
55529-9
Cat. No. UPC Code Back
0-92644+
Depth
#4 Flame-Retardant Electrode Bag
5471FR
55530-5
15-1/2" (394 mm)
Belt
Connection
Length
Width
Tunnel
Diameter
5" (127 mm)
Front
Depth
9" (229 mm)
Width
2-1/2" (64 mm)
12" (305 mm)
N/A
5416TFR
5471FR
Heavy-Duty Torpedo Level with Tether Ring
• Powerful rare-earth magnets,10x stronger than
strip magnets, hold firmly to iron and steel surfaces
Strong split ring
for tethering
• Three acrylic vials – plumb, level and 45° provide
the necessary jobsite measurements
• Top read level window simplifies viewing in tight areas
Cat. No.
931-9RETT
UPC Code 0-92644+
93000-3
Overall Length
9" (229 mm)
931-9RETT
Tape Measure Holder with Tether Ring
• Elastic bottom and hook-and-loop closure ensure this
holder will fit most 25' and 30' tape measures securely
• Includes D-ring on top for tethering
• Reinforced stitching to add strength
Cat. No
UPC Code
0-92644-
Overall Size
5195TT
55537-4
3" x 3.5" x 2" (76 mm x 89 mm x 50 mm)
5195TT
See our complete line of Work@Height Tools & Accessories
www.kleintools.com/workatheight
© 2016 Klein Tools, Inc.
Lincolnshire, IL 60069-1418
96429 03/16 Rev. B
很抱歉,暂时无法提供与“TT1”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+194.929951+25.00186
