DDKIT-1-68
DDKIT-1-68
    GREENLEECOMMUNICATIONS(格林利)
    DRILL DRIVER BIT KIT
DDKIT-1-68 数据手册
DRILL DRIVER BIT KIT (POP) 68-Piece Electricians Drill/Driver Kit Cat No: DDKIT-1-68 UPC No: 783310263135 Description • • • • • • • • 1/4 IN Quick Change technology Professional grade driver bits Titanium Nitride coated self-centering high speed drill bits High quality shock resistant case stays intact even after accidental drops Hammer drill rated carbidegrade tips and hardened shankmasonry drill bits Hardened forged magnetic nut drivers fit most TapCon fasteners Quick release chuck with precise fit Includes security bits that fit most security fasteners frequently used in public facilities Specifications • • • • • • Consists Of : ƕ 1/8 IN, 3/16 IN, 1/4 IN High Speed Titanium Coated Drill Bit Set ƕ MAS-SET (5/32 IN, 3/16 IN,1/4 IN, 3/8 IN) Masonry DrillBit Set ƕ NDS-SET (1/4 IN, 5/16 IN, 3/8 IN) Magnetic Nut Driver Set ƕ QCS-1 1/4 IN Quick Change Chuck ƕ EXT-3 Magnetic Bit Extension ƕ SBSET-1-14 (Spanner Security Bits - #6, #8, #10, #12, Torx Security Bits - T10, T15, T20, T25, T27, T30, Hex Security Bits - 1/8 IN, 9/64 IN, 5/32IN, 3/16 IN) Security Driver Bit Set Number Of Pieces : 68 Replacement Part : EXT-3 Magnetic Bit Extension,HSS-SET High Speed Titanium Coated Drill Bit Set (1/8 IN, 3/16 IN, 1/4 IN), MAS-SET Masonry Drill Bit Set (5/32 IN, 3/16 IN, 1/4 IN, 3/8 IN), NDS-SETMagnetic Nut Driver Set (1/4 IN, 5/16 IN, 3/8 IN), QCS-1 1/4 IN Quick Chang Size : 12.320 IN (313.000 MM) LengthX 10.750 IN (273.000 MM) Width X 1.950 IN (49.000 MM) Height Type : Electrician's Weight : 2.350 LB (1.060 KG)
DDKIT-1-68 价格&库存
很抱歉,暂时无法提供与“DDKIT-1-68”相匹配的价格&库存,您可以联系我们找货
