MagnumPRO
Fish Tapes
Your
Experts
Greenlee has always offered our
customers a family of Fish Tapes for
every type of fishing application that
are designed to outperform and outlast
the competition on the jobsite. Now,
we’re offering a new generation of
Fish Tapes with advanced ergonomics
and functionality as well as improved
ruggedness for tough job site conditions.
For example, Greenlee’s new rugged
case design and comfort grip give you
increased productivity with reduced
fatigue and longer tool life. So, whether
you’re fishing a few short feet or through
a number of walls and bends, Greenlee’s
Fish Tapes will make the job easier.
MagnumPRO
Fish Tapes
Advanced
comfort handle grip
reduces fatigue
Superior
Viewing Port
gives visibility to remaining
tape and ability to remove
jobsite debris quickly
rapid tape pay-out and rewind
(Patent Pending)
Smaller Fish Eye
with offset bend for improved
fishing ability
360° Uniform Grip
no bump case design reduces fatigue
(Patent Pending)
Flared Case
with Grip Ridges for no slip handling
Rugged Case
design improves drop impact capability
MagnumPRO
Fish Tapes are available in
several different materials
to fit the need of your job.
Whether your application
is fishing wire or cable in a
new construction building
or you have existing wires
to work around, Greenlee
has developed these
products with you in mind.
• Oil-Tempered
Spring Steel
• Stainless Steel
• Flexible Steel Cable
• Nylon
• Fiberglass
MagnumPRO
All MagnumPRO Fish Tapes Feature:
• Advanced comfort grip and rugged case design (Patent Pending)
• Superior rapid grip tape payout and rewind (Patent Pending)
• Viewing ports to see amount of tape in case and allow quick debris removal
Oil-Tempered Spring Steel
Used for general fishing in conduit
• Maximum durability
• Improved low profile tip for easy fishing through all sizes of conduit
• Available in 50'(15.2m), 65'(19.8m), 125'(38.1m) and 240'(73.2m) lengths
• 1/8", 1/4" and flat steel profiles to accommodate different fishing situations
Catalog #
* FTS438-65
RS438-65
* FTS438-125
RS438-125
* FTS438-240
RS438-240
FTS438W-100
RS438W-100
S438W-200
438-5H
438-2X
R438B
R438-BM
439-1
10051
10052
Weight
(lbs.)
UPC #
Description
12729
12469
12709
12470
12730
12471
12710
12472
12476
07500
01696
29367
05853
30859
10051
10052
Steel Fish Tape - 1/8" x 65'
Replacement Steel Tape - 65' (NO CASE)
Steel Fish Tape - 1/8" x 125'
Replacement Steel Tape - 125' (NO CASE)
Steel Fish Tape - 1/8" x 240'
Replacement Steel Tape - 240' (NO CASE)
Steel Fish Tape - 1/4" x 100'
Replacement Steel Tape - 1/4" x 100' (NO CASE)
Steel Fish Tape - 1/4" x 200' (NO CASE)
Steel Fish Tape - 1/8" x 50'
Steel Fish Tape - 1/4" x 25' (Flat Steel Tape)
Swivel Ball Head for use with 1/8" Steel Fish Tapes
Ball Tip Male Half
12" Flexible Fish Tape Leader
8-1/2" Case/Handle Replacement Kit
12" Case/Handle Replacement Kit
* Bulk Pack Available
= Replacement Part
= Accessory
438-2X
438-5H
RS438-125
FTS438-125
3.1
1.1
5.5
2.3
8.5
5.2
7.2
5.6
10.9
2.8
1.3
0.1
0.1
0.1
1.4
2.0
FTS438-65
Stainless Steel
Used in general fishing in conduit & harsh environmental situations
• Corrosion free stainless steel tape for maximum life
• Fish further and faster with Speed Flex leader
• Available in 100'(30.5m) and 200'(61m) lengths
• Replaceable Speed Flex leader
Catalog #
UPC #
Description
FTSS438-100
RSS438-100
FTSS438-200
RSS438-200
439-2
10052
12711
12480
12712
12481
14392
10052
Stainless Steel Fish Tape - 1/8" x 100'
Replacement Stainless Steel Tape - 100' (NO CASE)
Stainless Steel Fish Tape - 1/8" x 200'
Replacement Stainless Steel Tape - 200' (NO CASE)
12" SPEED FLEX Leader (Solder Joint)
FTSS438-100
Weight
(lbs.)
4.8
1.9
7.4
4.4
0.1
2.0
= Replacement Part
More flexible than steel, stronger than fiberglass or nylon and
slips through lateral & vertical bends in the same run
FTFS439-50
• Multi-strand steel cable for maximum flexibility
• Available in 50'(15.2m) and 100'(30.5m) lengths
Catalog #
UPC #
Description
FTFS439-50
FTFS439-100
FS439-100
10052
12713
12714
12482
10052
Flexible Steel Fish Tape - 3/16" x 50'
Flexible Steel Fish Tape - 3/16" x 100'
Flexible Steel Fish Tape - 3/16" x 100' Double Tip (NO CASE)
= Replacement Part
= Accessory
Weight
(lbs.)
5.6
8.9
6.2
2.0
MagnumPRO
Nylon
Used in proximity to energized lines & more flexible than steel
• Non-conductive, curl-resistant nylon tape for fast, clean fishing
• Good for fishing in conduit with wire or cable present
• Replaceable tip
Catalog #
UPC #
Description
FTN536-50
RN536-50
FTN536-100
RN536-100
12715
12483
12716
12484
01664
01664
Nylon Fish Tape - 3/16" x 50'
Replacement Nylon Tape - 50' (NO CASE)
Nylon Fish Tape - 3/16" x 100'
Replacement Nylon Tape - 100' (NO CASE)
Replacement Tip for 436 Nylon Fish Tape (Requires Greenlee K05 or
K09 series crimper or #6 hex crimp to install)
10052
= Replacement Part
10052
FTN536-50
Weight
(lbs.)
2.9
0.3
3.6
1.0
0.1
2.0
= Accessory
Fiberglass
Used in proximity to energized lines & where good flexibility is desired
• Non-conductive fiberglass tape with patented low-friction coating for faster
and easier fishing
• Perfect for fishing in conduit with wire or cable present
• Available in 50'(15.2m), 100'(30.5m), 200'(61m) and 250'(76.2m) lengths
• Replaceable tips
Catalog #
UPC #
Description
FTF540-50
FTF540-100
R540-100
542-150
05156
542-200
05157
542-250
05158
10565
12717
12718
35744
35745
05156
35746
05157
35747
05158
10565
35750
35750
35908
35908
35909
35909
35919
35930
10052
35919
35930
10052
Fiberglass Fish Tape - 11/64" x 50'
Fiberglass Fish Tape - 11/64" x 100'
Replacement Fiberglass Tape - 11/64" X100' (NO CASE)
Fiberglass Fish Tape - 3/16" x 150' (IN REEL STAND)
Replacement Fiberglass Tape - 3/16" x 150' (NO CASE)
Fiberglass Fish Tape - 3/16" x 200' (IN REEL STAND)
Replacement Fiberglass Tape - 3/16" x 200' (NO CASE)
Fiberglass Fish Tape - 3/16" x 250' (IN REEL STAND)
Replacement Fiberglass Tape - 3/16" x 250' (NO CASE)
Pulling Eye Repair Kit (Kit includes: pulling eye and adhesive)
Accessory Kit for 3/16" Fish Tapes (Kit includes: flexible pulling leader,
flexible pushing leader, pulling eye, splice ferrule and threaded ferrule
1/8" (3 mm) Repair Kit
(Kit includes: threaded end ferrule, splice ferrule and pulling eye)
3/16" (4.7 mm) Repair Kit
1/8" (3 mm) Pulling Eye
3/16" (4.7 mm) Pulling Eye
= Replacement Part
= Accessory
FTF540-50
Weight
(lbs.)
2.8
3.4
0.9
15.0
2.0
16.0
3.0
17.0
6.5
0.1
0.5
0.1
0.1
0.1
0.1
2.0
542-150
Along with Greenlee's extensive line of Fish Tapes,
you may also be interested in the following fishing
products to help you on the job:
Glo Stix®
Fish Poles
Glow in the dark to make fishing
VDV wire easier in the dark
Designed specifically for pushing and pulling
wires over long distances
Vacuum/Blower
Power Fishing
System
Includes everything to blow or
vacuum fish line, poly line
or measuring tape on
the jobsite
CableCaster®
50' range allows for
faster installation with
fewer pulls
www.greenlee.com
MA-5321 8/08
4455 Boeing Drive • Rockford, IL 61109-2988 • USA • 815-397-7070
©2008 Greenlee Textron Inc. • An ISO 9001 Company • Printed in USA
Greenlee Textron Inc. is a subsidiary of Textron Inc.
Poly Line
Easily pulls wire or rope
through conduit
很抱歉,暂时无法提供与“FTN536-100”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+1532.201081+198.18151
