FTSS438-200
FTSS438-200
    GREENLEECOMMUNICATIONS(格林利)
    FISHTAPE STAINLESS STEEL-200'
FTSS438-200 数据手册
MagnumPRO ™ Fish Tapes Your Experts Greenlee has always offered our customers a family of Fish Tapes for every type of fishing application that are designed to outperform and outlast the competition on the jobsite. Now, we’re offering a new generation of Fish Tapes with advanced ergonomics and functionality as well as improved ruggedness for tough job site conditions. For example, Greenlee’s new rugged case design and comfort grip give you increased productivity with reduced fatigue and longer tool life. So, whether you’re fishing a few short feet or through a number of walls and bends, Greenlee’s Fish Tapes will make the job easier. MagnumPRO ™ Fish Tapes Advanced comfort handle grip reduces fatigue Superior Viewing Port gives visibility to remaining tape and ability to remove jobsite debris quickly rapid tape pay-out and rewind (Patent Pending) Smaller Fish Eye with offset bend for improved fishing ability 360° Uniform Grip no bump case design reduces fatigue (Patent Pending) Flared Case with Grip Ridges for no slip handling Rugged Case design improves drop impact capability MagnumPRO ™ Fish Tapes are available in several different materials to fit the need of your job. Whether your application is fishing wire or cable in a new construction building or you have existing wires to work around, Greenlee has developed these products with you in mind. • Oil-Tempered Spring Steel • Stainless Steel • Flexible Steel Cable • Nylon • Fiberglass MagnumPRO ™ All MagnumPRO Fish Tapes Feature: ™ • Advanced comfort grip and rugged case design (Patent Pending) • Superior rapid grip tape payout and rewind (Patent Pending) • Viewing ports to see amount of tape in case and allow quick debris removal Oil-Tempered Spring Steel Used for general fishing in conduit • Maximum durability • Improved low profile tip for easy fishing through all sizes of conduit • Available in 50'(15.2m), 65'(19.8m), 125'(38.1m) and 240'(73.2m) lengths • 1/8", 1/4" and flat steel profiles to accommodate different fishing situations Catalog # * FTS438-65 RS438-65 * FTS438-125 RS438-125 * FTS438-240 RS438-240 FTS438W-100 RS438W-100 S438W-200 438-5H 438-2X R438B R438-BM 439-1 10051 10052 Weight (lbs.) UPC # Description 12729 12469 12709 12470 12730 12471 12710 12472 12476 07500 01696 29367 05853 30859 10051 10052 Steel Fish Tape - 1/8" x 65' Replacement Steel Tape - 65' (NO CASE) Steel Fish Tape - 1/8" x 125' Replacement Steel Tape - 125' (NO CASE) Steel Fish Tape - 1/8" x 240' Replacement Steel Tape - 240' (NO CASE) Steel Fish Tape - 1/4" x 100' Replacement Steel Tape - 1/4" x 100' (NO CASE) Steel Fish Tape - 1/4" x 200' (NO CASE) Steel Fish Tape - 1/8" x 50' Steel Fish Tape - 1/4" x 25' (Flat Steel Tape) Swivel Ball Head for use with 1/8" Steel Fish Tapes Ball Tip Male Half 12" Flexible Fish Tape Leader 8-1/2" Case/Handle Replacement Kit 12" Case/Handle Replacement Kit * Bulk Pack Available = Replacement Part = Accessory 438-2X 438-5H RS438-125 FTS438-125 3.1 1.1 5.5 2.3 8.5 5.2 7.2 5.6 10.9 2.8 1.3 0.1 0.1 0.1 1.4 2.0 FTS438-65 Stainless Steel Used in general fishing in conduit & harsh environmental situations • Corrosion free stainless steel tape for maximum life • Fish further and faster with Speed Flex leader • Available in 100'(30.5m) and 200'(61m) lengths • Replaceable Speed Flex leader Catalog # UPC # Description FTSS438-100 RSS438-100 FTSS438-200 RSS438-200 439-2 10052 12711 12480 12712 12481 14392 10052 Stainless Steel Fish Tape - 1/8" x 100' Replacement Stainless Steel Tape - 100' (NO CASE) Stainless Steel Fish Tape - 1/8" x 200' Replacement Stainless Steel Tape - 200' (NO CASE) 12" SPEED FLEX Leader (Solder Joint) 12" Case/Handle Replacement Kit FTSS438-100 Weight (lbs.) 4.8 1.9 7.4 4.4 0.1 2.0 = Replacement Part Flexible Steel Cable More flexible than steel, stronger than fiberglass or nylon and slips through lateral & vertical bends in the same run FTFS439-50 • Multi-strand steel cable for maximum flexibility • Available in 50'(15.2m) and 100'(30.5m) lengths Catalog # UPC # Description FTFS439-50 FTFS439-100 FS439-100 10052 12713 12714 12482 10052 Flexible Steel Fish Tape - 3/16" x 50' Flexible Steel Fish Tape - 3/16" x 100' Flexible Steel Fish Tape - 3/16" x 100' Double Tip (NO CASE) 12" Case/Handle Replacement Kit = Replacement Part = Accessory Weight (lbs.) 5.6 8.9 6.2 2.0 MagnumPRO ™ All MagnumPRO Fish Tapes Feature: ™ • Advanced comfort grip and rugged case design (Patent Pending) • Superior rapid grip tape payout and rewind (Patent Pending) • Viewing ports to see amount of tape in case and allow quick debris removal Nylon Used in proximity to energized lines & more flexible than steel • Non-conductive, curl-resistant nylon tape for fast, clean fishing • Good for fishing in conduit with wire or cable present • Available in 50'(15.2m) and 100'(30.5m) lengths • Replaceable tip Catalog # UPC # Description FTN536-50 RN536-50 FTN536-100 RN536-100 12715 12483 12716 12484 01664 01664 Nylon Fish Tape - 3/16" x 50' Replacement Nylon Tape - 50' (NO CASE) Nylon Fish Tape - 3/16" x 100' Replacement Nylon Tape - 100' (NO CASE) Replacement Tip for 436 Nylon Fish Tape (Requires Greenlee K05 or K09 series crimper or #6 hex crimp to install) 12" Case/Handle Replacement Kit 10052 = Replacement Part 10052 FTN536-50 Weight (lbs.) 2.9 0.3 3.6 1.0 0.1 2.0 = Accessory Fiberglass Used in proximity to energized lines & where good flexibility is desired • Non-conductive fiberglass tape with patented low-friction coating for faster and easier fishing • Perfect for fishing in conduit with wire or cable present • Available in 50'(15.2m), 100'(30.5m), 200'(61m) and 250'(76.2m) lengths • Replaceable tips Catalog # UPC # Description FTF540-50 FTF540-100 R540-100 542-150 05156 542-200 05157 542-250 05158 10565 12717 12718 35744 35745 05156 35746 05157 35747 05158 10565 35750 35750 35908 35908 35909 35909 35919 35930 10052 35919 35930 10052 Fiberglass Fish Tape - 11/64" x 50' Fiberglass Fish Tape - 11/64" x 100' Replacement Fiberglass Tape - 11/64" X100' (NO CASE) Fiberglass Fish Tape - 3/16" x 150' (IN REEL STAND) Replacement Fiberglass Tape - 3/16" x 150' (NO CASE) Fiberglass Fish Tape - 3/16" x 200' (IN REEL STAND) Replacement Fiberglass Tape - 3/16" x 200' (NO CASE) Fiberglass Fish Tape - 3/16" x 250' (IN REEL STAND) Replacement Fiberglass Tape - 3/16" x 250' (NO CASE) Pulling Eye Repair Kit (Kit includes: pulling eye and adhesive) Accessory Kit for 3/16" Fish Tapes (Kit includes: flexible pulling leader, flexible pushing leader, pulling eye, splice ferrule and threaded ferrule 1/8" (3 mm) Repair Kit (Kit includes: threaded end ferrule, splice ferrule and pulling eye) 3/16" (4.7 mm) Repair Kit (Kit includes: threaded end ferrule, splice ferrule and pulling eye) 1/8" (3 mm) Pulling Eye 3/16" (4.7 mm) Pulling Eye 12" Case/Handle Replacement Kit = Replacement Part = Accessory FTF540-50 Weight (lbs.) 2.8 3.4 0.9 15.0 2.0 16.0 3.0 17.0 6.5 0.1 0.5 0.1 0.1 0.1 0.1 2.0 542-150 Along with Greenlee's extensive line of Fish Tapes, you may also be interested in the following fishing products to help you on the job: Glo Stix® Fish Poles Glow in the dark to make fishing VDV wire easier in the dark Designed specifically for pushing and pulling wires over long distances Vacuum/Blower Power Fishing System Includes everything to blow or vacuum fish line, poly line or measuring tape on the jobsite CableCaster® 50' range allows for faster installation with fewer pulls www.greenlee.com MA-5321 8/08 4455 Boeing Drive • Rockford, IL 61109-2988 • USA • 815-397-7070 ©2008 Greenlee Textron Inc. • An ISO 9001 Company • Printed in USA Greenlee Textron Inc. is a subsidiary of Textron Inc. Poly Line Easily pulls wire or rope through conduit
FTSS438-200 价格&库存
很抱歉,暂时无法提供与“FTSS438-200”相匹配的价格&库存,您可以联系我们找货
FTSS438-200
  • 1+1499.941741+195.03374
