JIC-755
JIC-755
    JONARDTOOLS
    Cable Cutter Oval Crossing Blades 8.25" (209.6mm)
JIC-755 数据手册
MADE FOR LIFE® Premier Tool Manufacturer Since 1958 JIC-755 - 1” COAX Cable Cutter. - Data Sheet Designed to cut up to 1” coaxial cable. This tool works like a tube cutter to eliminate cable deformation during cable preparation. Tool provides precision one-handed cutting action. Made from Chrome Vanadium steel with hardened cutting blade. Not designed for ACSR or other steel cables. 8 1/4” long. Specifications Cut Type Cable Diameter Material Color Length Weight UPC No. Cable 1” Coax Chrome Vanadium Steel Yellow Handle 8-1/4” (209.55mm) 0.911 lbs 811490017283 134 Marbledale Road, Tuckahoe, NY 10707 | Tel 914.793.0700 | Fax 914.793.4527 | jonard.com
JIC-755 价格&库存
很抱歉,暂时无法提供与“JIC-755”相匹配的价格&库存,您可以联系我们找货
JIC-755
  • 1+353.114971+45.74074
