M405EC
M405EC
    SWANSTROM
    CUTTERSIDETPRDFULLFLUSH5.6"
M405EC 数据手册
CARBIDE CUTTERS CARBIDE TAPERED HEAD DIAGONAL CUTTERS Model Description OAL Blade Body Tip Length Width M401C Small Carbide Tapered Full Flush Cutter 4.70” 0.50” 0.45” 0.05” Traditional M401EC Small Carbide Tapered Full Flush Cutter, Ergo 5.60” 0.50” 0.45” 0.05” Ergo M403C Small Carbide Dual Tapered Fine Tip Full Flush Cutter 4.70” 0.30” 0.45” 0.04” Traditional 5.60” 0.30” 0.45” 0.04” Ergo 4.70” 0.40” 0.45” 0.03” Traditional 5.60” 0.40” 0.45” 0.03” Ergo 4.70” 0.30” 0.45” 0.02” Traditional 4.70” 0.30” 0.45” 0.03” Traditional 5.60” 0.30” 0.45” 0.03” Ergo 4.70” 0.45” 0.45” 0.03” Traditional 5.60” 0.45” 0.45” 0.03” Ergo M403EC M405C M403C M405EC Small Carbide Dual Tapered Fine Tip Full Flush Cutter Absolute precision. The tool of choice for precise flush cuts on internal coil trims. M4051C M401C Small Carbide Tapered Full Flush Cutter Provides a true flush cut on more robust applications and challenging materials. M406C M406EC M407C M407EC Small Carbide Dual Tapered Fine Tip Full Flush Cutter, Ergo Small Carbide Tapered Ultra Sharp Tip Full Flush Cutter Small Carbide Tapered Ultra Sharp Tip Full Flush Cutter, Ergo Small Carbide Tapered Ultra Sharp Micro Tip Full Flush Cutter Small Carbide Slim Dual Tapered-Relieved Fine Tip Full Flush Cutter Small Carbide Slim Dual Tapered-Relieved Fine Tip Full Flush Cutter, Ergo Small Carbide Dual Tapered Ultra Sharp Tip Full Flush Cutter Small Carbide Dual Tapered Ultra Sharp Tip Full Flush Cutter, Ergo Handle Type M4011C Small Carbide Tapered Semi Flush Cutter 4.70” 0.30” 0.45” 0.05” Traditional M4011EC Small Carbide Tapered Semi Flush Cutter, Ergo 5.60” 0.30” 0.45” 0.05” Ergo CARBIDE OVAL HEAD DIAGONAL CUTTERS M405C Small Carbide Tapered Ultra Sharp Tip Full Flush Cutter Ultra sharp tip is designed for precise internal trimming of the smallest coils. M406C Small Carbide Slim Dual Tapered-Relieved Fine Tip Full Flush Cutter Slim double tapered relieved head allows for precision trimming in confined spaces. Description OAL Blade Body Tip Length Width Handle Type M409C Small Carbide Oval Bullnose Semi Flush Cutter 4.70" 0.25" 0.45" 0.08" Traditional M409EC Small Carbide Oval Bullnose Semi Flush Cutter, Ergo 5.60" 0.25" 0.45" 0.08" Ergo M410C Small Carbide Oval Semi Flush Cutter 4.80" 0.45" 0.45" 0.04" Traditional M410EC Small Carbide Oval Semi Flush Cutter, Ergo 5.60" 0.45" 0.45" 0.04" Ergo M411C Small Carbide Oval Full Flush Cutter 4.80" 0.45" 0.45" 0.04" Traditional M411EC Small Carbide Oval Full Flush Cutter, Ergo 5.60" 0.45" 0.45" 0.04" Ergo M609C Large Carbide Oval Bullnose Semi Flush Cutter 5.20" 0.45" 0.60" 0.09" Traditional M609EC Large Carbide Oval Bullnose Semi Flush Cutter, Ergo 5.90" 0.45" 0.60" 0.09" Ergo M610C Large Carbide Oval Semi Flush Cutter 5.45" 0.80" 0.60" 0.09” Traditional M610EC Large Carbide Oval Semi Flush Cutter, Ergo 6.25" 0.70" 0.60" 0.09” Ergo M611C Large Carbide Oval Full Flush Cutter 5.40" 0.80" 0.60" 0.09" Traditional M611EC Large Carbide Oval Full Flush Cutter, Ergo 6.40" 0.80" 0.60" 0.09" Ergo CARBIDE M-SERIES ANGLED END CUTTERS M407C Small Carbide Dual Tapered Ultra Sharp Tip Full Flush Cutter Longer blade length than the M406C, allowing for further reach in areas with limited access. 2 M4011C Small Carbide Tapered Semi Flush Cutter A more robust cutting edge for heavier duty applications. Blade Body Tip Length Width Handle Type Model Description OAL M482C Small Carbide 60 Degree Angled Tip Flush Cutter 4.80" 0.50" 0.40" 0.03” Traditional M491C Carbide 60 Degree Angled Tip Flush Cutter 4.90" 0.45" 0.45" 0.06" Traditional CARBIDE CUTTERS Model 3 NON-CARBIDE CUTTERS TAPERED HEAD DIAGONAL CUTTERS M76917 Large Oval Full Flush Cutter Designed for flush lateral cutting of heavy duty materials such as stainless steel and Nitinol up to .035”. M610 Large Oval Semi Flush Cutter An ideal cutter for the widest varieties of cutting applications. Model Description OAL Blade Body Tip Length Width Handle Type M143 Small Tapered Semi Flush Cutter 4.70" 0.40" 0.40" 0.03" Traditional M143E Small Tapered Semi Flush Cutter, Ergo 5.60" 0.40" 0.40" 0.03" Ergo M144 Small Tapered Flush Cutter 4.70" 0.40" 0.40" 0.03" Traditional M144E Small Tapered Flush Cutter, Ergo 5.50" 0.30" 0.45" 0.03" Ergo M148LI Small Tapered-Relieved Super Flush Cutter 4.70" 0.40" 0.40" 0.03" Traditional M148ELI Small Tapered-Relieved Super Flush Cutter, Ergo 5.60" 0.30" 0.40" 0.03" Ergo M154 Midsize Tapered Flush Cutter 4.80" 0.50" 0.50" 0.03" Traditional M154E Midsize Tapered Flush Cutter, Ergo 5.70" 0.50" 0.50" 0.03" Ergo M415 Small Tapered Full Flush Cutter 4.80" 0.40" 0.45" 0.03" Traditional M415E Small Tapered Full Flush Cutter, Ergo 5.60" 0.45" 0.40" 0.03" Ergo M418 Small Tapered Flush Cutter 4.70" 0.30" 0.45" 0.03" Traditional M418E Small Tapered Flush Cutter, Ergo 5.60” 0.30” 0.45” 0.03" Ergo OVAL HEAD DIAGONAL CUTTERS M143 Small Tapered Semi Flush Cutter Our smallest tapered relieved cutter for those who prefer a smaller framed tool for highly detailed work. Small Tapered Full Flush Cutter Tapered head allows access to more confined spaces, while providing flush cuts. 4 Small Oval Semi Flush Cutter For general purpose applications where a true flush cut is not necessary. M411 Small Oval Full Flush Cutter For general purpose applications where a more flush cut is necessary. Description OAL Blade Body Tip Length Width Handle Type M140 Small Oval Semi Flush Cutter 4.75" 0.35" 0.40" 0.04" Traditional M140E Small Oval Semi Flush Cutter, Ergo 5.60" 0.35" 0.40" 0.04" Ergo M141 Small Oval Full Flush Cutter 4.70" 0.45" 0.40" 0.03" Traditional M141E Small Oval Full Flush Cutter, Ergo 5.50" 0.45" 0.40" 0.03" Ergo M150 Midsize Oval Semi Flush Cutter 4.85” 0.50” 0.50” 0.04” Traditional M150E Midsize Oval Semi Flush Cutter, Ergo 5.70" 0.50" 0.50" 0.04” Ergo M160 Large Oval Semi Flush Cutter 5.30" 0.68" 0.60" 0.06" Traditional M160E Large Oval Semi Flush Cutter, Ergo 6.20" 0.68" 0.60" 0.06" Ergo M410 Small Oval Semi Flush Cutter 4.80" 0.45" 0.45" 0.04" Traditional M410E Small Oval Semi Flush Cutter, Ergo 5.60" 0.45" 0.45" 0.04" Ergo M411 Small Oval Full Flush Cutter 4.80" 0.45" 0.45" 0.04" Traditional M411E Small Oval Full Flush Cutter, Ergo 5.60" 0.45" 0.45" 0.04" Ergo M510 Midsize Oval Semi Flush Cutter 5.00” 0.55” 0.50” 0.04” Traditional M510E Midsize Oval Semi Flush Cutter, Ergo 5.75" 0.55" 0.50" 0.04” Ergo M511 Midsize Oval Full Flush Cutter 5.00" 0.55" 0.50" 0.04” Traditional M511E Midsize Oval Full Flush Cutter, Ergo 5.60" 0.55" 0.50" 0.04” Ergo M610 Large Oval Semi Flush Cutter 5.40" 0.80" 0.60" 0.09" Traditional M610E Large Oval Semi Flush Cutter, Ergo 5.90" 0.80" 0.60" 0.09" Ergo M611 Large Oval Full Flush Cutter 5.50" 0.70" 0.60" 0.09" Traditional M611E Large Oval Full Flush Cutter, Ergo 6.40" 0.70" 0.60" 0.09" Ergo M709 Large Oval Bullnose Semi Flush Cutter 6.25" 0.50" 0.70" 0.09" Traditional M709E Large Oval Bullnose Semi Flush Cutter, Ergo 7.50" 0.50" 0.70" 0.09" Ergo M76917 Large Oval Full Flush Cutter 5.35" 0.65" 0.60" 0.09" Traditional M76917E Large Oval Full Flush Cutter, Ergo 6.40" 0.65" 0.60" 0.09" Ergo NON-CARBIDE CUTTERS M415 M410 Model 5 NON-CARBIDE SPECIALTY CUTTERS SHORT NOSE/HIGH LEVERAGE DIAGONAL CUTTERS M138-2 Miniature Tapered-Relieved Super Flush Cutter Miniature head and handle design are optimal for work under magnification. M509 Midsize Oval Bullnose Semi Flush Cutter Designed with strength and rigidity for intermediary hard wire cutting. Standard size handle is more accommodating to smaller hands. Blade Body Tip Length Width Handle Type Model Description OAL M409 Small Oval Bullnose Semi Flush Cutter 4.60" 0.30" 0.45" 0.05" Traditional M409E Small Oval Bullnose Semi Flush Cutter, Ergo 5.45" 0.30" 0.45" 0.05" Ergo M509 Midsize Oval Bullnose Semi Flush Cutter 4.75" 0.35" 0.50" 0.08" Traditional M509E Midsize Oval Bullnose Semi Flush Cutter, Ergo 5.65" 0.35" 0.50" 0.08" Ergo M533 Midsize Short Nose Tapered Semi Flush Cutter 4.70" 0.35" 0.50" 0.07" Traditional M533E Midsize Short Nose Tapered Semi Flush Cutter, Ergo 5.60" 0.35" 0.50" 0.07" Ergo M609 Large Oval Bullnose Semi Flush Cutter 5.20" 0.45" 0.60" 0.09" Traditional M609E Large Oval Bullnose Semi Flush Cutter, Ergo 5.90“ 0.45” 0.60" 0.09" Ergo 6.60" 0.55" 0.70" 0.09" Ergo 6.65” 0.66” 0.70” 0.09” Ergo M609EH M610EH Large High Leverage Bullnose Semi Flush Torsion Spring Cutter Large High Leverage Oval Semi Flush Torsion Spring Cutter MINIATURE DIAGONAL CUTTERS Large Oval Bullnose Semi Flush Cutter Our most versatile cutter in the M-Series line. Engineered for larger gauge hard wire cutting, including stainless steel and Nitinol alloys. M609EH Large High Leverage Bullnose Semi Flush Torsion Spring Cutter Ergonomic handle, torsion spring, and I-frame design put the high leverage tools in a class all of their own. Handle Type Description OAL M112 Miniature Oval Super Flush Cutter 4.80" 0.45" 0.40" 0.03" Traditional M112E Miniature Oval Super Flush Cutter, Ergo 5.70" 0.45" 0.40" 0.03" Ergo M138-2 Miniature Tapered-Relieved Super Flush Cutter 4.20" 0.30" 0.40" 0.03” Traditional M138E-2 Miniature Tapered-Relieved Super Flush Cutter, Ergo 5.30" 0.30" 0.40" 0.03” Ergo M130 Miniature Oval Semi Flush Cutter 4.00" 0.25" 0.35" 0.03” Traditional M130E Miniature Oval Semi Flush Cutter, Ergo 5.30" 0.30" 0.40" 0.03” Ergo M131 Miniature Oval Full Flush Cutter 4.00" 0.25" 0.35" 0.03” Traditional M131E Miniature Oval Flush Cutter, Ergo 5.40” 0.36” 0.35” 0.03” Ergo ANGLED END CUTTERS Blade Body Tip Length Width Handle Type Model Description OAL M225 Small 45 Degree Angled Tip Flush Cutter 4.90" 0.30" 0.45" 0.06" Traditional M225E Small 45 Degree Angled Tip Flush Cutter, Ergo 5.80" 0.30" 0.45" 0.06" Ergo M482 Small 60 Degree Angled Tip Flush Cutter 4.75" 0.25" 0.45" 0.04" Traditional M482E Small 60 Degree Angled Tip Flush Cutter, Ergo 5.60" 0.25" 0.45" 0.04" Ergo M491 60 Degree Angled Tip Flush Cutter 4.90" 0.45" 0.45" 0.06" Traditional M491E 60 Degree Angled Tip Flush Cutter, Ergo 5.80" 0.45" 0.45" 0.06" Ergo M-SERIES SHEARS M225E Small 45 Degree Angled Tip Flush Cutter, Ergo Used for precision tip cutting when an angled end is required for ease of access. 6 M482 Small 60 Degree Angled Tip Flush Cutter Angle end cutter ideal for precision work underneath magnification. Blade Body Tip Length Width Handle Type Model Description OAL MC6E Large Cable Shears 6.00" 0.40" 0.60" 0.09" Ergo MC8E Large Cable Shears 7.25" 0.70" 0.09" Ergo 0.40" NON-CARBIDE SPECIALTY CUTTERS M609 Blade Body Tip Length Width Model 7
M405EC 价格&库存
很抱歉,暂时无法提供与“M405EC”相匹配的价格&库存,您可以联系我们找货
M405EC
  • 6+2078.755006+268.94245
