170SD
170SD
    CHEMTRONICS
    CUTTER SHEARS TAPERD FLUSH 5.13"
170SD 数据手册
F-221 WEB IJ5–04–05.0–L–S–1–TR IJ5–01–05.0–L–S–1–TR IJ5–08–05.0–L–S–1–TR IJ5–04–05.0–L–D–1–TR (4.00 mm) .1575" IJ5 SERIES 50 W HIGH ISOLATION RF JACKS SPECIFICATIONS Single or Double Row Mates with: IP5 For complete specifications and recommended PCB layouts see www.samtec.com?IJ5 Shell Material: Copper Alloy Insulator Material: Black LCP Contact Material: Copper Alloy Dielectric Material: Black LCP Plating: Au or Sn over 50 µ" (1.27 µm) Ni Current Rating (Vertical): Signals: 2.36 A per pin (2 adjacent pins powered) Grounds: 4.4 A per pin (2 adjacent pins powered) Operating Temp Range: -55 °C to +125 °C Dielectric Withstanding Voltage: 600 VAC Working Voltage: 200 VAC RoHS Compliant: Yes PROCESSING IP5/IJ5 10 mm Stack Height Frequency Insertion Loss = 3 dB 10.5 GHz / 21.0 Gbps Return Loss = 15 dB 5.5 GHz / 11.0 Gbps Isolation = 60 dB 8.8 GHz / 17.6 Gbps Isolation = 70 dB 7.6 GHz / 15.2 Gbps Isolation = 80 dB 1.3 GHz / 2.6 Gbps Complete test data available at www.samtec.com?IJ5 or contact sig@samtec.com JACKS PER ROW IJ5 1, 2, 4, 6 or 8 Positions 05.0 PLATING ROW OPTION TAIL “X”R Lead–Free Solderable: Yes RECOGNITIONS –L = 10 µ" (0.25 µm) Gold on contact area, Matte Tin on tail –01, –02, –04, –06, –08 For complete scope of recognitions see www.samtec.com/quality FILE NO. E111594 APPLICATION NO. OF JACKS A –01 (5.55) .219 (9.55) .376 (17.55) .691 (25.55) 1.006 (33.55) 1.321 –02 –04 IJ5 –06 –08 10 mm –1 –S = (1.60 mm) .062" board thickness = Single Row –D –TR = Tape & Reel –FR = Full Reel Tape & Reel (must order max. quantity per reel; Contact Samtec for quantity breaks) = Double Row (Not available with –01) (2.03) .080 A (5.74) .226 (9.74) .383 (4.00) .1575 IP5 (6.50) .256 OTHER SOLUTIONS • Cable assembly (see IJ5C Series) (6.05) (7.52) .296 .238 (1.52) .060 –S –D (4.00) .1575 WWW.SAMTEC.COM Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice. Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Samtec: IJ5-04-05.0-L-S-1-TR IJ5-08-05.0-L-S-1-TR IJ5-02-05.0-L-S-1-TR IJ5-01-05.0-L-S-1-TR IJ5-02-05.0-L-D-1-TR IJ504-05.0-L-D-1-TR IJ5-06-05.0-L-S-1-TR IJ5-06-05.0-L-D-1-TR IJ5-08-05.0-L-D-1-TR IJ5C-02-1000-S-D-NUS IJ5C02-1000-S-D-NUS-1 IJ5C-02-1000-S-D-NUS-2 IJ5C-02-0300-S-D-NUS-1 IJ5C-04-0240-S-S-1 IJ5C-04-0458-S-DNUS-2 IJ5C-08-0300-S-D-NUS-1 IJ5C-04-0150-S-D-NUS-1 IJ5C-06-0100-S-D-NUS-1 IJ5C-06-0152-S-D-NUS-1 IJ5C-04-0200-S-S-1 IJ5C-04-0610-S-S-1 IJ5C-06-0150-S-D-NUS-1 IJ5C-08-0250-S-D-NUS-1 IJ5C-02-1000-S-S-1 IJ5C-02-1000-S-S-2 IJ5C-06-0153-S-S-1 IJ5C-06-0300-S-D-NUS-1 IJ5C-06-0450-S-D-NUS-1 IJ5C-06-0610-S-S-1 IJ5C-02-0100-S-S-1 IJ5C-02-0500-S-D-NUS-2 IJ5C-02-0150-S-D-NUS-1 IJ5C-04-0500-S-S-2 IJ5C-08-0254-S-DNUS-1 IJ5C-08-0500-S-S-1 IJ5C-08-0500-S-S-2 IJ5C-02-0400-S-S-1 IJ5C-04-0127-S-D-NUS-1 IJ5C-08-0150-S-DNUS-1 IJ5C-08-1000-S-S-1 IJ5C-02-0458-S-D-NUS-1 IJ5C-02-0300-S-S-1 IJ5C-04-0100-S-S-1 IJ5C-01-0100-S-DNUS IJ5C-04-0400-S-D-NUS-2 IJ5C-08-0500-S-D-NUS-2 IJ5C-08-0100-S-S-1 IJ5C-08-0200-S-S-1 IJ5C-08-1000-SD-NUS-2 IJ5C-04-0600-S-D-NUS-1 IJ5C-04-0914-S-D-NDS-2 IJ5C-04-1000-S-S-2 IJ5C-04-0102-S-D-NUS-1 IJ5C04-0508-S-D-NUS-1 IJ5C-02-0250-S-D-NUS-1 IJ5C-06-0500-S-S-2 IJ5C-04-0406-S-D-NUS-1 IJ5C-02-0115-S-DNUS-1 IJ5C-02-0500-S-S-2 IJ5C-08-0457-S-D-NUS-2 IJ5C-08-0610-S-D-NUS-2 IJ5C-02-0610-S-S-2 IJ5C-02-0800S-D-NUS-2 IJ5C-04-0400-S-S-1 IJ5C-08-1397-S-D-NUS-1 IJ5C-08-2000-S-S-2 IJ5C-04-0508-S-D-NUS-2 IJ5C-080600-S-S-1 IJ5C-04-0600-S-D-NDS-2 IJ5C-01-0500-S-S-1 IJ5C-04-0500-S-D-NUS-2 IJ5C-04-2020-S-S-2 IJ5C-020914-S-S-2 IJ5C-04-0600-S-S-2 IJ5C-02-1500-S-S-1 IJ5C-02-0171-S-D-NUS-1 IJ5C-08-0150-S-D-NUS-2 IJ5C-082000-S-S-1 IJ5C-02-0320-S-D-NUS-1 IJ5C-06-0600-S-S-2 IJ5C-01-0100-S-S-1 IJ5C-01-0500-S-D-NUS-1 IJ5C-040200-S-D-NDS-1 IJ5C-04-0310-S-D-NUS-1 IJ5C-04-0470-S-D-NUS-1 IJ5C-08-0914-S-D-NUS-1 IJ5C-08-1000-S-DNUS-1 IJ5C-02-0914-S-D-NDS-1 IJ5C-04-0360-S-D-NUS-1 IJ5C-06-0178-S-D-NUS-1 IJ5C-06-1000-S-D-NUS-1 IJ5C-08-0300-S-S-1 IJ5C-08-2500-S-S-2 IJ5C-02-0200-S-S-1 IJ5C-04-1000-S-D-NUS-1 IJ5C-04-0533-S-D-NDS-1 IJ5C-08-0200-S-D-NUS-1 IJ5C-02-0100-S-D-NDS-1 IJ5C-06-0100-S-S-1 IJ5C-08-0200-S-D-NDS-1
170SD 价格&库存
很抱歉,暂时无法提供与“170SD”相匹配的价格&库存,您可以联系我们找货
