45482
45482
    GREENLEECOMMUNICATIONS(格林利)
    CUTTER CABLE-8AWG
45482 数据手册
CUTTER, CABLE-8AWG Cable Cutter Cat No: 45482 UPC No: 783310454823 Description • • • • • • • • • Designed to cut solid, stranded wire up to 8 AWG (10 mm²)and multi-conductor cable up to 1/2 IN (12.7 mm) in diameter Curved cutting blades ensure an easy cut Economically priced Cushioned-grip handle for comfortable use Heat-treated for long life Stamped and precision ground from high-carbon tool steel Return spring Locking latch Rust-resistant black oxidefinish Specifications • • • • Capacity : Stranded Wire Up To 8 AWG (10.000 SQ-MM) And Multi-Conductor Cable Up To 1/2 IN (12.700 MM) In Diameter Finish : Black Oxide Handle Type : Cushioned Grip Jaw Material : High Carbon Steel
45482 价格&库存
很抱歉,暂时无法提供与“45482”相匹配的价格&库存,您可以联系我们找货
