0251-07M
0251-07M
    GREENLEECOMMUNICATIONS(格林利)
    PLIERS DIAGONAL 7" MOLDED
0251-07M 数据手册
PLIERS,DIAGONAL 7" MOLDED High Leverage Diagonal Cutting Pliers 7 molded grip Cat No: 0251-07M UPC No: 783310547389 Description • • • • • • • • • • • • Forged from chrome vanadium steel for greater durability and strength Precision-machined and laser-hardened blades strengthen cutters and provide consistent performance Effectively cuts most hardened wire, ACSR, bolts, screwsand nails Through-hardened steel for longer life Dual cutting edges for optimum cutting performance Exceeds ASME/ANSI specifications Rugged riveted construction for smooth precise action Lifetime limited warranty Note: This is not an insulated tool Molded Grip Only: Custom grip allows area for user identification Flared handles for added comfort and leverage Wider grip design provides larger load bearing area for user comfort Specifications • • • • • • • • Application : For Cutting Most Hardened Wire, ACSR, Bolts, Screws And Nails Handle Type : Flared, Molded Grip Material : Chrome Vanadium Steel Overall Length : 7.000 IN (17.800 CM) Size : 7.000 IN Standard : ASME/ANSI Type : High Leverage Diagonal Weight : 0.570 LB (0.260 KG)
0251-07M 价格&库存
很抱歉,暂时无法提供与“0251-07M”相匹配的价格&库存,您可以联系我们找货
