45240
45240
    GREENLEECOMMUNICATIONS(格林利)
    CUTTERCABLECIRCCROSSING11.5"
45240 数据手册
CUTTER-RATCHET CABLE Telco Ratchet Cutter Cat No: 45240 UPC No: 783310452409 Description • • • • • • This versatile cutter has aspecially designed moving blade to handle the larger diameter telephone cable and soft drawn copper and aluminum Cuts up to 2,700 pair 3 INtelephone cable Blade release for safety and fast backout Ratchet lock Blades are manufactured from high carbon tool steel and heat-treated for long life Rust-resistant, black oxide finish Specifications • • • • • • Cutting Capacity Of Communication Cables : Cuts Up To 2700 Pair 3.000 INTelephone Cable Finish : Black Oxide Jaw Material : High Carbon Steel Overall Length : 11-1/2 IN (287.000 MM) Type : Telco, Communication Weight : 2.800 LB (1.300 KG)
45240 价格&库存
很抱歉,暂时无法提供与“45240”相匹配的价格&库存,您可以联系我们找货
