10829F
10829F
    AVENTOOLS(艾文)
    CUTTERSIDEANG16DEGFLSH5.51"
10829F 数据手册
Premium Cutters Rockwell Hardness Rating: 63-65 Forged Steel Blades Durable. Reliable. Precise. Aven’s redesigned Accu-Cut cutters come complete with all of the premium features you’ve come to expect without the premium price. Dual Leaf Spring Release • Redesigned head sizes to fit modern applications • Ergonomic, ESD Safe hand grips for large and small hands ESD Ergonomic Cushion Grip • Forged steel blades provide 63-65 HRC • Screw joint construction • Dual leaf springs • Available in flush and semi-flush cutting finishes • Oval Head and Tapered Head styles • Rigorously tested in our custom-made cutting machine Semi-Flush Blade Flush Blade Email | sales@aveninc.com aveninc.com Phone | 734.973.0099 Premium Cutters TAPERED HEAD CUTTERS OVAL HEAD CUTTERS ITEM # CUTTING EDGE PRICE ITEM # CUTTING EDGE 10821S Semi-Flush 10825S Semi-Flush 10821F Flush 10825F Flush This popular style can be used for many applications OVAL HEAD RELIEF CUTTERS ITEM # CUTTING EDGE PRICE PRICE Compact pointed head for increased access, yet covers a wide range TAPERED HEAD RELIEF CUTTERS ITEM # CUTTING EDGE 10822S Semi-Flush 10826S Semi-Flush 10822F Flush 10826F Flush PRICE Same features as the Oval Head Cutter with relief for extra accessability Same features as the Tapered Head Cutter with relief for extra accessability LARGE OVAL HEAD CUTTERS MINI TAPERED HEAD RELIEF CUTTERS ITEM # CUTTING EDGE 10823S Semi-Flush 10823F Flush PRICE Popular for wire and cable, 25% larger than the standard oval cutters XL OVAL HEAD CUTTERS ITEM # CUTTING EDGE 10829S Semi-Flush 10829F Flush CUTTING EDGE 10828S Semi-Flush 10828F Flush PRICE For exceptionally fine cutting work. Reach small and difficult areas. MINI OVAL HEAD CUTTERS PRICE The largest and most durable Accu-Cut Cutter Email | sales@aveninc.com ITEM # aveninc.com ITEM # CUTTING EDGE 10827S Semi-Flush 10827F Flush PRICE SMT Cutter, 30% smaller than standard oval cutters Phone | 734.973.0099
10829F
1. 物料型号:文档列出了不同款式的剪刀,包括OVAL HEAD CUTTERS、OVAL HEAD RELIEF CUTTERS、LARGE OVAL HEAD CUTTERS、TAPERED HEAD CUTTERS、TAPERED HEAD RELIEF CUTTERS、MINI OVAL HEAD CUTTERS、MINI TAPERED HEAD RELIEF CUTTERS、XL OVAL HEAD CUTTERS。
2. 器件简介:这些剪刀具有以下特点: - 重新设计的头部尺寸,适合现代应用。 - 符合人体工程学,适合大手和小手的ESD安全握把。 - 锻造钢刀片,硬度为63-65 HRC。 - 螺丝接头结构。 - 双叶弹簧释放。 - 提供齐平和半齐平切割完成。 - 有椭圆形头和锥形头款式。
3. 引脚分配:文档中未明确提及引脚分配信息。
4. 参数特性:剪刀具有63-65的洛氏硬度评分,由锻造钢刀片制成,具有双叶弹簧释放机制。
5. 功能详解:文档中对不同款式的剪刀进行了功能描述,例如,锥形头剪刀适合电线和电缆使用,25%比标准椭圆形剪刀大;迷你椭圆形剪刀适合非常精细的切割工作,可以到达小且难以到达的区域。
6. 应用信息:这些剪刀适用于多种应用,如电线和电缆的切割、精细工作等。
7. 封装信息:文档中未明确提及封装信息
10829F 价格&库存
很抱歉,暂时无法提供与“10829F”相匹配的价格&库存,您可以联系我们找货
