11080
11080
    AVENTOOLS(艾文)
    CUTTER SHEAR TPRD CROSSNG 6.69"
11080 数据手册
Aven Inc. 4595 Platt Rd. Ann Arbor, MI 48108 Phone: 734.973.0099 Email: info@aventools.com • Web Address:www.aventools.com Item # 11080, 2 in 1 Combination Scissor 2 in 1 Combination Scissor This scissor has a unique 2 in 1 cutting blade and can trim and cut materials that would not be possible with a normal scissor. • Easily trim materials such as nylon fiber, cabtire cord, Kevlar etc. • Gives you a fine flush cut • Notched blades prevent the material to be trimmed from slipping • U-types notches on the blade allows you to hold items such as copper wire, cabtire or insulated cords etc. firmly in place • Soft grip for added comfort • Stainless Steel with blade hardness of HRC 54 • Length 170 mm (6-1/2") SPECIFICATIONS Length 6 1/2 in 170 mm Notched Blade Cutting Capacity Aluminum Sheet - Max. 0.5 mm Copper Sheet - Max. 0.5 mm PET - Max. 1.0 mm Plastic Plate - Max. 1.0 mm U-Type Blade Cutting Capacity Copper Wire - Max dia. 1.5 mm Weight 0.20 lb 2/9/2012 | Page 1 of 1
11080 价格&库存
很抱歉,暂时无法提供与“11080”相匹配的价格&库存,您可以联系我们找货
