www.wihatools.com
15
Wiha Soft Grip Pliers & Cutters
Diagonal Cutters
Diagonal Cutters DIN ISO 5749
326
Low wear lap joint, riveted and able to withstand high levels of load. Low
force cutting action, clean cutting. Long life edge is achieved through
additional induction hardening to approx. 64HRC. Special C70 tool steel
hardened and tempered. For soft & medium hard wire. Soft vinyl grips.
SHOP
High Leverage Cutters
Cable Cutters
Inch
Copper AWG
5.5
#6
6.3
#6
7.0
#6
Pkg. lbs.
1
.33
1
.49
1
.54
Item
No.
32646
32649
32652
Cutting Capacity
mm
160
180
200
Copper AWG
Inch
6.3
#6
7.0
#5
8.0
#4
Pkg. lbs.
1
.42
1
.50
1
.63
Cable Cutters Light, energy-saving & clean cutting with
326
specially ground precision cutting edges. Long life is achieved through
additional induction hardening of cutting edge to 64HRC. C70 special
tool steel hardened and tempered. Soft vinyl grips. For cutting of copper
& aluminum cables without crushing, also suitable for stripping. Not for
steel cable, wires and copper conductors with hard coatings.
SHOP
Flush Cutting Diagonal Cutters
• Flush cutting,
with return spring
Cutting Capacity
mm
140
160
180
High Leverage Cutters DIN ISO 5749
326
Semi-circular. Low wear lap joint, riveted and able to withstand high
levels of load. Low force action, clean cutting. Long life is achieved
through additional induction hardening of cutting edge to 64HRC.
C70 special tool steel hardened and tempered. Soft vinyl grips.
SHOP
64HRC
cutting edges
Item
No.
32638
32642
32639
Item
Cutting Capacity
Copper/Aluminum
No.
mm
Inch Pkg.
lbs.
32600 160
6.3 16mm 1 .34
32602 200
7.9 20mm 1 .62
326 Flush Cutting Diagonal Cutters With Return Spring For
Cutting Plastic DIN ISO 5749 Low wear lap joint, riveted and able
to withstand high levels of load. Lightweight action, clean cutting. Long
life edge is achieved through additional induction hardening to approx.
64HRC. Special C70 tool steel hardened and tempered. For cutting
plastic tie wraps & injection mold components. Soft vinyl grips.
SHOP
Soft Grip Crimping Pliers
Item
No.
32607
32614
mm Inch Pkg. lbs.
127 5.0 1
.14
160 6.3 1
.36
326 Crimping Pliers DIN ISO 5743
Semi-circular profiles for secure connection between end sleeve and
conductor. Long life is achieved through additional induction hardening to
64HRC. C70 special tool steel hardened & tempered. Soft vinyl grips.
SHOP
Item
No.
mm Inch mm2 AWG Pkg. lbs.
32604 145 5.75 0.25-2.5 14-32 1 .29
32605 180 7.0 0.25-16 6-32 1 .57
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Wiha:
32600 32602 32649 32642 32638 32607 32646 32639 32652 32614
很抱歉,暂时无法提供与“32607”相匹配的价格&库存,您可以联系我们找货
