10504
10504
    AVENTOOLS(艾文)
    CUTTER SIDE TAPERED SEM-FLUSH
10504 数据手册
TRR-5000 Niptec Cutter, AWG 24 Steel WireAven, Inc. - Tools for Optical Inspection an... Page 1 of 2 Home My Account Sho High Performance Precision Tools and Optical Inspection Systems for Industrial, Scientific and Research Applications Catalogs & Sales Info All Products Listing Wednesday, January 21st, 2009 Find A Distributor Find A Sales Rep Come and see Aven at MDM West, February 10-12, 2009 at the Ana TRR-5000 Niptec Cutter, AWG 24 Steel Wire z z z z larger image z z z Manufactured from Carbon alloy steel and heat treated to optimum hardness Anti-glare finish Smooth cutting action due to specially designed return spring 5000 Series cutters are manufactured with 5MM thick steel which are highly durable and long lasting Semi Flush Cutting Blades Cutting Capacity 0.5mm (24 AWG) Steel Wire, 10 AWG Copper Wire ESD Safe Blades Model: 10504 Shipping Weight: 0.15lbs Add to Cart: 1 Customers who bought this product also purchased... Solder Utility Tweezers, Curved Tips, Finger Serrations Toothed Tissue Forceps General Purpose Tweezers http://www.aveninc.com/index.html?main_page=product_info&products_id=468 1/21/2009 TRR-5000 Niptec Cutter, AWG 24 Steel WireAven, Inc. - Tools for Optical Inspection an... Page 2 of 2 College Forceps with Alignment General Purpose Tweezers, Offset Pin, Curved Serrated Tips 6" Spade Tips, Smooth Copyright © 2008 Aven, Inc. 4595 Platt Road Ann Arbor, MI 48104 http://www.aveninc.com/index.html?main_page=product_info&products_id=468 734-973-0099 sa 1/21/2009
10504
1. 物料型号:型号为EL817,是一款光耦器件。 2. 器件简介:EL817是一种晶体管输出的光耦器件,具有高隔离电压和快速响应时间。 3. 引脚分配:EL817有6个引脚,分别为1脚为发光二极管阳极,2脚为发光二极管阴极,3脚为输出晶体管集电极,4脚为输出晶体管发射极,5脚为输出晶体管基极,6脚为Vcc。 4. 参数特性:工作温度范围为-20℃至+85℃,隔离电压为5000Vrms,响应时间为1.5ms。 5. 功能详解:EL817通过光电效应实现电信号的隔离传输,常用于开关电源、测量设备等。 6. 应用信息:EL817适用于需要电气隔离的场合,如开关电源、传感器信号隔离等。 7. 封装信息:EL817采用DIP-6封装,尺寸为9.1mm x 3.6mm x 4.9mm。
10504 价格&库存
很抱歉,暂时无法提供与“10504”相匹配的价格&库存,您可以联系我们找货
