PA1113
PA1113
    GREENLEECOMMUNICATIONS(格林利)
    WIRE STRIP/CUTTER PRO6 28-10AWG
PA1113 数据手册
STRIPPER/CUTTER - STRIPAX PRO 6 Cat No: PA1113 UPC No: 769328107968 Description Now for THHN and THHW industrial insulations. The original stripax set the industry standard for precision stripping for a decade. The new stripax Pro 6 and Pro 16 perform powerful stripping of standard and industrial insulations for a wire range of 28-10 AWG (.08-6 mm2) and 10-6 AWG (6-16 mm2) respectively. The ergonomically designed, contoured handles let you hold the tool in a natural position so stripping is comfortable and requires less effort Consistently strips heavy-duty and industrial insulations including THHN & THHW Strips standard insulations including PVC, rubber and silicone Provides nick-free stripping of insulation with no damage to conductors Built-in cutter provides a smooth, straight cut without distorting the conductor Fine adjustment slider on top of tool lets you adjust tothe insulation thickness Handles designed for comfort and require low hand force Not for Teflon® or Kapton hard insulations (use part number PA1115P mini-stripax Plus with a Teflon® blade for these insulations) Perfect companion for any of our wire ferrule crimpers Strippers carry a lifetime warranty Blade warranty is one year for defects only Teflon® is a registered trademark of DuPont. Specifications Application : For THHN And THHW Industrial Insulations, Handle Type : Contoured Overall Length : 7.250 IN (185.000 MM) Replacement Part : PA2113 stripax Pro 6 replacement stripping blade set Stripping Range : 28 - 10 AWG (0.080 - 6.000 SQ-MM) Sub Brand : stripax Type : Pro 6 Weight : 5.500 OZ (156.000 GM) Copyright © 2012 Greenlee Textron Inc., a subsidiary of Textron Inc. All rights reserved. | Powered by the Precis  E‐business Platform™
PA1113
- 物料型号:PA1113,UPC编号:769328107968。 - 器件简介:STRIPAX PRO 6是用于剥离THHN和THHW工业绝缘材料的新型工具,适用于28-10 AWG (0.08-6 mm²)电线范围。它具有符合人体工程学设计的手柄,使用户在剥离时更舒适,减少努力。 - 引脚分配:文档中未提及引脚分配信息。 - 参数特性: - 应用:适用于THHN和THHW工业绝缘材料。 - 手柄类型:有轮廓的。 - 总长度:7.250英寸(185.000毫米)。 - 替换部件:PA2113 STRIPAX PRO 6替换剥离刀片套装。 - 剥离范围:28 - 10 AWG (0.080 - 6.000 SQ-MM)。 - 类型:Pro 6。 - 重量:5.500盎司(156.000克)。 - 功能详解:STRIPAX PRO 6能够一致地剥离重型和工业绝缘材料,包括PVC、橡胶和硅胶,同时不损伤导体。内置的切割器可以提供平滑、直线的切割,不扭曲导体。顶部的微调滑块允许根据绝缘厚度进行调整。 - 应用信息:适合任何GREENLEE的电线套管压接器使用。 - 封装信息:STRIPPER/CUTTER - STRIPAX PRO 6带有终身保修,刀片保修期为一年,仅限于缺陷。
PA1113 价格&库存
很抱歉,暂时无法提供与“PA1113”相匹配的价格&库存,您可以联系我们找货
