K1412
K1412
    KLEINTOOLS
    KLEIN-KURVEDUALNMCABLESTRIP
K1412 数据手册
Strippers, Cutters and Crimpers Manufactured with the needs of the professional tool user in mind, Klein strippers, cutters, and crimpers are designed to get jobs done with precision and quality. Strippers, Cutters and Crimpers Wire Strippers/ Cutters comfort grip handles Coil spring provides fast self-opening action. Wire looping and bending holes. Double dipped comfort grips. Strong gripping serrated nose for easy bending, shaping, and pulling of wire. Handy closure lock for convenient storage. Screw shearing holes Precision ground stripping holes Wire Strippers/Cutters Additional Features: Easy-to-read markings Precision shear-type blades Cleanly shears 6-32 and 8-32 screws Cat. No. 11054GLW features glow in the dark grips to easily locate your tool in dark or low lit areas • • • • 11054 8 – 16 AWG 8 AWG 10 – 1 Glow in the Dark Grips 11054GLW Cat. No. 11053 11054 11054GLW 11055 11057 Handle Color Blue/Red Blue/White Glow Blue/Yellow Blue/Red Overall Length 7-1/8" (181.0 mm) 7-1/8" (181.0 mm) 7-1/8" (181.0 mm) 7-1/8" (181.0 mm) 7-1/8" (181.0 mm) Strips and Cuts 6 - 12 AWG Stranded (10 mm² - 2.5 mm²) 8 - 16 AWG Solid (8.4 mm² - 1.3 mm²), 10 - 18 AWG Stranded (5.3 mm² - 0.82 mm²) 8 - 16 AWG Solid (8.4 mm² - 1.3 mm²), 10 - 18 AWG Stranded (5.3 mm² - 0.82 mm²) 10 - 18 AWG Solid (4.0 mm² - 0.75 mm²), 12 - 20 AWG Stranded (2.5 mm² - 0.50 mm²) 20 - 30 AWG Solid (0.50 mm² - 0.14 mm²), 22 - 32 AWG Stranded (0.34 mm² - 0.05 mm²) Screw Shearing 6-32 and 8-32 6-32 and 8-32 6-32 and 8-32 6-32 and 8-32 6-32 and 8-32 Weight 5.4 oz. (153 g) 5.4 oz. (153 g) 5.4 oz. (153 g) 5.4 oz. (153 g) 5.1 oz. (145 g) Dual NM Cable Stripper/Cutter Additional Features: 12/2, and 14/2 stripping slots quickly remove outer jacket of Type NM-B nonmetallic-sheathed cable Stripping holes easily remove insulation on 12 and 14 AWG sold wire Precision shear-type blades for square, clean cuts on solid copper wire Narrow nose fits into tight places • • • • Cat. No. K1412 K1412 4 AWG 12 – 1 Handle Color Yellow/White Overall Length 7-3/4" (196.9 mm) 32 www.kleintools.com Strips and Cuts 12 and 14 AWG Solid (2.5 mm² and 1.5 mm²) Type NM-B Cable 12/2 and 14/2 Screw Shearing 6-32 & 8-32 Weight 6.6 oz. (187 g) See page 310 for additional information on warnings. 11 04 2 mm SO L G AW ID .75 1.0 1.5 2.5 4.0 18 16 14 12 10 56 5 Strippers, Cutters and Crimpers WEA R E YE P AP RO ED N OV TIO PRTEC 6 NEVER USE ON LIVE CIRCUITS Klein-Kurve™ Wire Strippers/Cutters Dual NMD-90 Cable Stripper/Cutter Additional Features: Quickly removes outer jacket of Canadian NMD-90 Romex® Cable Strips, cuts, and loops 12 & 14 AWG solid wires Strips, cuts, and loops 14 & 16 AWG stranded wires Cleanly shears 6-32 and 8-32 screws • • • • K1412CAN 4 AWG 12 – 1 6 AWG 14 – 1 Romex ® is a registered trademark of Southwire Company. Cat. No. K1412CAN Handle Color Yellow/White Overall Length 7-3/4" (196.9 mm) Strips and Cuts 12 and 14 AWG Solid (2.5 mm² and 1.5 mm²), 14 and 16 AWG Stranded (1.5 mm² and 1.0 mm²) Type NMD-90 Cable 12/2 & 14/2 Screw Shearing 6-32 & 8-32 Weight 6.6 oz. (187 g) Wire Strippers/ Cutters Textured handles provide a firm, comfortable grip Spring loaded for self-opening action Wire looping and bending holes Black-oxide finish resists corrosion Precision-ground stripping holes for easy removal of insulation Easy-to-read wire gauge markings on both sides for stripping in either direction Wire Strippers/Cutters Additional Features: Compact, lightweight wire-stripping and cutting tools Narrow nose fits into tight places Hardened steel with precision ground stripping holes Do NOT use for cutting steel wire or screws • • • • 8 AWG 10 – 1 11045 Cat. No. 11045 11046 11047 11049 Handle Color Yellow Red Yellow Red Overall Length 6-1/4" (158.8 mm) 6-1/4" (158.8 mm) 6-1/4" (158.8 mm) 6-1/4" (158.8 mm) See page 310 for additional information on warnings. Strips and Cuts 10 - 18 AWG Solid (4.0 mm² - 0.75 mm²) 16 - 26 AWG Stranded (1.0 mm² - 0.14 mm²) 22 - 30 AWG Solid (0.34 mm² - 0.05 mm²) 8 - 16 AWG Stranded (6 mm² - 1.0 mm²) Weight 4.3 oz. (122 g) 4.3 oz. (122 g) 4.3 oz. (122 g) 4.3 oz. (122 g) 33 www.kleintools.com Strippers, Cutters and Crimpers Wire Strippers/Cutters Dual-Wire Stripper/Cutter Additional Features: Strips two wires in a single motion Paired stripping holes for 14 and 12 AWG solid wire One stripping hole for 10 AWG solid wire Shear-type cutting blades for square, clean cuts Narrow nose fits into tight places Hardened steel with precision ground stripping holes Do not use for cutting steel wire or screws • • • • • • • Cat. No. 11048 Handle Color Yellow Overall Length 6-1/4" (158.8 mm) Strips and Cuts 10, 12, 14 AWG Solid (4.0 mm², 2.5 mm², 1.5 mm²) Wire Strippers/Cutters • Strips six standard wire sizes without nicking wire • Scissors action of 1/2" (13 mm) wide cutter makes clean cuts with little effort • Serrated nose jaws to bend, shape or pull wire; holes for looping wire ends • Spring-loaded for self-opening action • Comfortable, plastic-covered handles Cat. No. 1011M 1011 Handle Color Blue Blue Overall Length 6-1/8" (155.6 mm) 6-1/8" (155.6 mm) Handle Color Yellow Yellow Overall Length 5" (127.0 mm) 5" (127.0 mm) Handle Color Yellow Overall Length 5-1/8" (130.2 mm) 34 www.kleintools.com 11048 0 AWG 10 – 2 2 AWG 12 – 2 Weight 3.7 oz. (104 g) 3.7 oz. (104 g) 1011 6 AWG 12 – 2 6 AWG 12 – 2 Strips and Cuts 12 - 26 AWG Solid and Stranded (2.5 mm² - 0.14 mm²) 12 - 26 AWG Solid and Stranded (2.5 mm² - 0.14 mm²) Adjustable Wire Stripper/Cutter Solid and Stranded Wire • Simply dial desired wire size for fast, easy stripping • Adjustable tool makes short work of cutting and stripping operations • Finely honed nose cutter easily gets into tight areas • Wire gauge dial sets stripping dies to proper size, helps prevent nicked wire • Black-oxide finish with plastic-dipped handles • Spring-loaded design - tool opens automatically after each action Cat. No. 74007 Weight 4.3 oz. (122 g) Strips and Cuts 0.15 to 4.0 mm² Stranded Wire 10 - 20 AWG Solid (4.0 mm² - 0.50 mm²), 12 - 22 AWG stranded (2.5 mm² - 0.34 mm²) Adjustable Wire Strippers/Cutters Solid and Stranded Wire • A handy, light, compact tool for stripping insulation • Convenient hole for looping or bending wire • Black-oxide finish with plastic-dipped handles • Cuts, strips, and loops 12-26 solid and stranded wire • Adjustable slide stop with set screw for repeat stripping work Cat. No. 1004 1003 WG , 14 A 10, 12 Hold-Open Spring Yes No Weight Yes 2.2 oz. (64 g) 1004 4 AWG 12 – 2 4 AWG 12 – 2 Strips and Cuts 12 - 24 AWG Solid and Stranded (2.5 mm² - 0.25 mm²) Weight 2.4 oz. (68 g) 74007 See page 310 for additional information on warnings. 11 04 2 mm SO L G AW ID .75 1.0 1.5 2.5 4.0 18 16 14 12 10 56 5 Strippers, Cutters and Crimpers WEA R E YE P AP RO ED N OV TIO PRTEC 6 NEVER USE ON LIVE CIRCUITS Wire Strippers/Cutters Katapult™ Wire Stripper/Cutters • Quick and easy wire stripping and cutting • Compound action wire stripping: grip and strip via single action squeezing motion • Precision machined stripping holes easily remove jacket insulation without damaging the wire • Removes up to 1" (24 mm) in length of the insulation layer (jacket layer) in a single step • Tension loaded wire-grip gently holds the cable in place while retaining the cable geometry • Recoil spring design returns tool to ready position upon cycle completion • Cast alloy chassis with heavy-duty Ecoat finish for corrosion resistance and durability • Additional precision machined steel cutting blades available ® 8 – 22 AWG 4 AWG 10 – 2 11063W Cat. No. 11063W Handle Color Blue/Black Overall Length 6-19/32" (167.5 mm) Strips Weight 8 - 24 AWG solid (6.0 mm² - 0.34 mm²), 12.0 oz. 10-22 AWG stranded (6.0 mm² - 0.34 mm²) (340 g) Cat. No. Application Weight Replacement Blades Sets VDV110-046 11082 11073 11074 RG6 Coaxial Cable 10 AWG Max Wire 8 - 22 AWG ((6.0 mm² - 0.34 mm²) 16 - 26 AWG ((1.0 mm² - 0.14 mm²) 0.16 oz. (4.5 g) 0.16 oz. (4.5 g) 0.01 lbs. (0.005 kg) 0.01 lbs. (0.005 kg) Wire Stop/Gauge 11081 Self-Adjusting Wire Stripper/Cutter • Strips 10-20 AWG solid, 12-22 AWG stranded, and 12/2 & 14/2 Romex • Adjustable stopper to control the length of the core strip • Convenient wire cutter in handle • Grooved grips are designed for added comfort ® Adjustable Wire Stop 0.16 oz. (4.5 g) wire 11061 Cat. No. 11061 Handle Color Blue/Black Overall Length 8-1/4" (209.6 mm) Strips and Cuts Weight 10 - 20 AWG Solid (4.0 mm² - 0.50 mm²), 12.6 oz. (358 g) 12 - 22 AWG stranded (2.5 mm² - 0.34 mm²), 12/2 and 14/2 Romex® 0 AWG 10 – 2 2 AWG 12 – 2 Romex® is a registered trademark of Southwire Company. NM Cable Ripper • Easy-to-use cable ripper • Slit the outer jacket of Romex cable (all sizes) and other nonmetallic (type NM) sheathed cable • Measure conductor wire gauge ® Cat. No. 74017 Overall Length 4" (101.6 mm) Slits All Sizes of Romex® and NM Measures Wire Gauge 8 - 14 AWG (6 mm² - 1 mm²) Weight 1.3 oz. (37 g) 74017 Romex® is a registered trademark of Southwire Company. See page 310 for additional information on warnings. 35 www.kleintools.com Strippers, Cutters and Crimpers Combination Wire-Stripping and Crimping Tools Multi-Purpose 6-in-1 Tool • Cleanly shears bolts • Easily cuts and strips wire • Measures stud sizes • Gauges wire sizes • Crimps insulated terminals • Comfortable, plastic-covered handles Cat. No. 1000 Handle Color Red Overall Length 7-3/4" (196.9 mm) 1000 8 – 22 Handle Color Red Overall Length 8-1/2" (215.9 mm) 6 AWG 10 – 2 Strips and Cuts 8 - 22 AWG Solid (6.0 mm² - 0.34 mm²), 10 - 26 AWG Stranded (4.0 mm² - 1.0 mm²) Multi-Purpose Electrician's Tool wire cutters-one at tip, the other halfway back near • Two stripping holes-double the utility of this tool crimping dies for 10-22 AWG insulated and • Color-coded non-insulated terminals • Cleanly shears bolts • Pivot nut adjusts tension • Wire-looping holes near tip • Full-sized, plastic-covered cushioned handles for comfort Cat. No. 1001 AWG Bolt Size 4-40, 6-32, 8-32, 10-24, 10-32 Weight 7.0 oz. (198 g) 1001 8 – 22 AWG 6 AWG 10 – 2 Strips and Cuts 8 - 22 AWG Solid (6.0 mm² - 0.34 mm²), 10 - 26 AWG Stranded (4.0 mm² - 1.0 mm²) Bolt Size 4-40, 6-32, 8-32, 10-24, 10-32 Weight 7.5 oz. (213 g) Multi-Purpose Long-Nose Tool • Easily cuts and strips wire • Narrow, serrated pliers nose to pull, loop, and bend wire • Long, curved cutting blade • Cutters and strippers are in front of the pivot for maximum ease-of-use in reaching into tight places • Crimps insulated and non-insulated terminals and 7 to 8 mm ignition terminals • Cleanly shears bolts • Plastic-covered cushioned handles for comfort 0 AWG 2 AWG 10 – 2 Cat. No. 1010 Handle Color Blue Overall Length 8-1/4" (209.6 mm) Strips and Cuts 10 - 20 AWG, 12 - 22 AWG 1010 12 – 2 Bolt Size 4-40, 5-40, 6-32, 8-32, 10-32, 10-24 Connectors 10 - 22 Gauge Weight 6.9 oz. (196 g) Crimping Tools Crimping/Cutting Tools Non-Insulated/Insulated Terminals die marked for insulated and non-insulated • Crimping solderless terminals and connectors • Tapered nose design for working in confined spaces • Specially hardened wire cutter in nose • Hot-riveted joint for smooth action and no handle wobble Cat. No. 1005 Overall Length 9-3/4" (247.7 mm) 1005 Handle Finish Plastic-dipped Handle Color Red Crimps 10 - 22 AWG (4.0 mm² - 0.34 mm²) Weight 12.8 oz. (363 g) Journeyman Red/Black 10 - 22 AWG (4.0 mm² - 0.34 mm²) 13.4 oz. (381 g) Journeyman Series – Dual-material handles J1005 9-3/4" (247.7 mm) 36 www.kleintools.com See page 310 for additional information on warnings. 11 04 2 mm SO L G AW ID .75 1.0 1.5 2.5 4.0 18 16 14 12 10 56 5 Strippers, Cutters and Crimpers WEA R E YE P AP RO ED N OV TIO PRTEC 6 NEVER USE ON LIVE CIRCUITS Crimping Tools Crimping/Cutting Tool - Non-Insulated Terminals • Designed for crimping non-insulated solderless terminals and connectors • Specially hardened wire cutter in nose • Tapered nose for working in confined spaces • Hot-riveted joint for smooth action and no handle wobble Cat. No. 1006 Handle Color Black Overall Length 9-3/4" (247.7 mm) 1006 Crimps 10 - 22 AWG (4.0 mm² - 0.34 mm²) Weight 13.6 oz. (386 g) Large Crimp Tool - Compound-Action • Crimps #6-4/0 AWG battery lugs and terminals • Ultra-comfortable hand grips for easy use • All-in-one, integral crimp nest. No removable parts or rotating dies handles and compound-action mechanism for • High-leverage superior mechanical advantage • Adjustment screw allows user to control crimp depth Cat. No. 2006 Handle Color Red Overall Length 19-1/2" (495.3 mm) Crimps #6 - 4/0 AWG battery lugs and terminals Weight 3.8 lbs. (1.72 kg) 2006 Ratcheting Crimpers Ratcheting Crimpers - Insulated Terminals No. T1715 full cycle ratcheting crimper crimps insulated terminals in wire sizes • Cat. 22-16 (front cavity), 16-14 (middle cavity), and 12-10 (rear cavity) No. T1710 compound-action tool crimps 10-22 AWG insulated terminals to • Cat. meet or exceed MIL-SPEC pull-out tests • Cat. No. T1710 features special locator to quickly position terminal to double crimp • Built-in ratchet with safety release assures uniform crimps every time lever-action of narrow span handles puts more crimping power into • Compound each squeeze • Comfort-grip plastic handles Cat. No. T1715 T1710 Handle Color Black Black Overall Length 9" (228.6 mm) 9" (228.6 mm) See page 310 for additional information on warnings. Crimps 22-16/16-14/ 12-10 10 - 22 AWG Weight 1.1 lbs. (0.50 kg) 1.1 lbs. (0.50 kg) T1715 T1710 37 www.kleintools.com
K1412 价格&库存
很抱歉,暂时无法提供与“K1412”相匹配的价格&库存,您可以联系我们找货
