ES177
ES177
    CHEMTRONICS
    CLEANER ELECTRONICS 1 GAL
ES177 数据手册
CHEMTRONICS TDS # 3277 Technical Data Sheet Eco-Rite™ Multi-Purpose Cleaner The eco-friendly, multi-purpose aqueous cleaner PRODUCT DESCRIPTION Environmentally preferable Eco-Rite™ Multi-Purpose Cleaner is a low environmental impact multi-purpose cleaner, specifically formulated for a variety of cleaning applications. This formulation is non-flammable and biodegradable, offering safe and efficient cleaning of a variety of surfaces. Available in a convenient, ready-to use trigger spray or a concentrate ready for dilution, Eco-Rite™ Multi-Purpose Cleaner is ideal for cleaning hard surfaces such as bench tops, counters, tool boxes, compressors, floors, hoists, lifts, engines, etc. The waterbased cleaning solution quickly penetrates, emulsifies and lifts the toughest grime, without the environmental impact of high VOC’s, caustic compounds, and butylbased cleaners. • • • • • • • • • • Multi-purpose spray and wipe cleaning performance Removes oils, dirt, waxes and handling soils Non-flammable Biodegradable No Phosphates, EDTA, or NTA Non-caustics, non-acidic, no chlorine bleach, no abrasives No Carcinogens, Ozone Depleting Compounds No Petroleum Distillates No Alkylphenolethoxylates Butyl-free TYPICAL APPLICATIONS Eco-Rite™ Multi-Purpose Cleaner can be used for all repair, maintenance, and manufacturing cleaning applications including: • Removes oils, handling soils and lubricants • Ideal for metal parts cleaning and tools • All repair and maintenance cleaning • Used to clean grease and other soils from a variety of surfaces such as: • Stainless Steel, Chrome • Plastics • Ceramics and enamel TYPICAL PRODUCT DATA AND PHYSICAL PROPERTIES Boiling Point Evaporation Rate (butyl acetate=1) Flash Point (TCC) Specific Gravity Appearance Odor Solubility in Water pH Shelflife CARB & OTC VOC Content SCAQMD VOC Content 212° F (Initial)
ES177 价格&库存
很抱歉,暂时无法提供与“ES177”相匹配的价格&库存,您可以联系我们找货
