CHEMTRONICS
Technical Data Sheet
TDS # 3299
Eco-Rite™ Stencil Cleaner
The eco-friendly stencil cleaner
PRODUCT DESCRIPTION
Eco-Rite™ Stencil Cleaner is an environmentally
friendly water based product designed to
effectively clean solder paste from stencils. EcoRite™ Stencil Cleaner is non-corrosive and
biodegradable, and comes available in a
convenient ready to use trigger sprayer. The water
based cleaning solution cleans stencils of solder
paste without the environmental impact of high
VOC’s, caustic compounds, and butyl-based cleaners.
Effectively cleans wet and dry solder paste
Removes misprinted paste
Non-flammable
Biodegradable
No Phosphates, EDTA, or NTA
Non-caustic, non-acidic, no chlorine bleach, no
abrasives
No carcinogens or ozone depleting compounds
No petroleum distillates
No alkylphenolethoxylates
Butyl-Free
TYPICAL PRODUCT DATA AND
PHYSICAL PROPERTIES
Boiling Point
RTU
Concentrate
Solubility in Water
Specific Gravity
RTU
Concentrate
Flash Point (TCC)
Appearance
Eco-Rite™ Stencil Cleaner removes the following
paste types:
Rosin-based (R, RMA, RA)
No Clean
Lead-free
Water soluble
Lead free adhesives
100%
1.00
1.01
None
Clear Liquid
Moderate
Odor
CARB & OTC
VOC Content*:
RTU
Concentrate
5.0%
25.0%
SQAQMD
VOC Content:
RTU
Concentrate
83 gms/L
415 gms/L
Shelf life
TYPICAL APPLICATIONS
Eco-Rite™ Stencil Cleaner can be used to clean
stencils by:
Underside Wiping
Ultrasonic Stencil Cleaning
Spray Cleaning
85°C/185oF
96°C/205oF (Initial)
2 years after opening
*Volatile Organic Compound (VOC) information is calculated on a
weight basis using the VOC definition of California Air Resources
Board (CARB) Consumer Product Regulations, South Coast Air
Quality Management District (SCAQMD) Rule 102 and the
Federal definition published in 40 CFR 51.100(s).
COMPATIBILITY
Eco-Rite™ Stencil Cleaner is generally
compatible with most materials used in printed
circuit board fabrication. With any cleaning agent
compatibility must be determined on a non-critical
area prior to use.
Material
Teflon
Graphite
LDPoly
PVC
PEHD
Lexan
ABS
Noryl
EPDM
Butyl
Buna N
Acrylic
Nylon 66
Compatibility
Excellent
Excellent
Excellent
Good
Excellent
Excellent
Good
Good
Excellent
Excellent
Excellent
Good
Excellent
USAGE INSTRUCTIONS:
For industrial use only.
Read MSDS carefully prior to use.
thoroughly in de-ionized water and dry where
required.
Dilution ratios for concentrate Water : Conc
Heavy flux residue
2:1
Moderate flux residue / RTU
5:1
General cleaning
10:1
AVAILABILITY
ES3299
1 quart RTU
ES199
1 gallon concentrate
ENVIRONMENTAL IMPACT DATA
HFC
nPB
This information is believed to be accurate. It is
intended for professional end users having the
skills to evaluate and use the data properly.
CHEMTRONICS does not guarantee the accuracy
of the data and assumes no liability in connection
with damages incurred while using it.
trademarks of Chemtronics. All rights reserved.
a clean, lint-free wipe. Eco-Rite™ Stencil Cleaner
concentrate can be full strength for immersion cleaning
or diluted to desired concentration. Rinse parts
None
None
NOTE:
Chemtronics is a registered trademarks of Chemtronics.
All rights reserved. Eco-Rite, and Controlwipes are
Eco-Rite™ Stencil Cleaner RTU can be sprayed
directly from the quart bottle onto uncured solder
past. Wipe away soils with a Controlwipes™ Wipe, or
HCFC-141b
HCFC-225
TECHNICAL & APPLICATION
ASSISTANCE
Chemtronics provides a technical hotline
to answer your technical and application
related questions. The toll free number is:
1-800-TECH-401.
None
None
Hydrochlorofluorocarbons (HCFCs) are regulated under the Montreal
Protocol as Class II ozone depleting substances. HCFC-141b is no longer
produced in the US under this legislation. HCFC-225 is planned for
production phase-out in 2015. Hydrofluorocarbons (HFCs) are not
currently regulated.
EPA has listed n-propyl bromide (nPB) as an acceptable alternative to
ozone depleting substances in metal, precision, and electronics cleaning
under Section 612 of the Clean Air Act.
All other trademarks herein are trademarks or
registered trademarks of their respective owners.
CHEMTRONICS
8125 COBB CENTER DRIVE
KENNESAW, GA 30152
REV. C (08/13)
1-770-424-4888
DISTRIBUTED BY:
很抱歉,暂时无法提供与“ES199”相匹配的价格&库存,您可以联系我们找货
