ES3299
ES3299
    CHEMTRONICS
    CLEANER STENCILS 1 QT
ES3299 数据手册
CHEMTRONICS Technical Data Sheet TDS # 3299 Eco-Rite™ Stencil Cleaner The eco-friendly stencil cleaner PRODUCT DESCRIPTION Eco-Rite™ Stencil Cleaner is an environmentally friendly water based product designed to effectively clean solder paste from stencils. EcoRite™ Stencil Cleaner is non-corrosive and biodegradable, and comes available in a convenient ready to use trigger sprayer. The water based cleaning solution cleans stencils of solder paste without the environmental impact of high VOC’s, caustic compounds, and butyl-based cleaners.           Effectively cleans wet and dry solder paste Removes misprinted paste Non-flammable Biodegradable No Phosphates, EDTA, or NTA Non-caustic, non-acidic, no chlorine bleach, no abrasives No carcinogens or ozone depleting compounds No petroleum distillates No alkylphenolethoxylates Butyl-Free TYPICAL PRODUCT DATA AND PHYSICAL PROPERTIES Boiling Point RTU Concentrate Solubility in Water Specific Gravity RTU Concentrate Flash Point (TCC) Appearance Eco-Rite™ Stencil Cleaner removes the following paste types:  Rosin-based (R, RMA, RA)  No Clean  Lead-free  Water soluble  Lead free adhesives 100% 1.00 1.01 None Clear Liquid Moderate Odor CARB & OTC VOC Content*: RTU Concentrate 5.0% 25.0% SQAQMD VOC Content: RTU Concentrate 83 gms/L 415 gms/L Shelf life TYPICAL APPLICATIONS Eco-Rite™ Stencil Cleaner can be used to clean stencils by:  Underside Wiping  Ultrasonic Stencil Cleaning  Spray Cleaning 85°C/185oF 96°C/205oF (Initial) 2 years after opening *Volatile Organic Compound (VOC) information is calculated on a weight basis using the VOC definition of California Air Resources Board (CARB) Consumer Product Regulations, South Coast Air Quality Management District (SCAQMD) Rule 102 and the Federal definition published in 40 CFR 51.100(s). COMPATIBILITY Eco-Rite™ Stencil Cleaner is generally compatible with most materials used in printed circuit board fabrication. With any cleaning agent compatibility must be determined on a non-critical area prior to use. Material Teflon Graphite LDPoly PVC PEHD Lexan ABS Noryl EPDM Butyl Buna N Acrylic Nylon 66 Compatibility Excellent Excellent Excellent Good Excellent Excellent Good Good Excellent Excellent Excellent Good Excellent USAGE INSTRUCTIONS: For industrial use only. Read MSDS carefully prior to use. thoroughly in de-ionized water and dry where required. Dilution ratios for concentrate Water : Conc Heavy flux residue 2:1 Moderate flux residue / RTU 5:1 General cleaning 10:1 AVAILABILITY ES3299 1 quart RTU ES199 1 gallon concentrate ENVIRONMENTAL IMPACT DATA HFC nPB This information is believed to be accurate. It is intended for professional end users having the skills to evaluate and use the data properly. CHEMTRONICS does not guarantee the accuracy of the data and assumes no liability in connection with damages incurred while using it. trademarks of Chemtronics. All rights reserved. a clean, lint-free wipe. Eco-Rite™ Stencil Cleaner concentrate can be full strength for immersion cleaning or diluted to desired concentration. Rinse parts None None NOTE: Chemtronics is a registered trademarks of Chemtronics. All rights reserved. Eco-Rite, and Controlwipes are Eco-Rite™ Stencil Cleaner RTU can be sprayed directly from the quart bottle onto uncured solder past. Wipe away soils with a Controlwipes™ Wipe, or HCFC-141b HCFC-225 TECHNICAL & APPLICATION ASSISTANCE Chemtronics provides a technical hotline to answer your technical and application related questions. The toll free number is: 1-800-TECH-401. None None Hydrochlorofluorocarbons (HCFCs) are regulated under the Montreal Protocol as Class II ozone depleting substances. HCFC-141b is no longer produced in the US under this legislation. HCFC-225 is planned for production phase-out in 2015. Hydrofluorocarbons (HFCs) are not currently regulated. EPA has listed n-propyl bromide (nPB) as an acceptable alternative to ozone depleting substances in metal, precision, and electronics cleaning under Section 612 of the Clean Air Act. All other trademarks herein are trademarks or registered trademarks of their respective owners. CHEMTRONICS 8125 COBB CENTER DRIVE KENNESAW, GA 30152 REV. C (08/13) 1-770-424-4888 DISTRIBUTED BY:
ES3299 价格&库存
很抱歉,暂时无法提供与“ES3299”相匹配的价格&库存,您可以联系我们找货
