ES155
ES155
    CHEMTRONICS
    DEGREASER ELECTRONICS 1 GAL
ES155 数据手册
CHEMTRONICS TDS # 155 Technical Data Sheet Eco-Rite™ Heavy Duty Degreaser The eco-friendly, industrial grade aqueous degreaser PRODUCT DESCRIPTION Environmentally preferable Eco-Rite™ Heavy Duty Degreaser is specifically formulated for removal of all types of soils including oxidized grease, sludge, and oil, while having a low environmental impact. This unique formulation is non-flammable, biodegradable, and has neutral pH, offering safe and efficient cleaning of a variety of surfaces. Available in a concentrate ready for dilution, Eco-Rite™ Heavy Duty Degreaser offers all the cleaning power for hard-to-remove soils. The waterbased cleaning solution quickly penetrates, emulsifies and lifts the toughest grime, without the environmental impact of high VOC’s, high pH, and butyl-based cleaners. • • • • • • • • • • • • TYPICAL PRODUCT DATA AND PHYSICAL PROPERTIES Boiling Point Evaporation Rate (butyl acetate=1) Flash Point (TCC) Specific Gravity Vapor Pressure @68°F Appearance Odor Heavy-duty cleaning performance Quickly penetrates, emulsifies and lifts the toughest grime Removes grease, oil, waxes and resins Non-flammable Biodegradable Formulated with ingredients on EPA Design for Environment list No Phosphates, EDTA, or NTA Non-caustics, non-acidic, no chlorine bleach, no abrasives No Petroleum Distillates No Alkylphenolethoxylates Butyl-free Meets CARB LBP-VOC Exemption TYPICAL APPLICATIONS Eco-Rite™ Heavy Duty Degreaser can be used for all repair, maintenance, and manufacturing cleaning applications including: • Removes grease, oil and lubricants • Ideal for metal parts cleaning and tools • All repair and maintenance cleaning • Cleans electric motors and gasoline engines • Removes tough soils from gears and pulleys • Use for maintenance of air compressors Solubility in Water pH >200° C
ES155 价格&库存
很抱歉,暂时无法提供与“ES155”相匹配的价格&库存,您可以联系我们找货
