ES3266
ES3266
    CHEMTRONICS
    CLEANER GLASS 32 OZ
ES3266 数据手册
CHEMTRONICS TDS # ES3266 Technical Data Sheet Eco-Rite™ Glass Cleaner The eco-friendly, non-streaking glass cleaner PRODUCT DESCRIPTION Eco-Rite™ Glass Cleaner is formulated specifically to clean glass, mirrors, chrome and other reflective surfaces. Eco-Rite™ Glass Cleaner is non-corrosive and biodegradable, and comes available in a convenient ready to use trigger sprayer. The water based cleaning solution cleans glass, plastics and similar surfaces streak free, without the environmental impact of high VOC’s, caustic compounds, and butylbased cleaners. • • • • • • • • • • Specifically formulated to clean glass and other surfaces Removes oils, dirt, finger prints and handling soils Non-flammable Biodegradable No Phosphates, EDTA, or NTA Non-caustics, non-acidic, no chlorine bleach, no abrasives No Carcinogens, Ozone Depleting Compounds No Petroleum Distillates No Alkylphenolethoxylates Butyl-free TYPICAL APPLICATIONS • ™ Eco-Rite Glass Cleaner can be used to remove surface smears and handling soils from a variety of smooth surfaces including: • Glass • Stainless Steel • Chrome • Mirrors • Plastic • Ceramic • Enamel TYPICAL PRODUCT DATA AND PHYSICAL PROPERTIES (RTU) Boiling Point Evaporation Rate (butyl acetate=1) Flash Point (TCC) Specific Gravity Appearance Odor Solubility in Water pH Shelflife CARB & OTC VOC Content SCAQMD VOC Content 205° F (Initial)
ES3266
1. 物料型号:ES3266 2. 器件简介:Eco-Rite™ Glass Cleaner是一种环保、无痕迹的玻璃清洁剂,专门用于清洁玻璃、镜子、铬和其他反光表面。它是无毒的、可生物降解的,并且不含高挥发性有机化合物(VOC)、腐蚀性化合物和基于丁基的清洁剂。 3. 引脚分配:文档中没有提及引脚分配,因为这是关于清洁剂的文档,而不是电子元件。 4. 参数特性: - 沸点:205°F(初始) - 蒸发速率:小于1(与丁酸丁酯=1比较) - 闪点:无 - 比重:0.99 - 外观:清澈无色液体 - 气味:温和、清洁 - 水溶性:100% - pH值:7.0 - 保质期:2年 - 挥发性有机化合物(VOC)含量:2.8%VOC 5. 功能详解:Eco-Rite™ Glass Cleaner可以去除各种光滑表面的表面污渍和手印,包括玻璃、不锈钢、铬、镜子、塑料、陶瓷和搪瓷。 6. 应用信息:适用于清洁玻璃、不锈钢、铬、镜子、塑料、陶瓷和搪瓷等表面。 7. 封装信息:提供32盎司的触发式喷雾器(ES3266)和1加仑的浓缩液(ES166)。
兼容性表格显示Eco-Rite™ Glass Cleaner与ABS、Buna-N、Butyl、EPDM、石墨、HDPE、PVDF、LDPE、Lexan™、Neoprene、Noryl、Nylon™ 66、聚碳酸酯、聚丙烯、聚苯乙烯、PVC、硅橡胶和Teflon™等材料兼容。
使用说明建议在使用前仔细阅读材料安全数据表(MSDS),将清洁剂喷洒在待清洁的表面上,然后用Controlwipes™ Wipe或干净的无纺布擦拭。
CHEMTRONICS提供了技术热线以回答技术和应用相关问题,电话号码是1-800TECH-401,或通过电子邮件AskChemtronics@chemtronics.com联系。
安全和环境数据表明,该产品不含CFC、HCFC、nPB、HF和HFC,ODP值为0.0。
ES3266 价格&库存
很抱歉,暂时无法提供与“ES3266”相匹配的价格&库存,您可以联系我们找货
ES3266
