PA1631
PA1631
    GREENLEECOMMUNICATIONS(格林利)
    TOOL CRIMPER 14-24AWG AMP
PA1631 数据手册
CRIMPER 1600 OPEN BARREL AWG 24-14 Open Barrel Contact Pin Crimper Cat No: 52049994 UPC No: 769328100730 Description • • • • • • • Professional crimping tool for open-barrel box and round connector contacts with a wire range of 24-14 AWG (0.2-2.5 mm2) Precision fixed dual-plate dies for crimp accuracy Built-in locator Crimps non-insulated terminal lugs, cable lugs and parallel and serial splices or F-Type Works with Molex, Waldom & Leoco-type connectors Durable steel construction for long life Rubber-embedded ergonomic handles for low-effort operation Specifications • • • • • • Application : For Open-Barrel Box And RoundConnector Contacts With A Wire Range Of 24-14 AWG (0.200 - 2.500 SQ-MM) Crimping Range : Small: 24-22 AWG (0.050 - 0.200 SQ-MM), Medium: 18-14 AWG (0.340 - 0.750 SQ-MM) Handle Type : Rubber Embedded Ergonomic Material : Durable Steel Type : Open Barrel Contact Pin Weight : 14.000 OZ (400.000 GM)
PA1631 价格&库存
很抱歉,暂时无法提供与“PA1631”相匹配的价格&库存,您可以联系我们找货
