180-701-170-000
Instruction Sheet
IS-180S
PROPER USE GUIDELINES
Cumulative Trauma Disorder can result from the prolonged use of manually powered hand tools. NorComp hand
tools are intended for the occasional use and low volume applications.
DMC
BLUE
RED
HAND TOOL
CONTACT
SIZE RANGE
(AWG)
WIRE
INSULATION DIAMETER
Max in. [mm]
STRIP LENGTH
in. [mm]
180-701-170-000
28-24
0.040 [1.02]
0.100 [2.54]
Figure 1
1. INTRODUCTION
2. DESCRIPTION
NorComp 180-701-170-000 Hand Tool Assembly
consists of Die Assembly and Hand Tool Frame.
The tool features a tool frame with a stationary jaw
and handle, moving jaw, and moving handle. The
tool frame holds a die assembly with two crimping
chambers.
The die assembly features a wire anvil, insulation
anvil, wire crimper, and insulation crimper.
CAUTION
Read these instructions thoroughly
before crimping any contacts.
NOTE:
NorComp, Inc.
Charlotte, NC
Use 24-28 crimp section only for contacts:
180-001-170L001 / 180-101-170L001
180-002-170L001 / 180-102-170L001
This document is subject to change
Rev 8
11/15/2019
Page 1 of 3
Date Printed 11/15/2019
180-701-170-000
Tool
Stationary
Jaw
Instruction Sheet
IS-180S
5. Holding the wire in place, squeeze the tool
handles together until ratchet releases.
Allow tool handles to open and remove
crimped contact.
Wire Strip
Length
4. CRIMP PULL TEST
Wire & Insulation
should be visible in
Inspection Window
Figure 2
1. Refer
to
Section
3,
CRIMPING
PROCEDURE, and crimp the contact
accordingly to achieve pull test in Figure 3.
WIRE SIZE
Max AWG
TEST PULL
lb.
28
26
24
4
6
8
3. CRIMPING PROCEDURE
Strip the wire to the length indicated, taking care not
to nick or cut the wire strands. Select an applicable
contact and identify the appropriate crimping
chamber according to the wire size (24-28) markings
on the tool.
Figure 3
5. CRIMP HEIGHTS
Refer to Figure 2, and proceed as follows:
1. Hold the tool so that the front is facing you.
Squeeze tool handles together and allow
them to open fully.
2. Insert the contact (mating end first) into the
hole in the locator which corresponds with
the appropriate crimping chamber. Make
sure that the open “U” of the wire barrel and
insulation barrel face the stationary jaw.
CAUTION
Make sure that both sides of the
contact insulation barrel are started
evenly into the crimping chamber.
Do NOT attempt to crimp an
improperly positioned contact.
Figure 4
6. CRIMP ADJUSTMENT
1. See Manufacturers data sheet (GMT-DS)
supplied with hand tool.
7. DAILY MAINTENANCE
3. Hold the contact in position, and squeeze
the tool handles together until ratchet
engages sufficiently to hold the contact in
position. Do NOT deform insulation barrel
or wire barrel.
4. Insert stripped wire into contact insulation
and wire barrels until wire and insulation are
visible in inspection window, as shown in
Figure 2.
NorComp, Inc.
Charlotte, NC
Properly crimped terminals are controlled by the
following
maintenance
and
inspection
procedures.
1. Clean all dust, dirt, moisture and other
foreign matter from the crimp jaws that could
damage the crimp area of the dies.
DO NOT immerse tool in cleaning solution
Rev 8
11/15/2019
Page 2 of 3
180-701-170-000
Instruction Sheet
IS-180S
2. The pivot pin and ratcheted pawl-bearing
surface should be lubricated to ensure a
smooth operation.
DO NOT spray oil into tool to lubricate
3. When storing the tool, close the handles
until the ratchet pawl is about to be released
from the tooth of the ratchet. This will help
prevent the dies from being damaged.
8. VISUAL INSPECTION
The crimping dies should be inspected on a
regular basis to ensure that they have not
become worn or damaged.
1. Clean tool die area with solvent or brush.
2. Check crimp area of die for damages.
3. If tool jams or locks, check the ratchet for
dirt and lubrication.
9. CARE OF TOOL
There is virtually no maintenance required. However,
it is a good practice to keep indenter tips free of
residual color band deposits and other debris. A
small wire brush may be used for this purpose.
WE STRONGLY RECOMMEND THAT YOU
DO NOT:
attempt to disassemble tool or make repairs
THIS IS A PRECISION HAND CRIMPING TOOL
AND SHOULD BE HANDLED AS SUCH
NorComp, Inc.
Charlotte, NC
Rev 8
11/15/2019
Page 3 of 3
很抱歉,暂时无法提供与“180-701-170-000”相匹配的价格&库存,您可以联系我们找货
