YC-670R
YC-670R
    JST
    TOOL HAND CRIMPER 22-26AWG SIDE
YC-670R 数据手册
Tool Specification 1. Part Number: YC-670R 2. Terminal: BBH-001 T-PO.5 3. Application Crimp Position A B B AWG UL1007 AWG26 AWG24 (AWG 22) Tensile Strength N (Kgf) 15(1.53) min. 20(2.04) min. (25(2.55) min.) Strip Length mm 2.4 2.4 2.4 Crimp Position AWG • Check the crimp appearance and tensile strength prior to use. • Select the appropriate crimp position based on the AWG that will be used. • The AWG in ( ) above could cause excessive crin1ping. Check the tensile strength and crimp appearance to confirm an acceptable crimp. • The insulation barrel is set for type of wire listed and in not adjustable.
YC-670R 价格&库存
很抱歉,暂时无法提供与“YC-670R”相匹配的价格&库存,您可以联系我们找货
