Tool Specification
1. Part Number: YRS-1460
2. Terminal: SZE-002T-PO.3 / SZPD-002T-PO.3
3. Application
Crimp
Position
28
26-24
26-24
AWG
AWG
UL1061 AWG 28
UL1061 AWG 26
UL1061 AWG 24
Tensile
Strength N (kgf)
10(1.0)min.
20(2.0)min.
(30(3.1 )min.)
Strip
Length mm
2.1
2.1
2.1
Crimper(B)
Stopper
I
I
I
I
Anvil(B)
Anvil(A)
• Check the crimp appearance and tensile strength prior to use.
• Select the appropriate crimp position based on the wire size
that will be used.
• The wire size in ( ) above could cause excessive crimping.
Check the tensile strength and crimp appearance to confirm
an acceptable crimp.
• The insulation barrel is set for type of wire listed and in not
adjustable.
很抱歉,暂时无法提供与“YRS-1460”相匹配的价格&库存,您可以联系我们找货
