Small-sized, plastic type, push-pull lock connectors
RP17 Series
■Features
1. Superior mating operability
・ Secure mating and easy unmating is achieved
by a push-pull locking mechanism.
・ White index markings are provided on the mating
positions of the plug for easy mating alignment.
・Our proprietary guide key allows for blind mating
conditions to be accomplished easily.
Sep.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
2. Light weight and robust design
The strong outer shell is made of glass-reinforced
polycarbonate resin, and produces a light but
highly durable connectors.
3. Anti-static electricity type
The metal plates in the receptacle protect the signal
lines from static electricity.
■Product Specifications
Ratings
Operating
Rated Contact numbers 1, 3 to 10 : 2 A (when using a wire of at least 26 AWG)
−10 to +60℃
current Contact numbers 2, 11, 12 : 5 A (when using a wire of at least 22 AWG) temperature range
Rated
Storage
−10 to +60℃
AC100V, DC140V
voltage
temperature range
Items
Specifications
15mø max.
1. Contact resistance
DIP Type : 20mø max.
2. Insulation
1,000Mø min.
resistance
3. Withstanding
No flashover or dielectric breakdown.
voltage
4. Vibration
No electrical discontinuity for 10µs or
resistance
greater.
5. Shock resistance
greater.
Contact resistance : 20mø max.
6. Mating cycles
Dip type : 25mø max.
7. Temperature cycle Insulation resistance : 1,000Mø min.
8. Moisture
resistance
Insulation resistance : 10Mø min.
(at high humidities)
100Mø min. (when dry)
Conditions
Measured at DC 1A
Measured at DC 500V
AC 1000V for 1 minute
10 to 55Hz/cycle, amplitude : 0.75mm, 3 axis directions,
2 hours each direction
2
Acceleration : 490m/s , duration : 11ms, 3 axis directions,
3 times each direction
1,000 times
−55℃ : 30 minutes ➝ Normal temperature : 10 to 15 minutes ➝
85℃ : 30 minutes ➝ Normal Temperature : 10 to 15 minutes,
left for 5 cycles
Temperature : 40℃ , relative humidity : 90 to 95%,
left for 96 hours
■Materials / Finish
Items
Plug
Material
Finish
Remarks
Shell, insulator
Polycarbonate resin
UL94V-0
Clamp
Brass
Bushing
Receptacle
Shell, insulator
Female contact
Vinyl chloride resin
Poly carbonate resin
UL94V-0
Steel
Nickel plating
Phosphor bronze
Silver plating
Crimped female contact
Female contact
Phosphor bronze
Silver plating
Crimped male contact
Male contact
Phosphor bronze
Silver plating
In cases where the application will demand a high level of reliability, such as automotive,
please contact a company representative for further information.
2022.3
1
RP17 Series●Small-sized, plastic type, push-pull lock connectors
■Product Number Structure
Refer to the chart below when determining the product specifications from the product number.
Please select from the product numbers listed in this catalog when placing orders.
● Plug
RP17 A - 13 P A - 12 S C (01)
❶
❷
❸
❹
❺
❻
❼
❶ Model name : RP17 Series
❷ Type identification
No marking : Standard type
A : Anti-static electricity type
❸ Shell size : The shell size is measured at the outer
diameter of the mating interface of the plug.
❹ Shell type
P : Straight plug
R : Receptacle
J : Jack
❺ Shell variation : Connectors are distinguished by A, B, or
C if another variation is applied in the same form.
❽
❾
❻ Number of contacts
❼ Contact form
S : Female contact
P : Male contact
❽ Contact termination method:
C : Contact termination by crimping
D : Straight PCB dipping method
❾ Other specifications : A two-digit character is added to
indicate other specifications when needed.
● Crimp contact
RP17 - SC - 2 1 2
❶
❾
❶ Model name : RP17
❾ Contact type :
SC : Crimped female contact
PC : Crimped male contact
Contact form
1 : Loose piece contacts
2 : Reel contacts
2
Applicable wire gauge
1 : For 18 to 22 AWG
2 : For 24 to 30 AWG
Type of plating
2 : Silver plating
■Plug (standard type)
B
Ø15
ØA
36
(Representative example.)
RP17-13P-12PC(71)
HRS No.
ØA
B
RP17-13P-12PC(71)
113-0501-0 71
5.3
46
RP17-13PA-12PC(71)
113-0512-7 71
6.1
51
Note : Cable clamping force, cable rotation force, and other
aspects may differ depending on the cable construction.
We recommend that you verify the suitability of the cable
assembly before use or production.
■Plug (anti-static electricity type)
46
Ø15
Ø5.3
36
RP17A-13P-12PC(71)
Part No.
HRS No.
RP17A-13P-12PC(71)
113-0551-9 71
Note : Cable clamping force, cable rotation force, and others
■Receptacle (standard type)
(Crimping type)
45°
Ø1
9
5.5
2.5
Ø1
2-M2.6×0.45
2
1
5
12
7
25
5
3.2
Ø1
16.7
□9.7
Part No.
RP17-13R-12SC(71)
Part No.
HRS No.
RP17-13R-12SC(71)
113-0502-3 71
3
(PCB dip type)
45°
5
5.5
2.5
Ø1
Ø1
Ø1
2-M2.6×0.45
9
0.5×0.3
(Dip post diameter)
1
5
2
7
25
7.5
3.2
12
3.5
Part No.
HRS No.
RP17-13RA-12SD(71)
113-0511-4 71
Remarks : See page 5 for details on dip post assignment and layout.
■Receptacle (anti-static electricity type)
(PCB dip type)
3.5
12
3.2 7.5
25
45°
RP17A-13RA-12SD(71)
Part No.
Ø1
9
5.5
0.5×0.3
(Dip post for signal contact)
1×0.4
(Dip post for ground contact)
2.5
Ø15
2-M2.6×0.45
Ø1
RP17-13RA-12SD(71)
5
HRS No.
RP17A-13RA-12SD(71)
113-0553-4 71
■Jack (standard type)
RP17-13J-12SC(71)
HRS No.
A
ØB
RP17-13J-12SC(71)
113-0515-5 71
44
5.3
RP17-13JA-12SC(71)
113-0516-8 71
49
6.1
Part No.
4
Dip post assignment and layout for receptacles
(Figures show as when viewed from the receptacle mating side.)
● (Standard type)
● (Anti-static electricity type)
d
12
un
Ø0
ro
12
Ø0
2.4
1
7
10
7
1.2
3
3
1.6
11
3.8
3
10
12
12
1.2
3
4.6
2
6
1.2
1-
0.4
2.6
2.4
0.4
1
3
1.6
2.6
2
1
6
11
1.2
3
Remarks : The machining tolerance of ±0.05 is recommended for the PCB layout dimensions.
■Contact
Male contact
B
1.2
C
A
Applicable
wire size
RP17-PC-112
113-0503-6
1.6
2.1
18
to 22 AWG
Loose piece
contacts
RP17-PC-122 113-0504-9 1.2 1.35 24 to 30 AWG
Type
A-A
A
Reel
contacts
15
Female contact
A-A
A
Part No.
A
B
C
RP17-PC-222 113-0508-0 1.2 1.35 24 to 30 AWG
Applicable
wire size
Loose piece RP17-SC-112 113-0505-1 1.6 2.1 18 to 22 AWG
contacts
RP17-SC-122 113-0506-4 1.2 1.35 24 to 30 AWG
Reel
contacts
15
HRS No.
RP17-PC-212 113-0507-7 1.6 2.1 18 to 22 AWG
Type
C
B
1.2
1
1
1
Ø1
.7
G
1(
3.8
.7
t)
ac
nt
co
Part No.
HRS No.
B
C
RP17-SC-212 113-0509-2 1.6 2.1 18 to 22 AWG
RP17-SC-222 113-0510-1 1.2 1.35 24 to 30 AWG
Applicable tools
Type
Manual
Auto
Items
Part No.
RP17-TC-11
Manual
crimping tools RP17-TC-12
Automatic
CM-105C
crimping press
AP105-RP17-1
Applicator
AP105-RP17-2
HRS No.
Applicable contact
Applicable wire size
150-0043-8
RP17-PC
SC-112
18 to 22 AWG
150-0044-0
RP17-PC
SC-122
24 to 30 AWG
901-0001-0
901-2036-9
RP17-PC
SC-212
18 to 22 AWG
24 to 30 AWG
901-2026-5
RP17-PC
SC-222
Cable crimping tool
RP17-TC-01
150-0042-5
Extraction tool
RP6-SC-TP
150-0039-0
Extraction tool
Cable crimping tool
(The handle shape shown is a
representative example.)
Manual crimping tools
Automatic crimping press
(Type CM-105C)
5
Termination procedure
● Plug
Operation procedure
Cable
Cord tube
1. First, pass the terminated cable in the following order through the: cord
tube, spring, connection sleeve, and cord bushing. Then crimp and
terminate the contacts.
2. Assemble the crimped and terminated contacts to the contact holes of
the P-insulation P case. At this time, please make sure that the
crimped contacts are securely engaged onto the contact holes of the
P-insulation P case by slightly pulling on the cable.
3. Attach the metal fitting by clamping to it the cord bushing and assemble
these into the P-insulation P case. Then crimp the metal fitting by
clamping it with the applicable tool (RP17-TC-01).
4. Next, attach in the following order to the P-insulation P case:
connection sleeve, spring, and cord. Then align the screw hole of the
cord tube and that of the metal fitting for clamping, and tighten the
round flat screw to the specified torque of 0.15 to 0.2N·m.
In addition, in order to prevent loosening of the screw, please apply
Locktight 243 manufactured by Henkel Japan Ltd., Tokyo or equivalent.
5. After the assembly procedure described above has been completed,
please make sure that the connection sleeve moves correctly.
Round flat screw
Spring
Arrow view A
Connection sleeve
A
Cord
bushing
2 or more
Metal fitting for
clamping
+3
20 − 2
3.2±0.3
P-insulation
P case
Contact arrangement
2
1
3
6
Contact arrangement
7
10
12
11
Remarks : 1. The figure shows the receptacle when viewed from the mating end (plug connection end).
Precautions
This product series uses silver plated contacts. Silver reacts easily to exposure to sulfur gas so the below conditions may cause
tarnishing.
・Dusty environments
・Area with a high concentration area of gases such as sulfur dioxide gas, hydrogen sulfide gas, nitrogen dioxide gas and so on.
Example; In close proximity to factory exhaust, automotive emissions, etc.
・Close to heaters, or in other areas marked by extreme temperature differences or high humidity.
・Close to rubber products includes rubber adhesives.
The Electrical connection is not affected by tarnishing on a silver surface due to the wiping effect of the contact pins.
Storage
Packing state; Packed in original packing or equivalent container
Temperature -10 to +60ç
Humidity
85% Max
(It is recommended that the product be stored in an area of normal level of temperature and humidity, and free of any
temperature fluctuation)
Please use this products within 6 months of delivery.
(After 6 month, please check the solderbility before use)
“Storage” means long-term storage of the unused products in sealed packaging, prior to assembly to PCB.
Please note that the white label on the connector may come off due to solvents such as alcohol.
2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN
https://www.hirose.com/
6
The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use.
The contents of this catalog are current as of date of 03/2022. Contents are subject to change without notice for the purpose of improvements.
