WWW.GREENLEE.COM
EK50ML120 • EK50ML138
MICRO CRIMPING TOOL
CRIMP 3X FASTER WITH 90% LESS FORCE
USA
PHONE 800.435.0786
FAX 800.451.2632
CANADA
PHONE 866.384.8813
FAX 800.524.2853
INT’L
PHONE +1.815.397.7070
FAX +1.815.397.9247
TIMES CHANGE.
SO DO REQUIREMENTS.
FAST
65% faster crimping cycle
vs ratcheting tool
250 crimps per cycle charge*
ERGONOMIC
Total weight 2.2 lbs
Reduces hand force from
53 lbs to 6 lbs
INTELLIGENT
• Gator Eye™ crimping diagnostics
• LED multi-functional light to
ensure crimp is complete
*When crimping 10AWG wire.
Monitors statistical performance of all cycles,
integrity of operations, and manages inventory
with user identifiable information.
FEATURES
• LED work light
• Patented Jaw Actuation
for crimping cycle
• Innovative trigger with
PowerSense™ Technology
• Overmolded grip for maximum comfort
• 10.8V Li-Ion battery with charge indicator
THE REVOLUTIONARY POWERSENSE™ FUNCTION
TECHNOLOGY
1. Manual Clamping Over molded grip
2. Motorized Crimping
for additional stability
clamp
PowerSense™ Technology: Pull trigger
part way and adjust material to ideal
position before crimping.
Depress trigger completely to
activate motorized crimp.
crimp
CM-1560
Fast. Ergonomic. Intelligent.
EK50ML - THE WAY YOU CRIMP TODAY
29%
ACCORDING TO THE NATIONAL
COUNCIL OF COMPENSATION
INSURANCE, THE TYPICAL COST OF
CARPAL TUNNEL SURGERY IS
OF ALL INJURIES INVOLVING
REPETITIVE USE OF TOOLS
RESULT IN CARPAL TUNNEL
SYNDROME.
- Bureau of Labor Statistics
$33,000
"By using the Greenlee Micro Crimper, we were able
to nearly eliminate hand fatigue in our high volume
crimping operations. Use of this tool will go a long way
toward eliminating carpal tunnel syndrome risks."
- Universal Electric Corporation
HAND
FORCE
REDUCTION
3. … and Done
Release trigger and jaws will
open automatically.
www.greenlee.com
FOR YOUR LARGER CRIMPING NEEDS
EK6IDL CRIMPING TOOL
• Tool marking – Provides clear marking of crimped connectors
• Flip top style rotating head
• Intelli-CRIMP™ technology measures pressure and amperage
32 times a second
−− Two-stage telescopic design identifies
correct pressure to apply
• Single trigger operation for controlling all tool functions
• Broad crimp range for stranded and fine stranded wire class
FOR PRODUCT VIDEOS,
DEMONSTRATIONS AND MORE VISIT:
ORDERING INFORMATION
CAT. NO.
EK50ML120
UPC NO.
www.youtube.com/GreenleeDEMO
DESCRIPTION
EK50ML12011
03105
Crimping tool kit with 12mm jaw and 110V charger with carrying case
EK50ML13811
03108
Crimping tool kit with 13.8mm jaw and 110V charger with carrying case
EK50ML12022
03123
Crimping tool kit with 12mm jaw and 230V charger with carrying case
EK50ML13822
03124
Crimping tool kit with 13.8mm jaw and 230V charger with plastic carrying case
EK50ML120B
03128
12mm jaw EK50ML bare tool
EK50ML138B
03130
13.8mm jaw EK50ML bare tool
MBP108
03127
10.8V EK50ML Li-Ion Battery
MBC110
03125
10.8V EK50ML Li-Ion Battery Charger, 110V
MBC230
03126
10.8V EK50ML Li-Ion Battery Charger, 230V
EK50MLCASE
03131
EK50ML Carrying Case
EK50ML138
The EK50ML138 is compatible with all Greenlee Kwik Cycle®
and CrimpALL® dies for various types of cables and sizes.
COMPATIBLE DIE SETS
Wezag®
EK50ML120
EK50ML138
www.greenlee.com
MA6218 12/18
CS30, CS150
4455 Boeing Drive • Rockford, IL 61109-2988 • USA • 815-397-7070
©2018 Greenlee Tools Inc. • An ISO 9001 Company • Printed in USA
Panduit®
CT-2600,CT-300
Thomas & Betts®
Ideal®
Sta-Kon®
Crimpmaster™
很抱歉,暂时无法提供与“EK50ML120B”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+5426.238211+702.02876
