YC-203
YC-203
    JST
    TOOL HAND CRIMPER FOR YC SERIES
YC-203 数据手册
OPERATION MANUAL FOR YC tools The Quality Connection (HAND CRIMP TOOL FOR LOOSE PIECE OPEN BARREL TERMINALS) t t 't'l,'l/t/t+++t+l:H-'Ht t tlc+++l tlllll/t'lt t-tl--H--l+--H--t-l+H+~~'l1/t/t/t/tl.i 1. General The YC series hand crimp tools are used to crimp loose piece open barrel terminals to wire in the recommended wire range for each terminal. Each tool has two crimping sections (A & B). Please refer to tho chart to find which section should be used. Some tools come equipped with a locator spring to aid in positioning of the terminal. 2. Crimp Operation (1) Squeeze handles until the ratchet releases and handles open. (2) Position a teminal in A or B section as shown in Fig. 1. (3) If the tool is the locator-equipped type, place the terminal as shown in Fig. 3, so that the locator comes between the wire barrel and the insulation barrel. (4) Squeeze handles gently until the terminal is held by the dies per Fig. 2. Do not deform the terminal at this stage. (5) Now insert a wire, which is stripped per Fig. 4 into the barrels of the terminal. (6) Squeeze handles completely until the ratchet releases, holding the wire by hand in the proper position. (7) Open handles, remove the crimped terminal and inspect it. (See Fig. 5. ) r ···-1~_.-- _.------_ .. __. _ - - - - - - - , I I wire barrel side . insulation side Fig. 1 Fig. 2 I I locator terminal wire barrel insulatio~ barrel ~-lB f~ wire ,---- I I n l+(O.5to 10mm) shall not have cracks dmlff shall not have cracks ~-~J Fig.3 Fig_ 4 Fig.5 Note: Refer to catalog for dimension l of barrel length. 3. Suggestions a. Do not use tool if broken or damaged in any way. Return to JST or the nearest representa­ tive. Do not attempt to repair or adjust dies or ratchet. J. There are no adjustments for crimp heights in this tool. For improved crimping, please consid­ er the purchase or lease of one of JST's crimp machine. b. Periodically oil all parts of the tool and store in paper or plastic bag when not in use. k. The YC-2A, locator-equipped type of YC-2, is to be applied to a-marked terminals only. c. To check if a wire is crimped correctly. measure wire tensile strength. Consult JST jf wire tensile strength specifications are needed. I. The prefix '8' or 'L' in the terminal part no. denotes the terminal barrel configuration as shown below. The chain terminals can be terminated with the YC type crimping tool if they are first cut into individual contacts (as in the case of end to end terminals)or cut off their carrier strip (as in the case of side terminals) _ In that case, the barrel condition is as descrived with the suffix d. Make sure correct tool and section are used for each terminal. e. Do not abuse tooi or use in a manner not intended. 'B' . f. The ratchet mechanism does not allow handles to open until crimping is completed. Do not open handles by force. g. Do not use the tool with rust, damage or foreign particles on the dies. h. When hand crimping board-in terminals (** marked ones). care should be taken not to con­ taminate their solder tails, as with greasy or oily fingers. If a solder problem arises, some cleaning of the tips of the terminal may be advisable. terminal barrels Type Type 'l' 'B' Fig. 0 m. I ne crimp height is not abjustable, therefore, applicable wires are limited. Check the appear­ ance and the tensile strength for every kind of wire. i. Before operation, make sure:­ n. For any questions, please contact JST. • Dies are clean without damage. rust or dirt. • Ratchet mechanism functions well. • Terminals are properly crimped. (Try a couple of samples and check the appearance, etc.) In line with a policy of continual product development, JST reserves the right to change the specifications of the goods at any time and without prior notice.
YC-203 价格&库存
很抱歉,暂时无法提供与“YC-203”相匹配的价格&库存,您可以联系我们找货
