EK50ML138B
EK50ML138B
    GREENLEECOMMUNICATIONS(格林利)
    BARE TOOL 13MM JAW
EK50ML138B 数据手册
WWW.GREENLEE.COM EK50ML120 • EK50ML138 MICRO CRIMPING TOOL CRIMP 3X FASTER WITH 90% LESS FORCE USA PHONE 800.435.0786 FAX 800.451.2632 CANADA PHONE 866.384.8813 FAX 800.524.2853 INT’L PHONE +1.815.397.7070 FAX +1.815.397.9247 TIMES CHANGE. SO DO REQUIREMENTS. FAST • • 65% faster crimping cycle vs ratcheting tool 250 crimps per cycle charge* ERGONOMIC • • Total weight 2.2 lbs Reduces hand force from 53 lbs to 6 lbs INTELLIGENT • Gator Eye™ crimping diagnostics • LED multi-functional light to ensure crimp is complete *When crimping 10AWG wire. Monitors statistical performance of all cycles, integrity of operations, and manages inventory with user identifiable information. FEATURES • LED work light • Patented Jaw Actuation for crimping cycle • Innovative trigger with PowerSense™ Technology • Overmolded grip for maximum comfort • 10.8V Li-Ion battery with charge indicator THE REVOLUTIONARY POWERSENSE™ FUNCTION TECHNOLOGY 1. Manual Clamping Over molded grip 2. Motorized Crimping for additional stability clamp PowerSense™ Technology: Pull trigger part way and adjust material to ideal position before crimping. Depress trigger completely to activate motorized crimp. crimp CM-1560 Fast. Ergonomic. Intelligent. EK50ML - THE WAY YOU CRIMP TODAY 29% ACCORDING TO THE NATIONAL COUNCIL OF COMPENSATION INSURANCE, THE TYPICAL COST OF CARPAL TUNNEL SURGERY IS OF ALL INJURIES INVOLVING REPETITIVE USE OF TOOLS RESULT IN CARPAL TUNNEL SYNDROME. - Bureau of Labor Statistics $33,000 "By using the Greenlee Micro Crimper, we were able to nearly eliminate hand fatigue in our high volume crimping operations. Use of this tool will go a long way toward eliminating carpal tunnel syndrome risks." - Universal Electric Corporation HAND FORCE REDUCTION 3. … and Done Release trigger and jaws will open automatically. www.greenlee.com FOR YOUR LARGER CRIMPING NEEDS EK6IDL CRIMPING TOOL • Tool marking – Provides clear marking of crimped connectors • Flip top style rotating head • Intelli-CRIMP™ technology measures pressure and amperage 32 times a second −− Two-stage telescopic design identifies correct pressure to apply • Single trigger operation for controlling all tool functions • Broad crimp range for stranded and fine stranded wire class FOR PRODUCT VIDEOS, DEMONSTRATIONS AND MORE VISIT: ORDERING INFORMATION CAT. NO. EK50ML120 UPC NO. www.youtube.com/GreenleeDEMO DESCRIPTION EK50ML12011 03105 Crimping tool kit with 12mm jaw and 110V charger with carrying case EK50ML13811 03108 Crimping tool kit with 13.8mm jaw and 110V charger with carrying case EK50ML12022 03123 Crimping tool kit with 12mm jaw and 230V charger with carrying case EK50ML13822 03124 Crimping tool kit with 13.8mm jaw and 230V charger with plastic carrying case EK50ML120B 03128 12mm jaw EK50ML bare tool EK50ML138B 03130 13.8mm jaw EK50ML bare tool MBP108 03127 10.8V EK50ML Li-Ion Battery MBC110 03125 10.8V EK50ML Li-Ion Battery Charger, 110V MBC230 03126 10.8V EK50ML Li-Ion Battery Charger, 230V EK50MLCASE 03131 EK50ML Carrying Case EK50ML138 The EK50ML138 is compatible with all Greenlee Kwik Cycle® and CrimpALL® dies for various types of cables and sizes. COMPATIBLE DIE SETS Wezag® EK50ML120 EK50ML138 www.greenlee.com MA6218 12/18 CS30, CS150 4455 Boeing Drive • Rockford, IL 61109-2988 • USA • 815-397-7070 ©2018 Greenlee Tools Inc. • An ISO 9001 Company • Printed in USA Panduit® CT-2600,CT-300 Thomas & Betts® Ideal® Sta-Kon® Crimpmaster™
EK50ML138B 价格&库存
很抱歉,暂时无法提供与“EK50ML138B”相匹配的价格&库存,您可以联系我们找货
