The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information.
All non-RoHS products have been discontinued, or will be discontinued soon. Please check the products status on the Hirose website RoHS search at www.hirose-connectors.com, or contact your Hirose sales representative.
DN SERIES-NEW D SUBMINIATURE
INTERFACE CONNECTORS
Sep.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
Nov.1.2016 Copyright 2016 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
General
The DN series are compact, rectangular multi-contact
connectors developed to meet the demand for smaller
and slimmer electronic equipment. 2.54 mm grid contact position and Direct dip soldering on PCB enable
high density circuit designing at reduced cost.
Aluminum die-cast shell and Metallic shell areshieledto
prevent from Electro-Magnetic interference. 20, 26, 36
and 50 way available.
Features
1. 2.54 mm grid contact position enable high density
circuit designing.
2. Stable quality due to the contact design based on
our field-proven SM series (D sub-connector).
3. One-touch lock system ensures perfect operation.
4. The cover case uses a thin, low-back compact design
that meets the needs of high density mounting. It
can be mounted between 17.78 millimeters (700mil)
substrates.
5. The cover case is made of aluminum diecast to
shield aginst electromagnetic waves In a combination with a connector metal shell, the cover case is
an ideal solution for noise.
6. Dip soldering connectors are provided with snap
clamps for temporarily fixing the connector on the
PCB.
7. IDC termination types are for standard 1.27 mm pitch
cables, and are available for two types of cables:
AWG26 and AWG28.
8. Crimp contact cables from AWG26 through AWG28.
9. Allows you to take out the cable vertically or horizontally, as your application requires.
Application
Office Automation, Computers, Communications Equipment, Factory Automation, Home Automation and other
commercial applications needing high density interconnections.
169
02/2021
04/2009
Specifications and Material
Main specifications
Main materials used
Current capacity
3A
Shell
Rated voltage
AC 200V
Insulator
PBT*
Contacts
Phosphor bronze
Insulation
resistance
5000mΩ on higher
at DC 500V
Contact
resistance
20mΩ or less
at DC 100mA
Withstand
voltage
1 minute AC 1000 Vrms
Aluminum dei-cash
Silver coating
Black
Nickel plating
andplating
Selective gold plating
Selective
gold
*UL94V-0
Ordering Information
DN 10 − 26 S( )
(1) (2)
(3) (4) (8)
DN − 26 − CVE 1
(1)
(3)
(5)
DN 50 − 2628 PC 1
(1) (2)
(6)
(7)
(1) Series Number: DN
(2) Type
10: Right Angle DIp Type
30: IDC Plug Type
50: Crimp Type
(3) No. of Pins: 20, 26, 36 and 50 way
(4) P: Plug
S: Receptacle
(5) Shell
CVE1: Angle Cable Exit Shell
CV1: Straight Cable Exit Shell
(6) Applicable Wire
2628: AWG#26 ~ AWG#28
(7) Type of Contact Pin
PC1: Bulk Pin Contact
PC2: Chain Pin Contact
(8) Specification
(50): RoHS
RoHS compliant
(50):
compliant
(70): RoHS compliant
Cable specifications
N: Pin
Pin: AWG#28(7/0.127)
AWG#26(7/0.16)
2 170
02/2021
04/2009
Crimp Pin Housing
DN50-26P
Unit: mm
HRS No.
No.of pin
Part No.
A
B
C
225-0016-3
225-0004-4
DN50-20P
DN50-26P
35.36 22.86 31.38
42.98 30.48 39
225-0005-7
225-0006-0
36
50
DN50-36P
DN50-50P
55.68 43.18 51.7
73.46 60.96 69.48
HRS No.
No.of pin
Part No.
A
B
C
225-0030-4-50
225-0029-5-50
DN30-20P(50)
DN30-26P(50)
35.36
42.98
29.1
36.7
31.38
39
225-0027-0-50
225-0028-2-50
36
50
DN30-36P(50)
DN30-50P(50)
55.68
73.46
49.4
67.2
51.7
69.48
RoHS
YES
IDC Plug
DN30-36P(50)
Unit: mm
RoHS
YES
171 3
02/2021
04/2009
DN-26-CVE1
Unit: mm
HRS No.
No.of pin
Part No.
A
B
C
225-0019-1
225-0020-0
DN-20-CVE1
DN-26-CVE1
45.9
53.5
12.7
13.7
9
9.7
RoHS
225-0021-3
225-0022-6
36
50
DN-36-CVE1
DN-50-CVE1
66.2
84
14.2
11
14.2 12×13
HRS No.
No.of pin
Part No.
A
B
C
RoHS
225-0031-7
225-0024-1
DN-20-CV1
DN-26-CV1
45.9
53.5
13.7
13.7
9
9.7
YES
225-0025-4
36
DN-36-CV1
66.2
14.2
11
YES
DN-26-CV1
Unit: mm
4 172
02/2021
04/2009
Right Angle P.C. Mount Receptacle
(Dip Post)
DN10-26S(50)
70
Unit: mm
HRS No.
225-0015-0-50
225-0001-6-50
225-0002-9-50
225-0003-1-50
No.of pin
Part No.
DN10-20S(50)
DN10-26S(50)
DN10-36S(50)
DN10-50S(50)
36
50
A
B
C
32
39.6
38.9
46.5
22.86
30.48
52.3
70.1
59.2
77
43.18
60.96
RoHS
YES
PCB Layout
mounting panel thickness 1.6mm
Unit: mm
No.of pin
A
B
36
50
32.0 39.6 52.3 70.1
22.86 30.48 43.18 60.96
PCB End
173 5
02/2021
04/2009
(Dip Post)
DN20B-26S(50)
70
Unit: mm
HRS No.
225-0045-1-50
225-0046-4-50
225-0047-7-50
225-0048-0-50
No.of pin
36
50
Part No.
DN20B-20S(50)
DN20B-26S(50)
DN20B-36S(50)
DN20B-50S(50)
A
B
C
D
38.9
60.9
68.5
81.2
99
22.86
30.48
43.18
60.96
53.9
46.5
59.2
77
61.5
74.2
92
RoHS
YES
PCB Layout
min
Contact No.1
min
Straight P.C. Mount Receptacle
min
Panel Cutout
Unit: mm
No.of pin
A
B
C
9
40.9
26
36
50
61.5
74.2
92
12
17
24
48.5
61.2
79
Note: 1. Use a 1.6-mm thick panel
2. The substrate reference drawing shows the connector-mounting
surface. The area marked with [ ] is to be prohibited from entering any pattern.
3. The substrate and panel are related to each other, with a 0/3.2
mounting hole as the reference point.
4. The panel is 1.6 millimeters thick.
6 174
02/2021
04/2009
Pin Crimp Terminal
DN50-2628PC1
(Bulk)
DN50-2628PC2
(Chain)
Note: Bulk in bags of 100pc. Chain on reels of 1,000pcs
HRS No.
Part No.
Remarks
225-0007-2
DN50-2628PC1
Loose piece contact
225-0008-5
DN50-2628PC2
Strip contact
RoHS
YES
Applicable Wire
Applicable wire: AWG No.26 ~ AWG No.28
Outer diameter of applicable wire
Unit: mm
Way
36
50
Outer diameter
Max.
9.0
Max.
9.7
Max.
11.0
Max.
12.0
Tooling (for Crimp Plug)
• CM-105 Crimp Maching
This machine has been carefully designed to meet
the many requests for advanced crimping machines
that can be used in a wider range of applications.
This machine offers easy setup adjustment and applicator mounting. We are confident that the machine
will find many applications as an easy-to-use semiautomatic machine for crimping strip contacts.
POWER SOURCE
AC 100V 200W
TOTAL WEIGHT
75 kgs
PERFORMANCE
2,000-4,000 crimps per hour
WORK RANGE
Adaptable to other HIROSE dies
Semi-Auto Machine
CM-105
CM-105C
(CL901-0005-4)
(CL901-0001-0)
Applicator
(Die)AP105-DN50-2628P
105-DN50
Applicator (Die)
(CL901-0208-1)
(CL901-2515-1)
Hand Tool
DN50-TA2628HC
(CL250-0101-0)
175
7
02/2021
04/2009
Tooling (for IDC Plug)
Hand Press
Pressure Block
Universal Guide Plate
HRS No.
Part No.
HRS No.
Part No.
HRS No.
Part No.
902-0068-0
902-0069-3
902-0143-4
DN30-26PB
DN30-36PB
DN30-20PB
902-0067-8
DN30-XXGP
550-0082-2
Hi-Flex termination
press and accessories
902-0144-7
DN30-50PB
Hi-Flex Termination Press and Accessories
General
The Hi-Flex termination press and its accessories connect the connectors to the HIF series ribbon cables more
securely and quickly.
Features
1. No incomplete connections. A preventive ratcht-type
device ensures against misconnections.
2. Prevents damage to connectors during connection.
The guide plate works as a stopper to prevent damage to connectors due to connection pressure.
3. Easy to position the connector and cable. The guide
plate case guide and cable stopper help positioning.
4. Capable of cable connection at an intermediate point
when the cable stopper is removed.
8 176
02/2021
04/2009
