MDF6 Series
Sep.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
3.5mm Pitch, Double Row, Compact Internal Power Connector
(UL/CSA Standard Certified Product)
Feb. 2021 ②
MDF6 Series/3.5mm Pitch, Double Row, Compact Internal Power Connector (UL/CSA Standard Certified Product)
Features
1. 3. 5mm pitch compact
connector
MDF6 Series is a compact, space- saving power
connector with a 3. 5mm × 5mm pitch set in a
double row alignment configuration.
Inner Positive Lock
2. 7A Current Capacity
Compact power connector that maintains a
current capacity of 7A when using 16 AWG
( UL/ CSA standard is 6A) .
3. Box Type Header
The box type header is highly resistant to prying
and is polarized to prevent mis- insertion.
Mis-insertion Prevention Design
4. Internal Positive Lock
Secure mating with enhanced safety is secured
by the internal positive lock.
Applications
Internal power supply for various devices
2
Product Specifications
Rated Current (Note 1)
16 AWG
18 AWG
20AWG
22 AWG
7A/pin
6A/pin
5A/pin
4A/pin
Rated Voltage
300V AC/DC
Rated Current
-30 to 85℃
Operating Humidity Range (Note 3)
40 to 80%
Storage Temperature Range
-10 to 60℃
Storage Humidity Range
40 to 70%
16 AWG
18 AWG
20 AWG
22 AWG
6A/pin
6A/pin
4A/pin
4A/pin
UL/CSA
UL : 250V AC
Rated Voltage
Operating Temperature (Note 2)
CSA : 30V AC
■ UL CSA Safety Standard File No.
UL : E52653
CSA : LR95109
Item
Specifications
Conditions
Insulation
Resistance
1000M Ω Min.
500V DC
Withstanding
Voltage
No flashover or insulation
breakdown.
1,500V AC per min.
Contact Resistance
30m Ω Max.
1mA
Vibration Resistance
No electrical discontinuity
of 1μ s or more
Frequency : 10 to 55Hz, single amplitude of 0.75mm, 10 cycles in each of the
3 directions.
Humidity (Steady
state)
Contact Resistance :
30m Ω Max.
Insulation Resistance :
1000M Ω Min.
96 hours at temperature of 40 ± 2℃ and humidity of 90% to 95%
Temperature Cycle
30m Ω Max.
1000M Ω Min.
(-55℃ : 30 minutes → 5 to 35℃ : 10 minutes → 85℃ : 30 minutes → 5 to 35℃
: 10 minutes) 5 cycles
Mating Durability
30m Ω Max.
Tin Plated : 30 cycles
Soldering Heat
Resistance
No deformation of components
affecting
performance.
Flow : 250℃ for 10 seconds
Manual soldering : 300℃ for 3 seconds
Note
Note
Note
Note
1
2
3
4
The rated current changes depending on the cable used. Only the rated current of the header is 7A.
Includes temperature rise due to current flow.
No condensing.
Information contained in this catalog represents general requirements for this Series. Contact us for the drawings and specifications for a specific part
number shown.
Material / Finish
Product
Part
Material
Finish
Remarks
Crimp Socket
Insulator
Polyamide Resin
Natural (White)
UL94V-0
Socket Crimp Contact
Contact
Phosphor Bronze
Tin Plating
Insulator
Polyamide Resin
Natural (White)
UL94V-0
Contact
Brass
Tin Plating
Pin Header
3
RoHS2
〇
Product Number Structure
■ Connector
MDF6 - # DS - 3.5 C
❶
❷
❸
❹
❺
❶
Series Name
MDF6
❹
Contact Pitch
3.5mm
❷
No. of Pos.
4 to 20
❺
Contact Type
❸
Connector Type
DS : Double Row Socket
DP : Double Row Pin Header
C : Crimp Socket
DSA : Straight Pin Header
DS : Right Angle Pin Header
❷
Packaging Type
SCF : Socket Contact, Reel
SC : Socket Contact, Pack
■ Contact
MDF6 - 1618 SCF
❶
❶
Applicable Cable
Size
❷
1618 : 16-18 AWG
2022 : 20-22 AWG
4
Double Row Socket
A
B
C
P=3.5
CAV No. Mark
5
8.2
14.2
Shown with crimp contacts assembled.
5.5
4.2
10.4
A
Polarity Mark
1 3
2 4
Contact No. Mark
Part No.
HRS No.
No. of Pos.
A
B
C
MDF6-4DS-3.5C
CL0547-0074-1-00
4
10.5
8.1
3.5
MDF6-6DS-3.5C
CL0547-0075-4-00
6
14.0
11.6
7.0
MDF6-8DS-3.5C
CL0547-0076-7-00
8
17.5
15.1
10.5
MDF6-10DS-3.5C
CL0547-0077-0-00
10
21.0
18.6
14.0
MDF6-12DS-3.5C
CL0547-0078-2-00
12
24.5
22.1
17.5
MDF6-14DS-3.5C
CL0547-0079-5-00
14
28.0
25.6
21.0
MDF6-16DS-3.5C
CL0547-0080-4-00
16
31.5
29.1
24.5
MDF6-18DS-3.5C
CL0547-0081-7-00
18
35.0
32.6
28.0
MDF6-20DS-3.5C
CL0547-0082-0-00
36.1
31.5
5
Purchase Unit
100pcs per bag
16.3
11.5
2.4
2.6
1.4
4.9
2.3
Applicable Cable Indicator
Part No.
HRS No.
MDF6-1618SCF
CL0547-0070-0-00
MDF6-1618SC
CL0547-0071-3-00
MDF6-2022SCF
CL0547-0072-6-00
MDF6-2022SC
CL0547-0073-9-00
Applicable Cable Applicable Cable
AWG Size
Jacket Diameter
16-18 AWG
φ 2.5 to 2.0
20-22 AWG
φ 1.9 to 1.5
Type
Purchase Unit
Reel Contact
5000pcs per reel
Loose Contact
100pcs per bag
Reel Contact
5000pcs per reel
Loose Contact
100pcs per bag
Applicable Cable (Tin Plated Annealed Copper Wire)
Conductor Size (Wire Construction)
16 AWG(26/0.254mm)
18 AWG(34/0.18mm)
20 AWG(21/0.18mm)
22 AWG(17/0.16mm)
Jacket Diameter
Recommended Cable
Strip Length
UL1061, UL1007
2.7 to 4.4mm
φ 2.5 to 2.0
φ 1.9 to 1.5
Note : Please contact a Hirose sales representative when using cables other than those specified.
6
Double Row Pin Header : Straight Type
5
5.8
Polarity Mark
□ 0.76
10.5
5.6
13
0.76×1.52
3.5
●Applicable Through Hole Diameter of PCB :
φ1.3+0.1
●Applicable PCB Thickness : 1.6±0.2
2.3
10.9
A
B
P=3.5
2.7
CAV No. Mark
1
A
2
Contact No. mark
Part No.
HRS No.
No. of Pos.
A
B
MDF6-4DP-3.5DSA(23)
CL0547-0083-2-23
4
10.5
3.5
MDF6-6DP-3.5DSA(23)
CL0547-0084-5-23
6
14.0
7.0
MDF6-8DP-3.5DSA(23)
CL0547-0085-8-23
8
17.5
10.5
MDF6-10DP-3.5DSA(23)
CL0547-0086-0-23
10
21.0
14.0
MDF6-12DP-3.5DSA(23)
CL0547-0087-3-23
12
24.5
17.5
MDF6-14DP-3.5DSA(23)
CL0547-0088-6-23
14
28.0
21.0
MDF6-16DP-3.5DSA(23)
CL0547-0089-9-23
16
31.5
24.5
MDF6-18DP-3.5DSA(23)
CL0547-0090-8-23
18
35.0
28.0
MDF6-20DP-3.5DSA(23)
CL0547-0091-0-23
31.5
7
Purchase Unit
100pcs per bag
Double Row Pin Header : Right Angle Type
A
B
2.3
5.8
Polarity Mark
19.95
10.5
5
22
5.6
0.76×1.52
Contact No. Mark
1
A
CAV No. Mark
□ 0.76
Part No.
HRS No.
No. of Pos.
A
B
MDF6-4DP-3.5DS(23)
CL0547-0270-0-23
4
10.5
3.5
MDF6-6DP-3.5DS(23)
CL0547-0271-2-23
6
14.0
7.0
MDF6-8DP-3.5DS(23)
CL0547-0272-5-23
8
17.5
10.5
MDF6-10DP-3.5DS(23)
CL0547-0273-8-23
10
21.0
14.0
Application Pattern
Cable
25.7
5.5 5
2.7
3.5
13.6
16.7
Cable
3.5
●Applicable Board Hole Diameter of PCB :
φ1.3+0.1
5
11.3
3.5
P=3.5
2.05
5
14.95
8
Purchase Unit
100pcs per bag
Applicable Crimping Tool
Type
Part No.
Main Press Unit
Applicator
Manual Crimping Tool
Extraction Tool
HRS No.
Applicable Contact
CM-105C
CL0901-0001-0-00
AP105-MDF6-1618S
CL0901-4512-4-00
MDF6-1618SCF
AP105-MDF6-2022S
CL0901-4513-7-00
MDF6-2022SCF
MDF6-TA1618HC
CL0550-0203-5-00
MDF6-1618SC
MDF6-TA-2022HC
CL0550-0204-8-00
MDF6-2022SC
DF-C-PO(A)
CL0550-0170-8-00
MDF6-####SC(F)
Note 1 : Issues caused by tools other than those specified by Hirose are outside the scope of warranty.
Note 2 : Please conduct crimping work according to the "Crimp Quality Standard (ETAD-H0792-00)" and "Crimp Condition Table".
Note 3 : When non-authorized tools are used, please consult with Hirose sales representative about provision of the drawing of the crimping tool.
Precautions When Crimping
■ Required Documents Prior to Crimping
The work- related documents listed below are required before beginning cable assembly ( The ● mark indicates required
documents) . Please contact a Hirose sales representative if you do not have these documents.
Description
Automatic
Crimping
Machine
Hand
Crimping
Tool
1. Crimping Machine Main
Unit Instruction Manual
Explanation of main press machine unit
2. Applicator Instruction
Manual
Crimping Method
3. Applicator Spare Parts
List
Explanation for Applicator Installation
4. Crimp Conditions
Standard crimp height and tensile
strength values
5. Crimp Quality Standards
Various standards for crimping
conditions
6. Operating Instructions for
Hand Tool
Crimping method, standard crimp height
and tensile strength values
Document Title
Reference
Bundled with purchase of
main press machine unit.
applicator.
hand tool.
■ Tools
Use the tools designated by Hirose when performing crimping. Crimping performed with tools other than those designated
is outside the scope of warrantly. The operating instruction manual for the crimping machine and applicator are provided.
Be sure to carefully read the operating instructions before beginning work.
■ Applicable Cables
Check that the cables to be used are within the applicable range. If you intend to use a cable other than those
recommended, contact a sales representative.
[ Precautions]
• Cables applicable to crimping connectors are tin- plated stranded soft- copper wire.
• Avoid crimping solid wire, wires with polyester threads or tin coated wires.
• Avoid crimping two cables together.
• The crimp height setting values ( Note) may vary between tin- plated and gold- plated terminals even if the same electric
wires are used.
• The crimp height setting values ( Note) may vary depending on the difference in the core wire configuration even if the
computed cross- sectional area is the same.
Note : The crimp height is an important item that determines crimping quality. We execute crimping tests for each electric wire to ensure the optimal value for the
crimp height with high precision, thereby ensuring optimal setup values.
9
Precautions
Please refer to the "Wire-to-Board Connector Use Handbook".
2.Connection
Conditions
3.Precautions
■ The color of the plastic molding may differ slightly depending on product lot and future storage conditions but
this does not affect the product performance.
4.Handling
Please refer to the following documents when handling the product.
■ Crimp Quality Standard(ATAD-H0792-00)
■ Wire-to-Board Connector Use Handbook
1.Cleaning
Conditions
While taking in consideration
Specifications mentioned in this catalog are reference values.
When considering to order or use this product, please confirm the " Drawing" and " Product Specifications" sheets.
Use an appropriate cable when using the connector in combination with cables.
If considering usage of a non- specified cable, please contact your sales representative.
If assembly process is done by jigs & tools which are not identified by Hirose assurance will not be given.
Please consult with your Hirose sales representative if you are planning to use the product for any of the following
applications. ( Automotive, medical, public infrastructure, aerospace/ defense, etc. )
Hirose will consider the validity of the warranty depending on the conditions.
10
[ JAPAN ]
[ GERMANY ]
[ TAIWAN ]
Headquarters
GERMAN Branch / STUTTGART Office
TAIWAN Office
HIROSE ELECTRIC EUROPE B.V.
HIROSE ELECTRIC (TAIWAN) CO., LTD.
Phone : +81-45-620-7410
http://www.hirose.com
Phone : +49-711-456002-1
http://www.hirose.com/eu/
Phone : +886-2-2555-7377
http://www.hirose.com/tw/
NUREMBERG Office
[ U.S.A ]
US Headquarters / CHICAGO Office
HIROSE ELECTRIC ( U.S.A.), INC.
Phone : +1-630-282-6700
http://www.hirose.com/us/
SAN JOSE Office
Phone : +49-911-326889-63
Phone : +49-511-978261-30
[ FRANCE ]
SINGAPORE Office
HIROSE ELECTRIC SINGAPORE PTE. LTD.
PARIS Office
Phone : +1-734-542-9963
Phone : +33-1-85764886
DALLAS Office
[ ITALY ]
BANGKOK Liaison Office
MILAN Office
Phone : +39-02-36636350
Phone : +1-972-324-3370
IRVINE Office
[ CHINA ]
PENANG Representative Office
CHINA Headquarters / SHANGHAI Branch
Phone : +1-949-930-3750
HIROSE ELECTRIC ( CHINA ) CO., LTD.
[ THE NETHERLANDS ]
SHENZHEN Branch
EU Headquarters / AMSTERDAM OFFICE
Phone : +86-755-8207-0851
http://www.hirose.com/cn/
Phone : +31-20-6557460
[ UNITED KINGDOM ]
UK Branch
Phone : +44-1908-202050
Phone : +66-2-686-1255
http://www.hirose.com/sg/
[ MALAYSIA ]
Phone : +65-6324-6113
[ THAILAND ]
BOSTON Office
Phone : +1-978-655-9850
Phone : +82-31-496-7000
http://www.hirose.co.kr/
[ SINGAPORE ]
DETROIT Office (AUTOMOTIVE)
KOREA Office
HIROSE KOREA CO.,LTD.
HANOVER Office
Phone : +1-408-253-9640
[ KOREA ]
Phone : +86-21-6391-3355
Phone : +60-4-648-5536
[ INDIA ]
BANGALORE Office
HIROSE ELECTRIC INDIA PVT. LTD.
Phone : +91-80-4120-1907
BEIJING Branch
HIROSE ELECTRIC ( CHINA ) CO.,LTD.
Phone : +86-10-5165-9332
GUANGZHOU Branch
DELHI Office
Phone : +91-120-660-8018
Phone : +86-180-9895-1861
[ HONG KONG ]
HONG KONG Office
HIROSE ELECTRIC
HONGKONG TRADING CO., LTD.
Phone : +852-2803-5338
http://www.hirose.com/hk/
2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN
https://www.hirose.com https://www.hirose-connectors.com
※ The contents of this catalog are current as of date of 2/ 2021. Contents are subject to change without notice for the purpose of improvements.
11
M E M O
