3840-IM/CK-MP(01)
3840-IM/CK-MP(01)
    HRS(广濑)
    HAND TOOL FOR 3800 SERIES
3840-IM/CK-MP(01) 数据手册
High Life Cycle Interface Connectors 3800 Series Hirose's Unique Contact Structure with High Durability 1) Minimum contact shaving due to a rolled surface on the bellows contact side 2) The spring contact design prevents buckling. 3) Stable contact design provides the support needed to endure 20,000 mating cycles Provides ideal long term contact force. Rolled surface Male contact Bellows contact Housing Plug Plug Female contact Fig.q ■Features 1. 20,000 mating/unmating life cycle with unique Hirose contact structure. Robust Structure 1) The 0.35 mm thick metal shell protects the housing. ◆Receptacle 2. The structure utilizes a metal shell that is 0.35 mm thick. The shell is designed t o c ov e r t h e h o u s i n g a n d p ro t e c t against rough mechanical operation. The addition of reinforced metal fittings increases t h e P C B r e t e n t i o n fo r c e a n d a l l o w s t h e s e connectors to be mounted with commercially available screws for the cradle type. (Fig.w) 3. Sequential mating, that features a 0.5 mm range (Fig.e) ◆Cradle plug 2) Protected Guide Posts Guide Post The metal shell on the cradle provides protection and cover to the guide posts on the cradle plug. 3) Optional screw fastening The cradle can be secured to the PCB with the use of commercially available screws (M2 x 0.4 x 5) to provide additional retention force. 4) Reinforcing metal fittings Commercial screw (optional) Solder is allowed to flow into the through hole and onto the reinforcing metal fittings to increase the PCB retention force. 4. Its small size and light weight design are helpful for use in compact devices 5. Simple mating process with a tactile cl i ck t h a t a s s u r e s p ro p e r m a t i n g completion. ◆Plug Fig.w Sequential Mating Structure The No.1 and 18 contacts are the first contacts to mate, with the remaining contacts mating thereafter. [Effective Mating Length] 1 & 18 Contact: 1.4 mm 2 to 17 Contact: 0.9 mm The pushbutton locking system leads to a simplified mating process that delivers a tactile click to ensure that the mating process was correctly completed. Contact No. 1 m The assembly of this connector is simplified due to its one-piece plug cover. m 6. One piece plug cover 0. 5 Sep.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Receptacle Receptacle 7. RoHS compliant Fig.e Contact No. 18 All materials and substances used to produce this product comply with the RoHS free standards. In cases where the application will demand a high level of reliability, such as automotive, please contact a company representative for further information. 2016.7w 1 3800 Series●High Life Cycle Interface Connectors ■Product Specifications Ratings Items 1. Insulation Resistance 2. Withstanding Voltage 3. Contact Resistance 4. Durability No.2 ∼ N0.17 ⇒ 0.5A No.1, No.18 ⇒ 1.5A Rated Current Rated Voltage AC 125V Operating Temperature Range −40 ∼ +85℃ Specifications Conditions Minimum of 1,000Mø Measured with DC 250V. No flashover or breakdown Apply 350V AC for 1 minute Maximum of 70mø Measured with 100mA (DC or 1,000 Hz) or below 1) Maximum of 20mø of deflection from its initial state 2) No damaged, cracked or loose parts 20,000 mating cycles ■Materials / Finish Sep.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ●Receptacle Component Housing Contact Dust cover Metal shell Materials Polyamide resin Copper alloy Polyamide resin Stainless Steel Color/Finish Black Selective gold plating Black Tin plating Remarks UL94V-0 − UL94V-0 − Component Materials Color/Finish Remarks Housing Polyamide resin Black UL94V-0 Contact Copper alloy Selective gold plating − Metal shell Stainless steel Tin plating − Fastening screw metal Steel Nickel under plating − Materials Polyamide resin Copper alloy Polycarbonate Stainless steel Color/Finish Black Selective gold plating Black − Remarks UL94V-0 − UL94V-0 − ●Cradle Type Plug ●Plug Component Housing Contact Cover Metal shell ■Product Number Structure Refer to the chart below when determining the product specifications from the product number. Please select from the product numbers listed in this catalog when placing orders. 38 40 - B - 18 P ❶ 2 ❷ ❸ ❹ ❺ ❶ Series Number : 38 ❸ Mating Key Type ❷ Termination style 40 : Soldering Type 60 : Right Angle SMT Type 80 : Cradle Type SMT Type ❹ No. of Contacts ❺ Type of Connector P : Plug S : Receptacle 3800 Series●High Life Cycle Interface Connectors ■Receptacle Connector 20.9 Product Lot Number Point of contact (0.5) B Key slots No.1, No.18 No.2-17 22.4 22.3 1 No.18 7.5 5 4.3 No.1 No.2-17 20.55 3.5 (0.35) (0.35) 4 Part No. HRS No. Quantity 3860-B-18S 238-2006-7 00 600 pcs/reel (0.23) 0.8 13.6 ■Cradle Plug Connector 32 PCB installation diagram (10) No.18 No.2 No.17 3.3 (2.76) (20.16) 1.3 13.4 B Keys 21 2.4 Screw M2×0.4×5 PCB(t=1.4∼1.8) 4.2 Product lot number 2.1 (1.6) No.1 4.6 (0.35) 1.5 19.81 5.2 13.6 0.8 Part No. HRS No. 3880-B-18P 238-2008-2 00 (0.5) ■Plug Connector No.18 No.1 23.6 9 (20.16) (2.76) 6.6 B Keys 27.5 Sep.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 1 1.3 3.5 22.25 (22.6) ) 8.4 (φ Part No. HRS No. 3840-B-18P 238-2007-0 00 ) 6.4 (φ 3 3800 Series●High Life Cycle Interface Connectors BApplicable Cable Cross Section 0.08mm2 Configuration 7 / 0.127mm Outer Diameter Ø0.38mm Conductor Size Outer Diameter of Insulation Ø0.58mm Wire Size 28 AWG UL STYLE OF APPLICABLE CABLE:20620、20276 Ho le) BRecommended PCB Layout r ou 4.3 1.3 Black 40.4 44 19.81 ) ole No.2 .2(Ho 5.2 le) 3860-B-18S 2.3 2.7 No.1 No.17 A (φ 13 ) (7.5) (49.5) 600 pieces per reel Vacuum pick-up area dimension 3860-B-18S 5.5 13.6 No.18 hH ug ro Th 1.9( 2xφ Unreeling Direction 1.2 3.5 PCB Edge ) Hole (φ380) ough H ole) 3880-B-18P PCB Dimensions (Reference) 1.5( 2xφ Plastic Reel Package Dimensions (0.4) φ1.6(T hr 0.5 2xφ2 16 4 2 (30) P=0.8 3 Embossed Carrier Tape Dimensions Unreeling Direction φ1 .3( Th 20.55 1.75 (t=1.8 MAX) 22.25 Mounting Surface Sep.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. gh 3860-B-18S PCB Dimensions (Reference) BReceptacle Reel packaging dimensions (JIS C 0806-3) 21 26 BRecommended Reflow Temperature Profile Cycle: Maximum of 2 reflow cycles Maximum of 10 seconds 250℃ Temperature 220℃ 60 ±10 seconds 150−180℃ 90 ±30 seconds Time Please check the mounting conditions before use, conditions such as solder paste types, manufacturer, PCB size and any other soldering materials may alter the performance of such materials. ® 4 2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN TEL: +81-45-620-3526 Fax: +81-45-591-3726 http://www.hirose.com http://www.hirose-connectors.com The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use. The contents of this catalog are current as of date of 07/2016. Contents are subject to change without notice for the purpose of improvements.
3840-IM/CK-MP(01) 价格&库存
很抱歉,暂时无法提供与“3840-IM/CK-MP(01)”相匹配的价格&库存,您可以联系我们找货
