516-280-700
516-280-700
    CRIMPING MACHINE 120/6
516-280-700 数据手册
516 SERIES RACK AND PANEL CONNECTOR (PLUG AND RECEPTACLE) • FEATURES: • .150" (3.81mm) Contact Spacing x .130" (3.30mm) or .150" (3.81mm) Row Spacing with staggered Grid • Plug and Receptacle in 20, 38, 56, 90 and 120 Contact Sizes • Edacon Hermaphroditic Contact Mating Design • Contact Termination Options include Crimp, P.C. Tail, Wire Hole and Wire Wrap • Mating and Unmating Simplified with use of Actuating Screws • Optional Covers with Side or Top Entry Cable Clamp in Plastic or Metal material Available for all Connector Sizes • Versatile Metal Cover Design permits Assembly or Disassembly After Cabling is Complete plus Cable Entry Style Flexibility • Actuating Screws, Locknuts, Polarizing Hardware, Covers and Contacts Suitable for either Plug or Receptacle • Polarizing Hardware Adjustable for 288 Mating Combinations • Tools Available for Contact Installation, Removal and Crimping and Polarizing Changes • RoHS Compliant & UL Recognized Specifications: Insulator Material Color Contact Material Contact Plating Current Rating Contact Resistance Withstanding Voltage Insulation Resistance Operating Temp Operating Temp Insertion & Withdrawal Force Example Part Number: Diallyl Phthalate, Thermoplastic Polyester or Polycarbonate UL 94V- 0 Green, or Polycarbonate Color: Grey Copper Alloy Gold Plating over Nickel over entire contact 8.5 Amperes 10 milliohms maximum 2000 VAC rms at sea level 5000 Megohms minimum -40°C to +125°C (Diallyl Phthalate Only) -40°C to +105°C 2 to 16 Oz (0.56 to 4.45N) per contact position 516-038-500-212 0 1 2 3 4 5 6 Series Total Number of Contacts Contact Code Style and Material Cover Code Hardware Code Series Description No Cover Assembly Plastic Cover, Top Entry Standard Clamp Plastic Cover, Side Entry Standard Clamp Plastic Cover, Top Entry Large Clamp Plastic Cover, Side Entry Large Clamp Metal Cover, Side Entry Metal Cover, Top Entry 516 Total Number of Contacts Contact Code 1,2 000 500 520 540 541 542 Cover Code 4, 5, 6, 7 020, 038, 056, 090 or 120 Description & Tail Size Tail Length "G" No Contacts Assembled Wire Hole .110 x .024 (2.79 x 0.61) P.C. Tail .25 x .024 (0.64 x 0.61) Wire Wrap .050 x .024 (1.27 x 0.61) Wire Wrap .026 x .024 (0.66 x 0.61) Wire Wrap .050 x .024 (1.27 x 0.61) -----------.245 (6.22) .215 (5.46) .600 (15.24) .620 (15.70) .790 (20.07) Style & Material 3 Style Insulator Material 1 2 3 4 5 6 Plug Receptacle Plug Receptacle Plug Receptacle Green Diallyl Phthalate Green Diallyl Phthalate Grey Polycarbonate Grey Polycarbonate Green Polyester Green Polyester www.edac.net Hardware Code 8 0 1 2 5 6 Description No Hardware Actuating Screw & Polarizing Hardware Locknut & Polarizing Hardware Actuating Screw with No Polarizing Hardware Locknut with No Polarizing Hardware 516 SERIES RACK AND PANEL CONNECTOR (PLUG AND RECEPTACLE) Ordering Code Notes Crimp Characteristics 1) Crimp contacts are also available for the 516 series connectors. Contacts may be ordered separately for pre-wired or select position assembly. Part Number Description Silhouette 516-290-500 Wire Hole 516-290-520 P.C. Tail 516-290-540 Wire Wrap 516-290-541 Wire Wrap 516-290-542 Wire Wrap 516-290-590 Crimp Loose 516-290-591 Crimp - 1800 Contact/Reel 2) For contact installation, removal and crimping tools, Please contact EDAC. 3) Grey Polycarbonate insulator material is not available for 120 pin size connector 4) The 20 pin connector cover will not accept the length of the wire wrap contacts 5) Plastic covers with large clamps are only available for 38 and 56 pin sizes only 6) Metal covers with side entry may be converted to top entry by removing side plate and changing clamp orientation 7) Covers may be ordered separately 8) Insulator design prevents improper mating of individual plug and receptacle. Polarizing hardware enables specific plug and receptacle combinations • Contacts and Crimp Tool Accommodate from 28AWG to 18AWG, Solid or Stranded Conductor Diameters from .012 (0.30) to .049 (1.25) and an Insulation diameter up to 0.074 (1.88) • Multiple Smaller Gauge Wires may be Crimped Together • Crimp Resistance from 0.5 Milliohms (18AWG) to 1.5 Milliohms(28AWG) • Crimp Tensile Strength for Wire Sizes 18AWG - 40 lbs (178 N) 20AWG - 25 lbs (111 N) 22AWG - 15 lbs (67 N) 24AWG - 10 lbs (44 N) 26AWG - 5 lbs (22 N) 28AWG - 3 lbs (13 N) Polarizing Codes • Polarizing Hardware Changes allow 288 Mating Combinations • Standard Code Supplied for Plugs PG1G1, for Receptacle RS1S1. • Connectors with Special Polarizing Codes Available upon Special Request Example Polarizing Code: P G 4 S 2 Type of Connector P - Plug, R - Receptacle Large Diameter Hardware G - Guidepin (at Contact Position "A" end) H - Guidepin (at Last Contact Position end) S - Socket (at Contact Position "A" end) T - Socket (at Last Contact Position end) Position of large Diameter Keyway - 1 Through 6 Small Diameter Hardware (Opposite end From Large Diameter) G - Guidepin, S - Socket Position of Small Diameter Keyway - 1 Through 6 This Example mates with Code RS4G2 www.edac.net 516 SERIES RACK AND PANEL CONNECTOR (PLUG AND RECEPTACLE) www.edac.net
516-280-700 价格&库存
很抱歉,暂时无法提供与“516-280-700”相匹配的价格&库存,您可以联系我们找货
