HR12-SC-TC
HR12-SC-TC
    HRS(广濑)
    HAND CRIMP TOOL FOR A HR10A
HR12-SC-TC 数据手册
High Performance Miniature Circular Connectors HR12 Series Features •Snap lock allows for easy insertion and extraction and prevents the accidental un-mating of the connector due to vibration or impact. Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. •The plug diameter range from Ø12mm to Ø16mm, and satisfies the need for small-size, light-weight and high-density electronic components. •Equipped with internal metal parts and a shielding mechanism, the HR12 (20-contacts) and HR212 feature enhanced protection against EMI. Product Specifications Ratings Items Rated voltage Rated current 100V AC, 140V DC 1A Operating temperature range -15ç to +60℃ Storage temperature range -10ç to +60℃ Measured at DC 1mA 2. Insulation resistance Specifications 30mø max. (excluding the cable conductor resistance) 100Mø min. 3. Withstanding voltage No flashover or dielectric breakdown. AC 300V for 1 minute 4. Vibration resistance No electrical discontinuity for 10µs or greater. 10 to 55Hz/cycle, amplitude : 0.75mm, 3 axis directions, 2 hours each 5. Shock resistance No electrical discontinuity for 10µs or greater. Acceleration : 490m/s2,duration : 11ms, 3 axis directions, 3 cycles each 6. Mating Cycles 30mø max. of contact resistance (excluding the cable conductor resistance) 1,000 times 7. Temperature cycle Insulation resistance : a minimum of 100Mø -25ç : 30 minutes ➝ Normal temperature : 10 to 15 minutes ➝ 70ç : 30 minutes ➝ Normal temperature : 10 to 15 minutes, left for 5 cycles 8. Moisture resistance Insulation resistance : 1Mø min. (at high humidity) Temperature : 40ç, 10Mø min. (when dry) relative humidity : 90 to 95%, left for 96 hours 1. Contact resistance Conditions Measured at DC 250V Material / Finish Part Insulator Contacts Material Soft vinylchloride (UL94-0) and Polypropylene (UL94V-0) PBT resin (UL94V-0) and Polycarbonate (UL94V-1) Brass, and Zinc alloy Copper alloy or phosphor bronze Finish –––––––– Tin plated and Nickel plated Tin plated or selective gold plated and silver plated In cases where the application will demand a high level of reliability, such as automotive, please contact a company representative for further information. 2018.8④ 1 HR12 Series●High Performance Miniature Circular Connectors Product Number Structure Cable Plug HR12 A - 10 L A A 8 P C A 300 A (**) ❶ ❷ ❸ ❹ ❺ ❻ ❼ ❽ ❾ Plug (Assembly type) and Receptacle HR12 - 10 R C - 8 SDL (**) ❶ ❸ ❹ ❻ ❼ ❽ Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Attachment HR12 - 10 R - SP (**) ❶ ❸ ❹ qModel : Series name. HR212 is a enhanced shielding type. wIndication of terminal connector provided or not: For models with connectors on both sides, different signs are used depending on the type of connector on one side. eShell size : Indicates the outside diameter of the plug mating part. rConnector form : P : Straight plug LP or L : Right angle R : Receptacle tCable removal directions for a right angle plug are classified as follows : A : The cable removal direction is on the right with the guide facing upward viewed from the mating part. B : The cable removal direction is on the left with the guide facing upward viewed from the mating part. yTypes of connector : A connector with two or more varieties is classified by A, B, C,....... uNumber of contacts iContact form : Classifies the type of contacts as follows: The plug has only male contacts, and the receptacle has only female contacts. P : Male contact PC: Crimp male contact (assembly type plug) SC : Crimp female contact SD : Straight dip female contact SDL : Right angle dip female contact oShape of cable : S : Straight cord C : Curled cord !0Type of cable : Cables connected to the plug are identified by A, B, C,..... when they are different in construction and number of cores. !1Cable length : indicates the length in mm of the cable connected to the plug. Curled cord length : Length of curled part Straight cable length : Cable length !2Shape of cable end: Plugs with cables of the same shape but different in cable end dimensions and finishing are identified by A, B, C,..... !3Types of accessories : SP : Stopper plate !4Other specifications : A two-digit character is added to indicate other specifications as needed. 2 HR12 Series●High Performance Miniature Circular Connectors HR12 Type 1065 Ø4.8 21 Right Angle Plug 15 Ø12 33 1 2 7 6 8 HR12-10LA8PS1065(71) Part No. HRS No. No. of contacts No. of conductors of cable Remarks HR12-10LA8PS1065(71) 112-3040-0 71 8 8-conductor (Shielded) Straight cord Terminal tin plated 10 max. Straight Plug (Representative example) HR12-10P8PC300(71) HRS No. No. of contacts HR12-10P5PCD300(71) 112-0101-6 71 5 HR12-10P8PC300(71) 112-0102-9 71 8 HR12-10P10PCAE300(71) 112-0133-2 71 10 Part No. ØA ØB C 4.8 15 720 5.5 17.5 700 No. of conductors of cable Remarks 5-conductor (Shielded) Curled cord Terminal tin plated 8-conductor (Shielded) 10-conductor (Shielded) Curled cord Terminal gold plated Receptacle (Crimp Type) 2 1 3 5 4 6 7 8 M14∞1 Ø16 1.3 11.3 Hexagon nut 17 15.4 Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 3 4 5 3 (Representative example) HR12-10R-8SC(71) Part No. HRS No. No. of contacts HR12-10R-5SC(71) 112-0501-4 71 5 HR12-10R-8SC(71) 112-0504-2 71 8 Remarks: For the mounting holes, see page 4. 3 HR12 Series●High Performance Miniature Circular Connectors Receptacle (Straight Dip Type) 1 2 5 3 1.3 9.5 Ø16 Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 5.9 15.4 Hexagon subtend dimension 17 M14×1 HR12-10R-8SD(71) Dip post (3×0.3) (Grounding terminal) HR12-10R-5SD(71) 112-0502-7 71 No. of contacts 5 HR12-10R-8SD(71) 112-0505-5 71 8 Part No. HRS No. Dip post (0.6×0.4) (Contact) (Representative example) Remarks Terminal tin plated Remarks : Refer to following diagram for panel mounting dimensions and dip post arrangement dimensions. Panel mounting dimensions Receptacle Dip Post (Panel thickness 1 to 4.7) Hole for grounding terminal 3.2×0.4 2 4 3 1 5 3.2×0.4 2+0.1 0 1.4 1.4 2.8 2.8 HR12-10R-5SD(71) 2 5 4 3 +0.1 Ø0.8 0 7 6 3.2 1 +0.1 Ø0.8 0 (5 places) 1.6 Ø10.7 1.6 7.4 +0.1 0 13.4 +0.1 0 Ø10.7 Hole for grounding terminal 3.2×0.4 8 (8 places) 3.2×0.4 1.4 2.8 1.6 Ø14.1+0.1 0 1.4 2.8 HR12-10R-8SD(71) Remarks : Dimensional tolerance of ±0.05mm is recommended for the board arrangement. 4 HR12 Series●High Performance Miniature Circular Connectors 13 Receptacle(Right Angle Dip) 1 2 5 5.2 A B 1 12 3 2 Dip post(2×0.3) (Grounding terminal) HR12-10R-8SDL(71) (Representative example) R5.75 (Note) No. of Part No. HRS No. A This product should be mounted contacts on the panel to hold with the HR12-10R-5SDL(71) 112-0503-0 71 5 13 interface portion,as shown in the 112-0506-8 71 panel mounting hole dimension HR12-10R-8SDL(71) diagram. 8 13.8 When it is difficult to press the HR12-10RC-8SDL(71) 112-0514-6 71 connector into the panel, we recommend using the attached Remarks : For dip post arrangement see below figure. stopper plate HR12-10R-SP(71) (112-0507-0 71) as described on page 7. B Remarks 10.5 9.3 Terminal tin plated Equipped with stopper plate Terminal tin plated Panel mounting dimensions +0.1 +0.1 0 +0.2 0 13.1 0 (Connector support part) 14 MIN. (For movement) 2 MIN. (Connector support part) 1 +0.3 2.2 0 12.1 +0.1 0 R5.8 PCB Note : Pay attention that this dimension is not available for 10 contacts. Receptacle dip post arrangement 1.4 2.8 1 1.4 2.8 +0.1 Ø0.8 0 (5 places) HR12-10R-5SDL(71) 12.9 5 9.3 Grounding terminal holes +0.1 (2 places) 2.2 +0.1 0 ×0.4 0 4 2 8 1.2 1.2 1.2 10.5 5 3 4.5 5.2 4.5 2.5 4.5 5.2 4.5 1.2 Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 3.5 Dip post(0.6×0.4) (Contact) 7 2 Grounding terminal holes +0.1 (2 places) 2.2 +0.1 0 ×0.4 0 6 4 5 3 1 1.4 1.4 2.8 2.8 +0.1 Ø0.8 0 (8 places) HR12-10R-8SDL(71) Position of applicable receptacle Ø1.5+0.1 0 (4 places) HR12-10R-SP(71) (Stopper plate) (Applicable PCB thickness range 1-2) Remarks : Dimensional tolerance of ± 0.05mm is recommended for the board arrangement. 5 HR12 Series●High Performance Miniature Circular Connectors 15.7 13 Receptacle (Right Angle Dip) 12 1 2 3 3.5 5 Stopper plate 1 Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 3 4 1 HR12-10RC-10SDL(73) 5.2 2.5 No. of contacts 112-0511-8 73 1 5 Dip post of stopper plate (4 pieces) Dip post 0.6×0.15 (10 contacts) 5 2 7 HR12-10RC-10SDL(73) HRS No. 14 9 14 21 Uneven position Ø1×1 9 10 6 7 8 Part No. Dip post 2×0.8 (2 ground terminals) 2.5 12.6 Remarks Color: Black Stopper plate Terminal gold plated 10 Remarks : For dip post arrangement see below figure. 5 2.6 3.5 3 12.6 1 1 14 9 14 21 1 2 5 HR12-10RD-10SDL(71) 4 Dip post of stopper plate(4 pieces) Dip post 2×0.4 (1 ground terminal) Dio post 0.6×0.15 (10 contacts) 3 8 7 6 10 9 7 Part No. HRS No. HR12-10RD-10SDL(71) No. of contacts 112-0512-0 71 Stopper plate Dip post 2×0.8 11.1 5.2 5 2.5 2 1 12 15.7 13 Remarks Color: Black Stopper plate Terminal gold plated 10 Remarks : For dip post arrangement see below figure. Receptacle dip post arrangement +0.1 Ø0.8 0 (10 places) 1 1 2 2 HR12-10RC-10SDL(73) 5 14 Grounding terminal holes Ø2.2+0.1 0 (2 places) Ø0.8+0.1 0 (10 places) Stopper plate +0.1 holes Ø1.5 0 (4 places) 2.5 12.9 4.5 4.5 Grounding terminal +0.1 holes Ø2.2 0 (1 place) 2 1.8 1.8 Grounding +0.1 terminal holes Ø2.2 0 (2 places) 2 1.8 1.8 14 2.5 Stopper plate +0.1 holes Ø1.5 0 (4 places) 11.1 5.2 12.9 4.5 4.5 5.2 5 2.5 Positioning +0.1 hole Ø1.1 0 (1 place) 1 1 2 2 HR12-10RD-10SDL(71) Remarks : Dimensional tolerance of ±0.05mm is recommended for the board arrangement. 6 HR12 Series●High Performance Miniature Circular Connectors Stopper Plate 15.7 (3.5) 8 1 1 12.6 5 Part No. HR12-10R-SP(71) HRS No. 112-0507-0 71 Applicable connector Applicable PCB thickness HR12-10R-*SDL t : 1 to 2 Remarks : 1. The *mark shows the number of pins. 2. For dip post arrangement,see page 5. HR12 Type (20 contacts) /HR212 Type Right Angle Plug (With straight) A 10 MAX. Ø4.8 23 28 6 Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. HR12-10R-8SDL(71) + HR12-10R-SP(71) Ø12 1 2 3 4 5 7 6 8 HR212-10LA8PSAT1028(72) Part No. HRS No. HR212-10LA8PSAT1028(72) 112-2120-1 72 HR212-10LA8PSAT3028(72) 112-2121-4 72 (Representative example) No. of contacts 8 A No. of conductors of cable Remarks 1028 Color: Black 8-conductor (Shielded) Terminal: Selective gold plated 3028 Remarks : Cable can be taken-out only in direction A. 7 HR12 Series●High Performance Miniature Circular Connectors Right Angle Plug (Assembly Type) Solder Type 35 23.3 Ø4.8 23.5 6 Inner dia. 13 㸳 Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 㸵 㸰 㸲 㸯 㸱 㸴 㸶 HR212-10LP-8P(71) Part No. HRS No. HR212-10LP-8P(73) 112-4002-6 73 HR212-10LP-8P(74) 112-4002-6 74 No. of contacts Remarks 8 Color : Black Terminal : Selective gold plated Color : Sand beige Terminal : Selective gold plated Remarks : Cable can be taken-out only in direction A. Note : Because the cable clamping and rotational forces may vary with different cable types, it is recommended to verify the suitability of the cable assembly before use or production. Crimp Type 35 23.3 Ø4.8 23.5 6 Inner dia. 13 1 2 4 5 7 3 6 8 HR212-10LP-8PC(71) Part No. HR212-10LP-8PC(71) HRS No. 112-4101-8 71 No. of contacts 8 Remarks Color : Black Remarks : Cable can be taken-out only in direction A. Note : Because the cable clamping and rotational forces may vary with different cable types, it is recommended to verify the suitability of the cable assembly before use or production. Straight Plug (With straight cable) A 2 1 5 4 3 7 6 8 Ø13.2 Ø12 6 Ø4.8 42 10 Max. (Representative example) HR212-10P8PSAT1042(72) 8 Part No. HRS No. No. of contacts HR212-10P8PSAT1042(72) 112-2220-6 72 8 A No. of conductors of cable Remarks 8-conductor Color : Black 1042 Terminal : Selective gold plated (Shielded) HR12 Series●High Performance Miniature Circular Connectors Straight Plug (Assembly Type) Solder Type 42 4 8 Ø12 2 7 Ø4.8 5 1 3 6 Ø13.2 6 HR212-10P-8P(71) Part No. HRS No. HR212-10P-8P(71) 112-4001-3 71 HR212-10P-8P(72) 112-4001-3 72 HR212-10P-8P(73) 112-4001-3 73 HR212-10P-8P(74) 112-4001-3 74 (Representative example) No. of contacts Remarks Color : Black Terminal : Tin plated Color : Sand beige Terminal : Tin plated Color : Black Terminal : Selective gold plated Color : Sand beige Terminal : Selective gold plated 8 Note : Because the cable clamping and rotational forces may vary with different cable types, it is recommended to verify the suitability of the cable assembly before use or production. Crimp Type 42 1 3 6 Ø4.8 4 8 Ø12 2 7 Ø13.2 6 5 Inner dia. (Representative example) HR212-10P-8PC(71) Part No. HR212-10P-8PC(71) HR212-10P-8PC(72) HR212-10P-10PC(71) HR212-10P-10PC(72) HRS No. 112-4051-1 71 112-4051-1 72 112-4052-4 71 112-4052-4 72 No. of contacts Remarks ---------------------Color: Sand beige ---------------------Color: Sand beige 8 10 Note : Because the cable clamping and rotational forces may vary with different cable types, it is recommended to verify the suitability of the cable assembly before use or production. Receptacle (Crimp Type) 15.7 11.3 22.5 17.5 1 13 Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Inner dia. 3 2 5 Nut for M2 (Representative example) HR212-10R-8SC(71) No. of contacts HR212-10R-8SC(71) 112-2001-2 71 8 Part No. HRS No. Remarks ---------------------- 9 HR12 Series●High Performance Miniature Circular Connectors Receptacle (Straight Dip Type) 15.7 11.3 22.5 17.5 2 1 13 3 5 8 0.5×0.2 Nut for M2 1×0.2 Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. HR212-10R-8SD(73) Part No. HRS No. HR212-10R-8SD(73) 112-2002-5 73 HR212-10R-8SD(74) 112-2002-5 74 No. of contacts 8 Remarks Color : Black Terminal : Tin plated Color : Black Terminal : Selective gold plated Remarks : For dip post arrangement, see below figure. Receptacle (Right Angle Dip Type) 22.5 17.5 1 2 5 3 3 13 13.8 Nut for M2 8 -0.6 4 -0.4 4 -1 8 -0.4 13 HR212-10R-8SDL(73) Part No. HRS No. HR212-10R-8SDL(73) 112-2003-8 73 HR212-10R-8SDL(72) 112-2003-8 72 (Representative example) No. of contacts 8 Remarks Color : Black Terminal : Tin plated Color : Sand beige Terminal : Selective gold plated Remarks : For dip post arrangement, see below figure. Receptacle Dip Post Layout +0.1 Ø0.8 0 12.6 1.4 2.8 2.8 HR212-10R-8SD 2.5 9.3 4 1.2 1.4 1.2 1.6 5.5 1.2 3.2 1.6 (8 places) Grounding terminal +0.1 holes 1.1+0.1 0 ×0.5 0 (1 place) Grounding terminal +0.1 holes 1.1+0.1 0 ×0.5 0 (1 place) Ø0.8+0.1 0 (8 places) 1.4 1.4 2.8 2.8 HR212-10R-8SDL Remarks : Dimensional tolerance of ±0.05mm is recommended for the board arrangement. 10 HR12 Series●High Performance Miniature Circular Connectors Receptacle (Right Angle Dip Type) 14 13 1 2 5 3.5 12 3 8 -0.6 2 -2 8 -0.4 HR212-10RA-8SDL(74) Part No. HRS No. No. of contacts HR212-10RA-8SDL(74) 112-2004-0 74 HR212-10RA-8SDL(72) 112-2004-0 72 HR212-10RA-8SDL(73) 112-2004-0 73 Remarks Color : Black Terminal : Tin plated Color : Sand beige Terminal : Selective gold plated 8 Color : Black Terminal : Selective gold plated Remarks : For dip post arrangement, see below figure. 21.1 13 14.1 㸰 㸱 㸳 3.5 12 㸯 Positioning pin Ø1 2 -0.4 2 -0.8 10 -0.6 10 -0.15 2 -2 HR212-10RC-10SDL(74) Part No. HRS No. HR212-10RC-10SDL(74) No. of contacts 112-2009-4 74 Remarks Color : Black Terminal : Selective gold plated 10 Remarks : For dip post arrangement, see below figure. 9.5 㸶 㸵 㸳 +0.1 0 Positioning hole Ø1.1 (1 place) Grounding terminal +0.1 hole Ø2.2 0 (2 places) 㸱 㸯 1.4 2.8 1.4 1.8 2 0.7 1.9 3.1 Ø0.8+0.1 0 (8 places) 4.5 1.8 㸴 㸲 㸰 4.5 14.1 3.4 (8.6) Grounding terminal hole +0.1 2.2 +0.1 0 ×0.8 0(2 places) 2.6 5.4 Receptacle Dip Post Layout 4.3 Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 2 -0.4 2 -0.8 1 1 2 2 Ø0.8+0.1 0 (10 places) 2.8 HR212-10RA-8SDL HR212-10RC-10SDL Remarks : Dimensional tolerance of ±0.05mm is recommended for the board arrangement. 11 HR12 Series●High Performance Miniature Circular Connectors Straight Plug 5000 55 Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. φ6 5 4 3 2 1 Ø16 10 Max HR12-14P20PSD5000(71) Part No. HR12-14P20PSD5000(71) HRS No. (Representative example) No. of No. of conductors of cable contacts 112-1105-2 71 20 20-conductor (Shielded) Remarks Straight cord Terminal : silver plated Right Angle Plug 700 20.5 300 30 Ø20 Ø16 Ø6 10 Max. HR12-14LA20PC300(71) Ø100 5 4 3 2 1 Part No. HR12-14LA20PC300(71) HRS No. 112-1001-7 71 Remarks : Cable can be taken-out only in direction A. 12 No. of No. of conductors of cable contacts 20 20-conductor (Shielded) Remarks Curled cord Terminal : silver plated HR12 Series●High Performance Miniature Circular Connectors Receptacle (Crimp Type) 21 16 㸰 㸱 㸲 㸳 20 14.5 㸯 15.5 10 Part No. HR12-14RA-20SC HRS No. No. of contacts Remarks 112-1504-8 20 With hexagon nut Receptacle (Right Angle Dip Type) 21 16 .2 Ø2 㸰 㸱 㸲 㸳 20 14.5 㸯 Dip post(0.6×0.25) (Contact) Dip post (1×0.9) (Grounding terminal) 25 5 HR12-14R-20SDL 5.08 3.5 20.2 3.81 No 20 No 16 Grounding terminal hole Ø1.3+0.1 0 (4 places) No 5 (Dip Post Layout) Part No. HR12-14RA-20SDL HRS No. 112-1502-2 No. of contacts Remarks 20 With hexagon nut Terminal: silver plated 1.9 No 1 1.9 3.8 3.8 17.78 1.9 5 1.9 1.9 Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. .2 Ø2 HR12-14RA-20SC Ø0.8 +0.1 0 (20 places) Remarks : Dimensional tolerance of ±0.05mm is recommended for the board arrangement. 13 HR12 Series●High Performance Miniature Circular Connectors Contact Female Contact A 1 Type 10 A 1.15 1.2 Loose contacts Reel contacts HRS No. Plated Applicable wire 112-0410-0 Selective gold plated HR12-SC-112 112-0411-3 Silver plated HR12-SC-113 112-0412-6 Tin plated HR12-SC-211 112-0407-6 Selective gold plated HR12-SC-212 112-0408-9 Silver plated HR12-SC-213 112-0409-1 Tin plated 26 to 30 AWG Note 1. Use cables with cable covering outer dia. Ø1mm or less. 2. Loose piece contacts are packaged 100 pcs/pack. Reel contacts are packaged 10,000 pcs/reel. Section A-A Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Part No. HR12-SC-111 1 Male Contact 10 A 1.15 1.2 Type Part No. HRS No. Loose contacts HR10-PC-111 110-0515-6 HR10-PC-113(71) 110-0519-7 71 Reel contacts HR10-PC-211 110-0516-9 HR10-PC-213(71) 110-0520-6 71 Plated Applicable wire Selective gold plated Tin plated Selective gold plated 26 to 30 AWG Tin plated Note 1. Use cables with cable covering outer dia. Ø1mm or less. 2. Loose piece contacts are packaged 100 pcs/pack. Reel contacts are packaged 10,000 pcs/reel. Section A-A Applicable tools Type Item Part No. HRS No. Applicable terminal Automatic Manual HR10-PCHR12-SC-TC 150-0052-9 111 HR12-SC- 112 113 Automatic crimping machine body CM-105C 901-0001-0 ---------------------- Applicator AP105-HR12-1 HR12-SC-TP 901-2015-9 RP6-SC-TP (HR12-SC-TC) Hand Crimp Tool 26 to 30 AWG ---------------------- 211 213(71) 211 HR12-SC- 212 213 26 to 30AWG 150-0050-3 111 112 113 HR12-SC211 212 213 ---------------------- 150-0039-0 111 113(71) HR10-PC211 213(71) ---------------------- Extraction tool 14 111 113(71) Manual crimping tool HR10-PC- Applicable wire (HR12-SC-TP)  (RP6-SC-TP) Extraction Tool Auto Crimp Tool CM-105C HR12 Series●High Performance Miniature Circular Connectors Cable Connecting Procedures Works Process Right-angle Plug Straight Plug 1 Use cables of finished dia. 4.8mm and nominal conductor cross section of 0.129mm2 (AWG#26) and under. (Inner dia. of solder pot of soldering terminal is Ø0.7mm.) 2 Insert bushing over cable as shown in Fig.1. Install hood over cable. Figure of straight type is omitted. 6 20 -50 Soldering type Copper tape Crimping type:1.5+0.5 0 Approx.2 C Bushing Shied cable 3 Mold block or mold P shell A P shell B Fig.1 Make cable end treatment to the dimensions shown in Fig.1. For shield cable, an example of cable end treatment is given below. (1) Firmly wrap the cable sheath end with copper tape 6mm wide, 16mm long and 85µm thick (overall thickness including adhesive). (2) Bundle up the shield cables, and tight twist. (Twist at least three turns over 6mm in length from the cable sheath tip) (3) Cut the shield cables at 6 0-1mm from the cable sheath tip, and fold back as shown in Fig.1. 4 (Soldering Type) Solder cables to mold block into which terminals are assembled. (Crimping Type) Use applicable tool (HR12-SC-TC or CM-105) to crimp connect cables to applicable crimping terminals, then insert crimped terminals into mold and fix them to complete the mold block. 5 Assemble mold block having cables connected to location P shell A as shown in Fig.1. Carefully note that mold block and P shell A have directional polarization. 6 Assemble bundled shield cables so that they are positioned at the center (C section) of cable outlet of P shell A as shown in Fig.1. Install P shell B over P shell A as shown in Fig.2 and avoid catching of internal cables. Use the M2 self-tapping screws supplied (shape of screw head is phillip #0 for precision machinery) to secure from the direction of P shell B (2 places). 7 Cable Casing Ø4.8 Self-tapping screw P shell A Fig.2. Move bushing to the end face of P shell, and put P shell and bushing into the casing as shown in Fig.2. P shell B With groove of hood and protruding portion of P shell aligned, install hood over P shell as shown in Fig.3. Hood Cable 8 Ø4.8 Groove of hood Install casing over P shell as shown in Fig.4. Cable P shell Bushing Protruding portion Fig.3 9 6 Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Ø4.8 Cable Fig.4 10 Now assembling is completed. 15 HR12 Series●High Performance Miniature Circular Connectors Terminal Arrangement and performance Shell size 10 sizes 㸦 Terminal arrangement Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Powered by TCPDF (www.tcpdf.org) 5 Shell size 㸧 㸧 㸦 㸩 㸨 㸪 㸨 㸪 㸫 㸭 㸬 㸫 㸪 㸩 No. of contacts Withstand voltage Rated current Insulation resistance Contact resistance 㸨 㸧 㸦 㸭 8 300V AC for 1 minute 1A 200Mø or more at 250V DC 30mø or less (excluding cable conductor resistance) 10 14 sizes 㸦 㸧 㸨 㸩 㸪 Terminal arrangement No. of contacts Withstand voltage Rated current Insulation resistance 20 300V AC for 1 minute 1A 200mø or more at 250V DC 30mø or less (excluding cable conductor resistance) Contact resistance Remarks : 1. The above figures show the receptacle pin inserts as viewed from the mating side. 2. Withstand voltage shows the testing voltage. 3. Contact resistance is as measured at 1A DC. Precautions This product series uses silver plated contacts. Silver reacts easily to exposure to sulfur gas so the below conditions may cause tarnishing.  ・Dusty environments  ・Area with a high concentration area of gases such as sulfur dioxide gas, hydrogen sulfide gas, nitrogen dioxide gas and so on. Example; In close proximity to factory exhaust, automotive emissions, etc.  ・Close to heaters, or in other areas marked by extreme temperature differences or high humidity.  ・Close to rubber products includes rubber adhesives. The Electrical connection is not affected by tarnishing on a silver surface due to the wiping effect of the contact pins. Storage Packing state; Packed in original packing or equivalent container Temperature -10 to +60ç Humidity 85% Max (It is recommended that the product be stored in an area of normal level of temperature and humidity, and free of any temperature fluctuation) Please use this products within 6 months of delivery. (After 6 month, please check the solderbility before use) “Storage” means long-term storage of the unused products in sealed packaging, prior to assembly to PCB. ® 16 2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN TEL: +81-45-620-3526 Fax: +81-45-591-3726 http://www.hirose.com http://www.hirose-connectors.com The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use. The contents of this catalog are current as of date of 08/2018. Contents are subject to change without notice for the purpose of improvements.
HR12-SC-TC 价格&库存
很抱歉,暂时无法提供与“HR12-SC-TC”相匹配的价格&库存,您可以联系我们找货
